| -Matt- |
 -Matt- World Chat Champion
 Posted: 21:31 - 11 Jun 2013 Post subject: 1982 suzuki sb200 gearbox oil |
Hi all
Got an old suzuki sb200 2stroke im restoring. The old 1982 manual says to use 20w50 oil for the gearbox. Seems quite an old uncommon oil now, would i be best off using another modern oil perhaps, or sticking with the original spec?
Cheers  |
| N cee thirty |
 N cee thirty Banned
| cb1rocket |
 cb1rocket World Chat Champion
| -Matt- |
 Posted: 00:55 - 12 Jun 2013 Post subject: |
Oops double posted the thread
Okay thanks guys, they both also specify 20 50 originally do they? Did you notice any changes when you switched if you recall?
Thanks  |
| DMCpro |
 DMCpro Traffic Copper
| -Matt- |
 Posted: 03:40 - 12 Jun 2013 Post subject: |
Isnt atf for automatic gearboxs only  |
| DMCpro |
| stickybackbob |
 stickybackbob Trackday Trickster
 Posted: 11:06 - 12 Jun 2013 Post subject: |
There's a world of difference in viscosity between ATF and 20/50. ATF is as thin as fork oil whereas 20/50 is like treacle. Takes ages to do an oil change using the 20/50 unless you warm it up a bit.
Saying that, the ex-mrs used to have an SB200 and we never found a problem using bog standard, cheap oil.
A gearbox isn't the same as something like a four stroke engine with all it's narrow oil ways and need for pressure. On a two stroke, the workings sit in a bath of oil and splash it about a bit.
In short, oil is oil for a gearbox. The only worry is any detergents or friction reduction agents (not usually found in cheap oils) that can have an effect on the wet clutch. If I were you,I'd be going for the cheapest oil I could find  |
| -Matt- |
 Posted: 14:16 - 12 Jun 2013 Post subject: |
Thanks for the advice guys  |
The last post was made 13 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
