Making a bike stand with no stand?
DMCpro
PostPosted: 21:32 - 09 May 2013    Post subject: Making a bike stand with no stand? Reply with quote
I'm currently doing an engine swap proving difficult with no paddock stand and since the stand is attached to the engine it's being difficult any ideas for a makeshift stand? I've got plenty of planks of wood and bricks and buckets need something fairly stable for me to wriggle an engine into the frame with our it moving to much can't think it's a bit late for my brain BCF I'm calling you for help
Honda CB-1, TS125X
VW Golf Estate
Matt578
PostPosted: 21:46 - 09 May 2013    Post subject: Reply with quote
I put a scaffold tube under the frame before the pillion foot pegs. Put a stack of concrete blocks either side of the bike (Equal Heights), Then lift the bike and put the ends of the scaffold tube on the stacks of blocks. It is really sturdy and was the method i used when taking the engine out my Ninja. Sounds Bodge but does the job Thumbs Up
Your Daddy, Everyone's Friend.
Islander
PostPosted: 22:31 - 09 May 2013    Post subject: Reply with quote
You could also use slings to suspend the bike from a rafter or similar.
Walloper
PostPosted: 22:44 - 09 May 2013    Post subject: Reply with quote
This ^^^
End of Thread.
bladerunner
PostPosted: 23:15 - 09 May 2013    Post subject: Reply with quote
Make the said stand to hold the bike safe when not doing the engine fitting.....get a couple of mates over to help when your removing or installing the engine! That's what I do anyhow and I've got front and rear stands and a bike lift. Nothing beats extra hands and eyes when it comes to heavy lifting and lining up engine mounts and getting bolts in at the same time! Usually costs a couple of beers and some snacks Wink
Walloper
PostPosted: 23:23 - 09 May 2013    Post subject: Reply with quote
Word on the street is that you never 'get them' in you big fibber.
Just sayin'.
PostPosted: 23:44 - 09 May 2013    Post subject: Reply with quote
Put the footpegs on upside down.
Stick an axle stand under one. Push the bike over onto it, put the other stand under the other.
Support whichever end drops down with a car jack.
Here's my VFR750 on google earth putting my money where my mouth is:
https://i48.photobucket.com/albums/f216/stinkwheel/street1.png
stickybackbob
PostPosted: 23:47 - 09 May 2013    Post subject: Reply with quote
Lay the engine on its side (on towels, cushions or whatever. Lower the rolling chassis over the engine. Bolt up some of the mounts and then lift the lot back up.
Used this method on a GS1000 chop and it can be done with just one pair of hands Smile
Walloper
PostPosted: 23:52 - 09 May 2013    Post subject: Reply with quote
Thanks stinkers. I've got the coordinates for your hoose. The bears will be round with a van at the weekend. Thumbs Up
Very Happy
PostPosted: 00:19 - 10 May 2013    Post subject: Reply with quote
Very Happy
Good luck.
TheSmiler
PostPosted: 00:37 - 10 May 2013    Post subject: Reply with quote
Any Real Reason on why to put them upside down Question
Whenever I have to lift up the CG (Ok it is light) I just shove one under the right or where it would go and then the other by the sidestand. Push the bike to the right and push the other jack under the footrest after lifting up sidestand with my foot.
Never had any problems doing it that way.
Walloper
PostPosted: 07:14 - 10 May 2013    Post subject: Reply with quote
Front pegs are hinged to allow them to scrape on the ground and not upset the bike. Smaller bikes only have a solid bar running through so no need to turn.
TheSmiler
PostPosted: 17:13 - 10 May 2013    Post subject: Reply with quote
Ah makes a lot of sense, thanks for explaining that Thumbs Up
Sid_The_Sloth
PostPosted: 22:08 - 10 May 2013    Post subject: Reply with quote
When I had to lift my bandit the other day we used 2 Axle stands under the main bike frame. Pulled the weight over onto the side stand to get the first under then pushed it over onto the other side to lift up the stand side to put the second 1 under. Fairly easy to do with 1 extra pair of hands
Walloper
PostPosted: 22:26 - 10 May 2013    Post subject: Reply with quote
I've never had anyone help me lift bikes onto bricks, axle stands, paddock stands or trolley jacks. I have always managed on my own.
I'm a bit of a show off though. Cool
Matt578
PostPosted: 15:59 - 12 May 2013    Post subject: Reply with quote
Stinkwheel's Idea is a good un Thumbs Up
The last post was made 12 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 93.39 Kb
