Project 'Buyers Remorse' - XT350
Tristan.
PostPosted: 12:59 - 28 Mar 2013    Post subject: Project 'Buyers Remorse' - XT350 Reply with quote
I’ve been wanting to get into muddy riding for ages, and I’ve been looking for a bike in budget for quite some time. Unfortunately I think I got overexited and climaxed prematurely.
Last weekend I went to view this heap
https://i35.photobucket.com/albums/d170/tristanthe/xt.jpg
1988 XT350
Beforehand I had priced up every consumable and was confident that even if I replaced all of them I could still have a decent green laner for a decent price, so when I viewed it my main concern was checking the frame was solid not rusted through, which it is, just covered in surface rust. Knocked a few quid off as the rear rim had aids
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/B8DAC442.jpg
And the oil stinks of petrol.
Anyway money changed hands and the exty slipped into something a little more comfortable.
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/D4AD4C41.jpg
The next day I dislodged the bike from the car and put it together,
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/E07F5C40.jpg
then brought it into the house and started taking it apart.
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/2EB16139.jpg
All going quite well. No major issues and a few nice surprises – frame is fine in the covered areas and the steering head bearings are very new, Next I found this travesty
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/A7987E33.jpg
footpeg hanger is welded to the frame (brake lever is attached to the back of it, swingarm spindle is behind it and passes through the engine) so it needed to be removed. After asking for advice in the workshop I decided to try and chop it off, but first I would remove the top half so I could remove the swingarm, engine etc, to make it easier to turn the frame over and mitigate the chances of catching anything expensive.
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/66EE56F2.jpg
That’s pretty much the last thing you want to be doing to a bike you bought 2 days ago.
Then I hit a brick wall.
The swingarm pivot bolt and the 3 linkage bolts are completely seized in their bearings
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/77D67CFD.jpg
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/B72FFB1B.jpg
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/2FC12BB9.jpg
Given how fucked the shock was I just chopped through it to get a bit more access
I’ve managed to get the swingarm pivot bolt to rotate, initially with a fucking big breaker bar, but now it’ll turn with my crappy impact gun, but only for 10s at a time before my teeny compressor runs out of puff, so I’ve ordered an electric impact gun which should be able to handle spinning it constantly. I’ve also been soaking it in plusgas constantly, so current plan is to get it spinning constantly, then tap it and maybe apply heat to the swingarm. If that doesn’t work the angle grinder comes out again and I’ll butcher the swingarm, replacements are fairly cheap.
Then today I came down to find this
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/0B5FFB28.jpg
Something else to look into.
The temptation to break it is very high, only curtailed by the fact that barely any of it is saleable and the bits that are probably won’t break even what I paid.
Time to play with the Zixxers to cheer myself up.
PostPosted: 13:03 - 28 Mar 2013    Post subject: Reply with quote
Curious... what did you pay for that?
I sold my 2005 WR450F for £822 and it even came with a spare plated frame Neutral
Tristan.
PostPosted: 13:08 - 28 Mar 2013    Post subject: Reply with quote
Middle Finger
haha
no, an embarrassing amount. Normally I'm pretty good on bargains, my 2 ZX7Rs cost less than £1200 and My daily driver '95 VFR750 cost me £600 to get it on the road. This was £460, plus the petrol to go get it Embarassed
Tim..
PostPosted: 13:23 - 28 Mar 2013    Post subject: Reply with quote
Good luck with this one
You'll need it Wink
www.marshallracing.co.uk
MaybeGuy
PostPosted: 13:34 - 28 Mar 2013    Post subject: Reply with quote
I like the part where it became rusty.
PostPosted: 13:38 - 28 Mar 2013    Post subject: Reply with quote
Ah that sucks Sad
Faraz
PostPosted: 13:59 - 28 Mar 2013    Post subject: Reply with quote
Jesaas. Shocked
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
pepperami
PostPosted: 23:10 - 28 Mar 2013    Post subject: Reply with quote
Pah! Piffle! , you think you`ve bought a stupid project.
I raise you the Jawas from hell!
https://i158.photobucket.com/albums/t87/pepperami_photos/Jawa3.jpg
https://i158.photobucket.com/albums/t87/pepperami_photos/Jawa2.jpg
Previous owner was an expert on home made alternative wiring and ripping out parts without the aid of tools Shocked
CHR15
Turbo nutter bastard
PostPosted: 23:20 - 28 Mar 2013    Post subject: Reply with quote
just to make you feel better, i paid 500 quid for this.
https://i939.photobucket.com/albums/ad233/chris-bracey/GK73A/CW022316Medium.jpg
trololol.
tomh
PostPosted: 23:31 - 28 Mar 2013    Post subject: Reply with quote
I'd be tempted to buy another shitter and just put the best of both together.
However, I can't see why it can't be sorted if you spend enough time on it. The best way to get through them shock linkages free is by cutting it off on both sides with a hacksaw. Once free knock out the collars, remove dust seals and then using a similar sized socket and hammer, knock out the bearings. If you take them to a local bearing shop it shouldn't cost to much to get replacements.
You'll probably find with the swingarm that its the bolt seized to collars so you can turn the bolt as the collars move in the rusty bearings but obviously can't remove the bolt, what you need for that is lot and lots of HEAT. Put the nut back on the spindle if you want to protect it and then hit away with a BIG hammer.
Keep us updated anyway Thumbs Up
Nick 50
PostPosted: 01:07 - 29 Mar 2013    Post subject: Reply with quote
trololol.
I see your £500 and raise you this for £200:
https://i300.photobucket.com/albums/nn6/ElScampio/541006_10151388102157037_1256157742_n_zps2be5036f.jpg
dangerousdave
PostPosted: 18:57 - 29 Mar 2013    Post subject: Re: Project Buyers Remorse Reply with quote
https://www.ebay.co.uk/itm/Yamaha-New-XT350-Frame-/261191007690?pt=UK_Motorcycle_Parts&hash=item3cd0327dca#ht_351wt_1062
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
PostPosted: 18:59 - 29 Mar 2013    Post subject: Reply with quote
trololol.
Free Dance!
https://super-user.co.uk/b44.jpg
Irn-Bru
PostPosted: 19:02 - 29 Mar 2013    Post subject: Reply with quote
Is the engine at least a good runner or does it have the aids also? Razz The back wheel is interesting, never seen that sort of damage before.
Tristan.
PostPosted: 18:13 - 30 Mar 2013    Post subject: Reply with quote
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/9C1D154C.jpg
Fuck you swingarm spindle
many many many hours to get that out, then ten minutes to get the engine out
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/BC500BA9.jpg
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/374E44B9.jpg
(rear mudguard captive nuts are spinning so they'll get drilled out later)
Short tangental story, I decided to lift the engine onto my bench, but I was wearing a clean suit, so I stripped off as the engine is filthy. Cue my girlfriend walking in as I'm hunched over with the engine in my naked midriff
"are you... fucking that?"
Then I had a manly shower using swarfega all over.
Then I realised I'd been stupid and I should of cleaned the engine first, so I used some of the skanky old petrol in my parafinn gun
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/B41C7C3F.jpg
Yes I'm whitetrash with a fridge in my garden - to be fair it's handy for this sort of thing
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/6E722C2E.jpg
also cleaned up the swingarm, which is in decent nick, I expected terminal rust holes
although the linkage has more aluminium aids
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/934905BC.jpg
I'll keep an eye out for a new one.
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/5572D72E.jpg
Next step is to see what kind of derpgasm the engine's had. As I mentioned the oil stinks of petrol so I'm expecting rings aren't sealing at the least. Plus there's the oil leak.
Tristan.
PostPosted: 18:29 - 30 Mar 2013    Post subject: Reply with quote
Argh, what kind of prick puts a bolt like this back on an engine
https://i35.photobucket.com/albums/d170/tristanthe/Snapbucket/463986CC.jpg
pdg
PostPosted: 01:30 - 31 Mar 2013    Post subject: Reply with quote
Thanks for this story - keep it up, I feel so much better Laughing
Seriously though, I've had worse on the road in the (distant) past...
bladerunner
PostPosted: 01:58 - 31 Mar 2013    Post subject: Reply with quote
The same one that lets a bike get like that in the first place....I HATE when people put fubar bolts and fasteners on a bike that are just going to kick you big time next service or repair. Honestly....spend a quid getting a new one! Float bowl screws and countersunk master cylinder screws being 2 of my pet hates ..... Total cost for stainless items currently 16p time taken to remove refitted ones that have been rounded to nothing ...... Maybe an hour each and the kit required to do it!!!
Zen Dog
PostPosted: 12:54 - 31 Mar 2013    Post subject: Reply with quote
Jesus Christ. What the hell have you bought? Shocked
Thats not a bike. Thats 25 years of rust and abuse, with tyres. If you get that thing going I'll be be seriously impressed.
Zen Dog
Ichy
PostPosted: 13:23 - 31 Mar 2013    Post subject: Reply with quote
Anything can be got running again, it's just a matter of how much money you spend on it.
Blackwolf
Burgerfist
PostPosted: 17:01 - 31 Mar 2013    Post subject: Reply with quote
Where do you all get these cheap bikes from?! I want one Crying or Very sad
suzukirider19...
PostPosted: 19:43 - 31 Mar 2013    Post subject: Reply with quote
paid way too much imo this is local to me as i was gonna buy it
https://www.ebay.co.uk/itm/yamaha-xt-350-spares-repair-project-/121085937027?pt=UK_Motorcycle_Parts&hash=item1c3148c583#ht_944wt_1130
husky sm610
Sload
PostPosted: 20:23 - 31 Mar 2013    Post subject: Reply with quote
Christ what a mess Thumbs Up
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
The last post was made 13 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 137.82 Kb
