ER-6F Clocks permanent live
wots
PostPosted: 12:28 - 18 May 2013    Post subject: ER-6F Clocks permanent live Reply with quote
Spent ages trying to figure this out and just cracked it. But need further advice. I was losing the time and trip on my bike after ignition switch off. Tried new clocks couldn't find anything. Traced the permanent live back to the Ecu fuse, which is a permanent live. Looked underneath the fuse box and the wire has been spliced and runs into the alarm. Obviously that's the immobiliser. I can't believe it's been like this from day one (dealer fit alarm).
Only way I can think to deal with this, without losing immobiliser is to run a feed to the clocks with a diode inline to prevent it running back and powering up the ECU when it's immobilised.
I'm going to try and find another circuit to immobilise too.
wots
PostPosted: 12:35 - 18 May 2013    Post subject: Reply with quote
Just tested by running a feed and bypassing. It worked. Can't believe a dealer would immobilise a circuit needing a permanent live feed. Will look at the diagram and see if there is another circuit which can be safely immobilised.
Timmeh
PostPosted: 12:40 - 18 May 2013    Post subject: Reply with quote
as it's a low-current drain you could just wire it in directly to your battery. I seriously doubt the clock will take any more or less than the alarm will on standby.
wots
PostPosted: 20:15 - 18 May 2013    Post subject: Reply with quote
Well I don't know who fitted that alarm, but I'm pretty sure there is a more appropriate circuit to immobilise than the bikes permanent live. That means that the clocks didn't have power and crucially, the ECU isn't therefore allowed to retain data it's learned, as it's reset each time. Anyway all good now.
The last post was made 13 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 41.29 Kb
