Rieju Rs2 Matrix battery fault or something worse?
Danny09
PostPosted: 15:37 - 28 Apr 2013    Post subject: Rieju Rs2 Matrix battery fault or something worse? Reply with quote
Hey BCF,
I am Danny and even though I have been surfing this form for over a year now this is actually my first post, and I hope the lovely community can give me some advice.
Recently purchased a Rieju Rs2 50cc 2006 of a gentlemen who had initially bought it for himself but never ended up riding it and it was sat in his garage for about 3 weeks prior to me buying it.
Everything looked fine and it even started up electric start the 3rd time he tried but I notices lots of white smoke but I guess that's usual for these 2 strokes.
Long story short, 50 mile trip back home and tried to get it started using the electric start but it just wont start, you can hear it trying to and everything like the lights works fine but the engine isn't turning over no matter how hard I try (clutch in/ throttle over).
I am obviously presuming that the battery is flat and needs re charging (in the process of doing so) but could it also be a spark plug problem? Where could I get a replacement and does anyone know where the spark plug is in this model?
is the rust on the battery wires a reason for it not starting up?
https://i40.tinypic.com/2vaxxyf.jpg
How do you get the seat up on this model?
Could do with some advice.
Thanks, Dan
ALSO COULD ANYBODY RECOMMEND SOME GOOD OIL FOR THIS BIKE?
nightshaddow
PostPosted: 16:55 - 28 Apr 2013    Post subject: Reply with quote
to get the seat up you have to use your key in the pillion seat and there is a bolt that holds the rider seat inside there!
as for starting it shouldnt need the throttle wide open just a bit of choke and flick the starter (you probably flooded the carb)
the batterys on these are small and drain really quick, did you try bumping it?
spark plugs can be bought at any motorcycle shop or halfrouds and they are located on top of the cylinder head
hth Thumbs Up
Danny09
PostPosted: 17:12 - 28 Apr 2013    Post subject: Reply with quote
hth Thumbs Up
Thanks for the reply, do you own a rieju? What do you mean by flick the starter? And will be replacing the battery and spark plug very soon so will keep you updated.
Turkish
PostPosted: 18:23 - 28 Apr 2013    Post subject: Reply with quote
Finger on the button for ~0.5 seconds only. Just enough to get it to turn over a couple of times.
To bump start it; ignition 'ON', select 2nd gear, then with the clutch held in run like fuck with the bike and dump the clutch for an instant when up to jogging speed. It's important to bring the clutch back in when you feel the bike start unless you have experience mounting a speeding horse.
ZX-6R G2
CBR125R RW6
dolly3900
PostPosted: 13:31 - 29 Apr 2013    Post subject: Reply with quote
Hiya,
I have one of these (2003/53 plate) and have similar issues.
The battery is (as the Nightshaddow says), a pathtically small one and does not hold much of a charge, couple that with the fact that the charging circuit on these is nototiously weak, you have bike which, when ridden on full beam, will run fine and dandy, but does not really charge the battery after the inital drain of starting.
When starting (or attempting to), you'll find that the starter spins and turns over the engine apparnetly fine, but with that drain on the battery is enough to leave little or no charge to fire up the ignition circuit and so will not spark.
If the battery is charged externally (easy enough to do) all appears fine, but after a few starts (especially cold ones), it struggles.
As Turkish sugests, try a bump start and all should be OK (put the lights on dip or off first though, reduce any extra load on the battery and give the best chance of a decent spark)
Best sugestions.....
#1 Fit an external charge socket and plug it in to a trickle charger each night to make sure it is full in the morning (A good inteligent charger will do this with no risk to the battery condition).
#2 Ride with no lights to reduce load on the electrical circuit and to maximise the charge to the battery (Not recommended for safety reasons to you , the rider as this would increase the risk of SMIDSY).
#3 Upgrade the chargeing circuit (Bigger magneto from the 125, bit of a faff as it is not a direct swap).
#4 Accept it and get used to bumping it in the morning.
TBH I have gone for option #4 as I live on a hill and it makes no odds to me rolling down in the morning.
Hope this helps
Mike
Danny09
PostPosted: 17:07 - 29 Apr 2013    Post subject: Reply with quote
dolly3900 wrote:
Hiya,
Hope this helps
Mike
Thanks for the reply Mike, I actually just left the battery to charge over night and the bike starts first time now but new problem - the rear break pad activated the back lights but the front break leaver doesn't?
dolly3900
PostPosted: 20:55 - 29 Apr 2013    Post subject: Reply with quote
Front break light switch on lever probably stuck in.
In screw it, give it a quick blast with wd40 and free up the little plunger.
If it works, then eBay a new switch, only a few quid
dolly3900
PostPosted: 21:55 - 29 Apr 2013    Post subject: Reply with quote
Az
PostPosted: 02:28 - 30 Apr 2013    Post subject: Reply with quote
If the headlights or dashboard lights flicker/become dim when hitting the ignition button then its probably battery related
Try bump starting it, if it works then it could be your starter motor or your battery
If bump start doesn't work, then check for a spark.
And when u do attempt to start it does it make any loud squeaking noises? If so your starter motor may need replacing.
Or.. like someone else said from you opening your throttle while the bikes off it may be flooded which may explain the smoke (excess fuel burning off) and if this is the case then you need to get rid of that excess fuel.
And 2 strokes do smoke, but normally that smoke clears up after it's warmed up.
Good luck resolving your problem. Smile
Az
PostPosted: 02:32 - 30 Apr 2013    Post subject: Reply with quote
To remove the riders seat normally you take off the pillion seat/seat cowl and you'll see two bolts attached to the riders seat, unbolt those bolts and the seat will simply come off (on the bikes i've owned thats been the case anyway).
dolly3900
PostPosted: 10:44 - 30 Apr 2013    Post subject: Reply with quote
I've tried top attach the manual for the bike for you, but for some reason it's not letting me.
Inbox me and I'll send it to you.
Not 100% certain if it'll all be relavant to yours, but it'll be a good starting point for you.
BTW, if this kind of thing is frowned upon, the admin, please feel free to delete the post, Sorry.
Mike
The last post was made 13 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 73.27 Kb
