1982 suzuki sb200 gearbox oil
-Matt-
PostPosted: 21:31 - 11 Jun 2013    Post subject: 1982 suzuki sb200 gearbox oil Reply with quote
Hi all
Got an old suzuki sb200 2stroke im restoring. The old 1982 manual says to use 20w50 oil for the gearbox. Seems quite an old uncommon oil now, would i be best off using another modern oil perhaps, or sticking with the original spec?
Cheers Smile
cb1rocket
PostPosted: 00:46 - 12 Jun 2013    Post subject: Reply with quote
Yes 10w 40 on my GP100
-Matt-
PostPosted: 00:55 - 12 Jun 2013    Post subject: Reply with quote
Oops double posted the thread Rolling Eyes
Okay thanks guys, they both also specify 20 50 originally do they? Did you notice any changes when you switched if you recall?
Thanks Thumbs Up
DMCpro
PostPosted: 01:42 - 12 Jun 2013    Post subject: Reply with quote
ATF fluid is normally used in older machines for gear oil.
Honda CB-1, TS125X
VW Golf Estate
-Matt-
PostPosted: 03:40 - 12 Jun 2013    Post subject: Reply with quote
Isnt atf for automatic gearboxs only Thinking
DMCpro
PostPosted: 08:27 - 12 Jun 2013    Post subject: Reply with quote
It's been suggested that it has certain detergents in that will clean and keep the inside of the engine free from sludge etc.
I put ATF in my bikes and my dads BSA Bantom and his Suzuki gt185
Honda CB-1, TS125X
VW Golf Estate
stickybackbob
PostPosted: 11:06 - 12 Jun 2013    Post subject: Reply with quote
There's a world of difference in viscosity between ATF and 20/50. ATF is as thin as fork oil whereas 20/50 is like treacle. Takes ages to do an oil change using the 20/50 unless you warm it up a bit.
Saying that, the ex-mrs used to have an SB200 and we never found a problem using bog standard, cheap oil.
A gearbox isn't the same as something like a four stroke engine with all it's narrow oil ways and need for pressure. On a two stroke, the workings sit in a bath of oil and splash it about a bit.
In short, oil is oil for a gearbox. The only worry is any detergents or friction reduction agents (not usually found in cheap oils) that can have an effect on the wet clutch. If I were you,I'd be going for the cheapest oil I could find Smile
-Matt-
PostPosted: 14:16 - 12 Jun 2013    Post subject: Reply with quote
Thanks for the advice guys Thumbs Up
The last post was made 13 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 59.32 Kb
