Respraying my bike..
Eddie Hitler
PostPosted: 21:26 - 15 May 2013    Post subject: Respraying my bike.. Reply with quote
Tried the search but isn't working for me at the moment.
How easy would it be for a total novice like myself to respray a bike? I'm talking a simple 1 colour job, most probably black. I want a half decent finish. Simple as sand down, primer, halfords black spray can, then a varnish type layer on top?
Need some wisdom!
SQL
PostPosted: 21:30 - 15 May 2013    Post subject: Reply with quote
Pretty much as easy as that, dust coats and sand inbetween coats with wet 1200 paper.
Hardest thing will be getting weather.
Oh and flys :@
Nexus Icon
Black is one of the worst colours if you're unsure about the quality of your prep work. It shows up every blemish.
Rattle cans can give an acceptable finish but you really have to put in the work at the prep stage to stand a chance.
Greetings from Shitsville!
Eddie Hitler
PostPosted: 21:32 - 15 May 2013    Post subject: Reply with quote
What I would really want is red/white, but my confidence levels aren't at all great. When it comes to taping lines, does masking tape suffice? If black is that bad, I'm now more tempted with my more ambitious idea.
SQL
PostPosted: 21:34 - 15 May 2013    Post subject: Reply with quote
Black is a bitch Laughing
I did my car with a brush and tin of hammarite gloss came up like glass Laughing
SQL
PostPosted: 21:35 - 15 May 2013    Post subject: Reply with quote
Masking tape will be ok providing you dust coat it.
FireStorm-X
PostPosted: 21:36 - 15 May 2013    Post subject: Reply with quote
Hi there
I have in the past resprayed a few things Wink prep is the key word. The better the prep, better the finish.
But it is not as easy as it sounds Sad spray cans can be tricky things.
Full respray, Ford Orion, Ford Fiesta with proper spray booth and lots of prep work. Came out looking good Smile
Full Respray rust bucket, Ford Sierra in Hamarit blue from spray cans. Strangely it looked good lol, even after 2 years the rust never came back lol.
In the end practice on something first before touching your bike Wink
Lexmoto Street 125 (sold) - Kawasaki ZR7S
Eddie Hitler
Prep is king, I think I'll give it a shot. Thumbs Up
mysterious_rider
PostPosted: 21:39 - 15 May 2013    Post subject: Reply with quote
mine.
hycote satin black, then a ebay jobbie 2k clearcoat laqcuer.
It's easy, but practise the lacquer on something first!!!!!
For the tank decals, FFS don't remove them, you have to use a heat gun and cut all the paint layers off. Laughing Just sand them down.
Most of the time is prepwork.
It's not brilliant but it's good enough for me.
https://i270.photobucket.com/albums/jj88/mysterious_rider/new/IMGP4599.jpg
KAWASAKIIIII
SQL
PostPosted: 21:40 - 15 May 2013    Post subject: Reply with quote
The more time you spend prepping the better the finish, as I said after doing my car with a brush Laughing the prepI did before gave it a glass finish.
illuminateTHE...
PostPosted: 21:42 - 15 May 2013    Post subject: Reply with quote
Plastidip your motorcycle man... only prepping you will need doing is cleaning the surface of your motorcycle... equipment is fairly cheap, you could get a wagner gun for maybe £30 and paint for say £50 - £80.
plasti dip gtr
https://www.youtube.com/watch?v=0Jzi_JQMWH4
myths about plasti dip
https://www.youtube.com/watch?v=vvkq-qyY9aY
https://www.dipyourcar.com/forums/forumdisplay.php?14-Motorcycle-Dipping
https://i1277.photobucket.com/albums/y484/A_yam/IMG_8384_zpsa3de43fe.jpg
https://i1277.photobucket.com/albums/y484/A_yam/801c6f21_zps5b3d0562.jpg
https://i1277.photobucket.com/albums/y484/A_yam/20130224_134248_zpse8fd7e9e.jpg
Great thing about plastidip is that you can peal it off.
Theory: PASSED Module 1: PASSED Module 2: PASSED 12/2012!!!
yzf r125 [SOLD] sv650 [CURRENT]
i.p.phrealy
PostPosted: 22:39 - 15 May 2013    Post subject: Reply with quote
There's a bit in this show and tell thread about the difference between masking tape and edging tape, although I must warn you it contains a post from Tef...
https://www.bikechatforums.com/viewtopic.php?t=267339
PostPosted: 09:40 - 16 May 2013    Post subject: Reply with quote
If you're doing it in your garage using retail products then plan on having your bike off the road for a week, and then two more weeks of the slightest contact leaving marks in the lacquer before it fully cures.
If I were doing it again and just wanted a consistent block colour, I'd seriously consider vinyl wrap. Have a look at some how-tos. It looks fairly fiddly, but weigh that up versus coat after coat of sanding and spraying, and the existential horror of getting a run.
mysterious_rider
PostPosted: 10:01 - 16 May 2013    Post subject: Reply with quote
Trust me on this, I have a mate who's wrapped stuff and it takes forever, he said to wrap his car it took weeks, let alone you cant touch up repairs. Shocked
Far easier to do what I did, that satin base coat stuff is super forgiving. If it runs, you can literally dab it with a towel and then lightly spray over it again, and v'oila it's perfect.
It's just the 2k lacquer which is weird, really easy to use, but you have to get it close and lay it on quite thick. Took me about 6 hours of prep work to get it all keyed in etc. Then a couple of hours to get 6 coats on, then about 4 coats of lacquer. This was in 5deg a couple of days before we had the snow. Laughing Laughing Laughing Had to leave it in a shed with a fan heater. I reckon had I waited till the summer, it would have come out even better. Thumbs Up
KAWASAKIIIII
pits
PostPosted: 10:29 - 16 May 2013    Post subject: Reply with quote
Plastidip it, easier than painting and if you get it wrong you can just peel it back off, very little prep involved in apply it as well.
James83
PostPosted: 11:24 - 16 May 2013    Post subject: Reply with quote
I've been thinking about doing a plati-dip job on my bike. Anyone know how many cans you need to do a complete bike?
maxp
PostPosted: 14:43 - 16 May 2013    Post subject: Reply with quote
Worth a read
https://cbrforum.com/forum/how-mechanical-40/how-paint-bike-without-compressor-gun-**not-considered-rattle-can-job**-115135/
When it comes to clear coating its worth spending the extra cash on a 2 part clear, especially if its something other than a black basecoat. Make sure you have very good ventilation if you go this route though.
Also, if you are going to put any decals on the tank, they will need to be lacquered over, otherwise the petrol will have them un-sticking is no time.
PostPosted: 15:03 - 16 May 2013    Post subject: Reply with quote
pits wrote:
Plastidip it
They do it in glow in the dark. Shocked Thinking Very Happy
illuminateTHE...
PostPosted: 17:40 - 16 May 2013    Post subject: Reply with quote
I wouldn't use cans on big surfaces..
James83
PostPosted: 22:55 - 16 May 2013    Post subject: Reply with quote
Why not?
FireStorm-X
PostPosted: 23:07 - 16 May 2013    Post subject: Reply with quote
Me and one of the chaps at work are going to go 50/50 on a spray kit and 10lt of plast paint and see what it is like in a few months time (next 5 week pay day) should be around £150 each. Looks interesting lol. Worth a try just to see how it comes out always wanted to try a matt car or bike before Smile
Marmaduke
PostPosted: 23:33 - 16 May 2013    Post subject: Reply with quote
Cellulose is nice and forgiving! Resprayed the K75 with it (not from cans though), had no issues with running, just a few fisheyes because of silicone glue being used nearby.
Don't have to worry about dropping dead with cellulose either.
Current: '03 Tuono RSV1000, '05 Van Van, '91 Zephyr 550
Previous: Multistrada 620,Bandit 600,Kawsaki ER-5, BMW K-75
illuminateTHE...
PostPosted: 07:30 - 17 May 2013    Post subject: Reply with quote
with a gun you can get a consistent amount spray on the fairing, you also can spray a wider area.
James83
PostPosted: 08:02 - 17 May 2013    Post subject: Reply with quote
Fair point, but the cost of buying all the parts vs buying say 2 cans of paint is more than triple the cost.
The question is, is 2 cans enough to cover all the panels on a sports bike?
mudcow007
PostPosted: 08:09 - 17 May 2013    Post subject: Reply with quote
im looking at spray my tank an plastic bits at the moment as well, we have a spray booth (used to lacquer oak furniture) but the sprayers here have never sprayed paint
i have been quoted £120 to have my tank an stuff done, but i kinda of want to do it my self
ive used rattle cans on bits n bobs in the past but nothing as big as a fuel tank
i think i will have a go when i get paid
The last post was made 12 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 128.83 Kb
