| Clutchy |
 Clutchy World Chat Champion
 Posted: 10:29 - 05 Jun 2013 Post subject: WTF is this tool/random bits for? |
Well I got my sv650, and I'm out to do a service on it, except I haven't got the Suzuki special tool to remove the oil filter, is there any other way to do this? Other than strap wrench/pump pliers.
Also found these in the Suzuki tool section in my bike, what are they and what are the for????????
https://i.imgur.com/vrpzX0c.jpg ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| Shinigami |
 Shinigami World Chat Champion
 Posted: 10:31 - 05 Jun 2013 Post subject: |
really??  ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
"Once you realize what a joke everything is, being the Comedian is the only thing that makes sense. |
| lihp |
 lihp World Chat Champion
 Posted: 10:32 - 05 Jun 2013 Post subject: |
Circlip and circlip pliers. Keep hold of the pliers they are handy.
If the alloy disc is a bike part, I expect it's from inside the forks going by the diameter and finish.
EDIT: Can't find anything on the parts list that looks like that disc in the forks, nor a circlip like that. ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 10:33 - 05 Jun 2013 Post subject: |
wasn't a standard item in my kit, probably a previous owner tool that he had tucked away in bike and now wonders where the hell he has put his circlip pliers!  ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| Clutchy |
Makes sense, considering when I was playing with them thats what I did, ahweellllll.
| Islander |
 Islander World Chat Champion
 Posted: 10:42 - 05 Jun 2013 Post subject: |
D'oh!  |
| yen_powell |
| Raffles |
 Raffles World Chat Champion
| STONEY! |
 STONEY! Brolly Dolly
| Clutchy |
| Supermoto_Fan |
 Supermoto_Fan World Chat Champion
| G |
 G The Voice of Reason
| Clutchy |
 Posted: 16:31 - 07 Jun 2013 Post subject: |
All serviced and sorted now, yeah front spark plug was horrible to get out, not just because of clearance but it looked as if no one has done the front one for ages (posted pics etc in what have you done to your bike today thread) was rusty as fuck.
Cleaned up the old oil filter to remove any oil around it, put on some very grippy gloves and twisted it off by hand, even after 5 turns it wasn't leaking oil so used the same method to do it back up, I'm sure it will be fine.  ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Supermoto_Fan |
| Clutchy |
 Posted: 18:36 - 07 Jun 2013 Post subject: |
Will do
Also while we are here...
When I twist the throttle all the way back it stays on, or is very slow to return, now I've traced the cable back into the bodies? and it all looks swell, not snagged on anything, however it has after market heated grips which could be the culprit, what do you think? Is this a common problem?
On a side note, I know its dangerous but I'm not in a massive rush to get it fixed as I rekon it could be where the bike has been sat for half a year but will it fail an MOT on this? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| Supermoto_Fan |
 Posted: 18:54 - 07 Jun 2013 Post subject: |
| Clutchy wrote: | Will do
On a side note, I know its dangerous but I'm not in a massive rush to get it fixed as I rekon it could be where the bike has been sat for half a year but will it fail an MOT on this? |
Yeah it'll fail for sure.
Odds-on it's either the grips rubbing on the bar-end or throttle tube gummed up with road dirt. Loosen the housing bolts to allow the tube to slide off slightly, if it becomes loose it's the grips rubbing, if not it needs cleaning out. De-gunge the tube and the bar and re-assemble dry - don't apply lube or wd40 etc or they will gum up again.
5 minutes work  ____________________ a.k.a 'Geri'
| Clutchy |
The last post was made 12 years, 293 days ago. Instead of replying here, would creating a new thread be more useful? |
