| J.M. |
 J.M. World Chat Champion
 Posted: 19:24 - 23 Mar 2013 Post subject: Bike still cutting out in the wet |
Bugger.
https://sphotos-e.ak.fbcdn.net/hphotos-ak-ash4/317528_556561484378819_134680059_n.jpg
GS500 2004.
Essentially as the bike gets wet. One (right) cylinder starts to intermittently work. As you progress, it'll just stop working completely.
Moving from a standstill requires a lot of clutch slipping and yields the performance of a 50cc ped.
Motorway at full throttle just maxes out at about 7k RPM, so you can get a 50mph.
Eventually it got to the stage where the engine was just completely cutting out.
What I have done:
- Replaced spark plugs with known working ones
- Replaced coils/ht leads/ht caps with known working ones
- Gone over all the wiring of the bike that I could see with heat shrink
- Removed all accessories from the bike
I'm thinking there must be a connection somewhere which is earthing once wet.
Does anybody have any clues what to check? ____________________ 2004 R1 & 2018 XSR900 |
| P.addy |
 P.addy Red Rocket
 Posted: 19:29 - 23 Mar 2013 Post subject: |
Have you checked the coils themselves.
WD40 the lot, sand down where they bolt to frame.
Cover it in silicone spray and let it set. Happened to my Bandit 600, died in rain only... did that and problem went away  |
| Scythe |
 Scythe Crazy Courier
| P.addy |
 P.addy Red Rocket
| J.M. |
| P.addy |
 P.addy Red Rocket
| J.M. |
| P.addy |
 P.addy Red Rocket
| J.M. |
 Posted: 19:40 - 23 Mar 2013 Post subject: |
I can't afford to buy/insure nice bikes  ____________________ 2004 R1 & 2018 XSR900 |
| bladerunner |
 bladerunner World Chat Champion
| YBR Ric |
 YBR Ric Spanner Monkey
| Clutchy |
 Clutchy World Chat Champion
 Posted: 00:57 - 24 Mar 2013 Post subject: |
Not really sure how to word this, ill give it a go, someone please correct/help me!
The electrical component that generates the spark (is it known as a distributor on a bike?) could be an issue, water could be getting in but I imagine that would affect the other cylinder aswell?
If not keep working backwards? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| Clutchy |
 Posted: 01:00 - 24 Mar 2013 Post subject: |
If not can we not go back to looking at the carbs?
Long shot but is there a chance that water could be getting in at any point (assuming all issues are because of the rain) on the carb and diluting the petrol to a point where it wont spark?
Is there anyway where you can get the bike to cut out like before and test to see if the plug actually sparks off the block to test? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| haroman666 |
 haroman666 World Chat Champion
| J.M. |
 Posted: 11:39 - 24 Mar 2013 Post subject: |
I'll try to answer in order:
@Blade
I doubt it will be anything like the kill switch, as those circuits completely cut both cylinders from sparking. The issue seems to be that the spark gets progressively weaker until it just can't spark.
I will look at the wiring diagram later today... although I've left my manual at my other address 30 miles away
My hope is that the coils are attached in series rather than parallel, with the left coil being before the right coil. If that's the case then I suspect a dodgy earth before the left coil, meaning the right coil is getting progressively less voltage until it cuts out, then the left cylinder does the same.
It's also worth noting... in the wet the backlights for the clocks seem to vary in brightness depending on RPM. This doesn't happen in the dry. The last time that happened, I had a charging fault which I fixed (but not this present fault).
@YBR, cool idea to try, thanks
@Clutchy, carbs aren't the issue. There will physically be no spark present, rather than just a terrible mixture. I have managed to reproduce it on one occasion (before replacing the coils+leads+caps) by chucking water all over the front of the bike.
@Haroman
Mine is CDI, yes. It has a range of confusing gizmos on the bike, like a throttle position sensor and an air flow sensor, along with a CDI and a signal generator to tell the coils when to spark, on a carbed bike.
I have a wiring diagram, but it's in my manual 30 miles away. I think I have a PDF on my laptop too though, which I shall be looking for/through today.
WD shall be coming to play I feel, yes. ____________________ 2004 R1 & 2018 XSR900 |
| sickpup |
 sickpup Old Timer
| TotalGSXR |
 TotalGSXR Borekit Bruiser
| Vincent |
 Vincent Banned
| J.M. |
| P.addy |
 P.addy Red Rocket
 Posted: 12:52 - 24 Mar 2013 Post subject: |
You replaced both.
Do you remember your old working one, tried that on the currently broken side? Doubt you would have 2 faulty coils but... I would have swapped and seen if it was the coil breaking down or some wiring somewhere.
Well, you have 2 weeks or so it strip absolutely everything electrical off and check for everything.
Start with the loom  |
| moppy |
 moppy World Chat Champion
| J.M. |
 Posted: 12:58 - 24 Mar 2013 Post subject: |
Unfortunately I left the other coils back in Birmingham... so I can't try those until I'm back there.
Although I may go back sooner than 2 weeks. I'll look for a dry day after a week or so and go for it probably. Need to see that girl ASAP because I have been, quite frankly, ruining all chances with her slowly since Saturday morning.
As for the ZZR... I would love one. However insurance still says no... at that was before my fault accident. ____________________ 2004 R1 & 2018 XSR900 |
| Alpha-9 |
 Alpha-9 Super Spammer
| J.M. |
 Posted: 13:10 - 24 Mar 2013 Post subject: |
Yeah, I'll be trying that Alpha
Okay... just been looking at the wiring diagram. TotalGSXR has sent me a photocopy of his manual's wiring diagram, thank you!
From the CDI, 1 wire goes to a solenoid, which then goes directly to the coils. The diagram makes it appear that the coils are ran in parallel rather than in series.
I anticipate that my first port of call shall be to track down this wire + solenoid and check it for defects. ____________________ 2004 R1 & 2018 XSR900 |
| sickpup |
 sickpup Old Timer
The last post was made 13 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
