Cyclone V2 killing 125 battery in 20 hours
Mark 37
PostPosted: 16:24 - 21 Apr 2013    Post subject: Cyclone V2 killing 125 battery in 20 hours Reply with quote
Pretty much as above. I fitted the alarm yesterday. Just the basic set up into indicators and battery.
The wife went out the back and heard a buzzing noise. I switched the alarm off then on again and notice the indicators weren't flashing.
I switched the alarm off and tried the indicators which worked. I then tried to fire the bike up, nothing. I've taken the battery out and put it on charge (just in time).
All the other wires (not in use) I heat shrunk all of them to insulate, then folded them neatly and cable tied them into an area of the bike surrounded by rubber, so wouldn't expect that to be the issue.
Can anyone enlighten me?
Thanks,
Mark
EDIT, forgot to say its a Honda cbf125 with a 12V 6amp battery.
No matter how fast light travels, darkness was always their first.
J.M.
PostPosted: 16:27 - 21 Apr 2013    Post subject: Reply with quote
All alarms will have a draw along with them. If you fitted the LED too, that's another (albeit minor) draw.
If your battery was low in the first place, it's entirely possible that the alarm drained the battery.
You do have to be careful if you leave a bike sitting for a couple of days with an alarm attached! 20 hours does sound way too quick, but as I say, if the battery was low in the first place this would happen.
2004 R1 & 2018 XSR900
Mark 37
PostPosted: 17:05 - 21 Apr 2013    Post subject: Reply with quote
I did not think the battery would be low. Las run was Thursday night 100 miles or so.
Mark
EazyDuz
PostPosted: 18:30 - 21 Apr 2013    Post subject: Reply with quote
Mark
Battery might just not be holding a charge.
Get a Motobatt and see if the problem persists, i bet it wont
Sako
PostPosted: 18:43 - 21 Apr 2013    Post subject: Reply with quote
get yourself an optimate trickle charger.
PostPosted: 18:55 - 21 Apr 2013    Post subject: Reply with quote
Cyclone wired with just the + and - will not discharge a battery for week over 2-3weeks, even then, that is a weak battery.
Wired just those wires in as its all that's needed, no issues even when leaving bike for well over a week in winter.
bridgedino
PostPosted: 19:18 - 21 Apr 2013    Post subject: Reply with quote
My Cyclone has been wired into my 250 for a good few months now with no ill effects. All be it I didn't bother with the indicators, just the basic motion sensor set up
I ride 5 or 6 days a week and it hasn't affected my battery
Do you know your battery history? Have you had it from new?
Mark 37
PostPosted: 19:20 - 21 Apr 2013    Post subject: Reply with quote
I have one but can't leave it on as the bikes outside.
Cheers,
Mark
J.M.
PostPosted: 19:21 - 21 Apr 2013    Post subject: Reply with quote
Mark
On the other hand, if your charging system isn't up to spec, a long run would rather discharge the battery.
I've had a bike cut out on me due to a flat battery after 140 odd miles on the motorway before, although the battery was low before leaving.
Sako
PostPosted: 19:27 - 21 Apr 2013    Post subject: Reply with quote
Cheers,
Mark
get yourself a garage.
Mark 37
PostPosted: 19:29 - 21 Apr 2013    Post subject: Reply with quote
Battery is from new, 2 years old.
Up until now I've had no battery issues. Over winter I took it out charged it and it held its charge for 3-4 weeks, only dropping 10-20% of its charge.
Cheers,
Mark
uberkron
PostPosted: 22:00 - 21 Apr 2013    Post subject: Reply with quote
Use a multimeter to see if the alarm is drawing current, and that the bike is charging properly. If the battery is more than two years old id suspect it.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
Turkish
PostPosted: 22:26 - 21 Apr 2013    Post subject: Reply with quote
This. Check the current draw of the alarm with a DMM in series with the + or - supply. If it's more than a few milliamps then there could be an issue with it - the rated current is on their website somewhere.
ZX-6R G2
CBR125R RW6
uberkron
PostPosted: 22:41 - 21 Apr 2013    Post subject: Reply with quote
Most thatcham approved ones drop down to 15ma standby/armed. Leaving it disarmed may flatten your battery as draw will be somewhere near 250ma.
uberkron
Mark 37
PostPosted: 13:05 - 15 May 2013    Post subject: Reply with quote
It seems the battery was very low. After charging it I've had no issues with the battery draining.
It appears the buzzing noise came from the horn because I now have no working horn since the alarm was fitted (found out when I needed my horn for an idiot cutting me up).
Can anyone tell me what's happened to the horn and if its fixable?
Thanks,
Mark
PostPosted: 15:42 - 15 May 2013    Post subject: Reply with quote
If you have a buzzing coming from your horn it means you have some sort of electrical feed to it. If it's not 'beeping' horn noises but just a low buzz you have a low voltage feeding it.
Pretty obviously if it started when you wired in the Cyclone, you have fucked up somewhere.
Triumph Trophy Launch Edition
Shinigami
PostPosted: 16:01 - 15 May 2013    Post subject: Reply with quote
Cheers,
Mark
2 years old is pretty old for a bike battery, they don't last particularly long some of them
Mark 37
PostPosted: 22:13 - 15 May 2013    Post subject: Reply with quote
It didn't start straight away. It was about 6 hours after fitting. Not from when i connected the battery.
I only connected the four wires as instructed by the hand written notes. Two to positive feeds of indicators which were staggered and fully insulated with heat shrink then electrical tape, then the red and black to the battery. Smile
If we ever get some dry weather when the kids are out the way ill put the meter on the tabs that connect to the horn to see if the switch is working. Then I'll desolder the indicator connections.
The horn is on the same positive feed as the indicators. Is their a particular place to make the connections???? I.E before or after the fuse box. I done it at its easiest point.
Unless anyone has any other ideas.
Mark
Az
PostPosted: 22:36 - 15 May 2013    Post subject: Reply with quote
Totally off subject, but i'm ordering this alarm system for my CBF125 (this friday i'm ordering it) and was wondering where you fitted the black alarm box thingy?
Thanks in advance, Az Smile
Mark 37
PostPosted: 23:09 - 15 May 2013    Post subject: Reply with quote
You have a PM.
Mark
Az
PostPosted: 23:34 - 15 May 2013    Post subject: Reply with quote
Mark 37 wrote:
You have a PM.
Mark
u also have a PM lol Thumbs Up
duzzer
PostPosted: 01:57 - 16 May 2013    Post subject: Reply with quote
i had a clifford car alarm wired to my old scooter a 2008 speedfight 100cc, was wired to LnR indicator and hight beem, the old bonet pin used for the under seat, proximity sensor with chip mode anyone within 10ft and it chip twice evey 10 sec but stay there 30 sec and Mad battery lasted 7 days stanby
i think its ur battery or somthing else is draining it
The last post was made 13 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 114.53 Kb
