R1 Temperature is 108 degrees...
PostPosted: 14:25 - 04 Jul 2013    Post subject: R1 Temperature is 108 degrees... Reply with quote
Just before I head off to Spain, the R1 apparently gets above 100 degrees in the current weather which is ~21 degrees.
I just want to confirm that is not too bad.
I've seen over 100 on the CBR and 112-115 on the Daytona once in traffic... but I haven't ever committed to a 2000+ mile trip to Spain on a bike I've not owned for long Laughing
PostPosted: 14:29 - 04 Jul 2013    Post subject: Reply with quote
Can't help you there. It's fucking rediculously hot. Old people drop dead in that kind of heat.
Take a hydration backpack and make sure you drink it all by the end of the day.
Sunscreen on any exposed skin.
PostPosted: 14:30 - 04 Jul 2013    Post subject: Reply with quote
Laughing Edited title
Conzar
Fock it and the temperature!
Buy alot of mesh clothing
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
iMark
PostPosted: 14:33 - 04 Jul 2013    Post subject: Reply with quote
Have you flushed the coolant to make sure the mixture ratio is correct?
3:2 Mixture of AF & Water is the optimal Razz
60% AF : 40% Water (some people misread ratios)
K8 GSXR 1000
It is around 50/50. Thumbs Up
iMark
PostPosted: 14:36 - 04 Jul 2013    Post subject: Reply with quote
Shouldn't make much of a difference at 50/50 , Stop hooning around in town and that'll help Rolling Eyes
K8 GSXR 1000
Speed
PostPosted: 14:37 - 04 Jul 2013    Post subject: Reply with quote
I've heard that the R1 does run incredibly hot and it is common so i doubt there is anything to worry about Thumbs Up
Current: Suzuki GSXR 750 Y
Former: Kawasaki ZX6R Ninja F3
PostPosted: 14:38 - 04 Jul 2013    Post subject: Reply with quote
This was apparently sat at the lights, so expect temp to go up.
I suppose its normal, I'm just worrying big time Laughing
iMark
PostPosted: 14:41 - 04 Jul 2013    Post subject: Reply with quote
Well, "normal" running temperature is between 80-120 on most vehicles Razz
Once it gets above something like 115 the fans will kick in...
Have a look in the manual and see what temperature the thermostat opens at.. some only just start opening up at like 98 degree's which is just the start of the coolant flowing around, not the fans kicking in to help cool it.
K8 GSXR 1000
Timmeh
PostPosted: 14:44 - 04 Jul 2013    Post subject: Reply with quote
I once saw al's R6 get to 116 after a blat to Boxy on a roasting august sunday.
Maybe you'll just have to stop and have regular breaks? You should be doing anyway to keep your fluids up.
Ichy
PostPosted: 14:45 - 04 Jul 2013    Post subject: Reply with quote
Personally I'd go for a proper coolant in high temperatures, something like supercool or engine ice. If you do use off the shelf stuff try to mix it with distilled water.
Temperature wise I'd expect it to be running at just over 100 when stuck in traffic and around 70-80 when being ridden. I'd look at flushing the system out as a minimum.
PostPosted: 14:55 - 04 Jul 2013    Post subject: Reply with quote
I'll see if I can get some high temp specific stuff.
It was flushed out last week, completely fresh stuff in there now.
PostPosted: 15:04 - 04 Jul 2013    Post subject: Reply with quote
My bad.
I thought the 108 was referring to the air temperature you werre expecting in Spain in farenheit, not the engine temperature in celcius.
Stowelly
PostPosted: 15:05 - 04 Jul 2013    Post subject: Reply with quote
mines been getting to 94 in not too bad traffic
my SRAD ran a lot hotter, the fan didnt even kick in till 120 which isapparently normal
PostPosted: 15:06 - 04 Jul 2013    Post subject: Reply with quote
Nope, my bad, I worded it like a turd. Laughing
PostPosted: 15:08 - 04 Jul 2013    Post subject: Reply with quote
You need air conditioning. Thumbs Up
Bendy
Mrs Sensible
PostPosted: 15:09 - 04 Jul 2013    Post subject: Reply with quote
My gsxr regularly reaches 107, 108 in town while sitting in the 70s when out on the open roads. I've never thought to be concerned by it.
Quote Me Happy
PostPosted: 15:10 - 04 Jul 2013    Post subject: Reply with quote
And consider dropping an electrolyte tablet in the drink pouch, being hunched up on a bike with cramp is no fun.
PostPosted: 15:14 - 04 Jul 2013    Post subject: Reply with quote
Seems I am just worrying a little too much Thumbs Up
barrkel
PostPosted: 15:24 - 04 Jul 2013    Post subject: Reply with quote
Probably.
My VFR was around 85 when moving, 100-110 in traffic, in 30+ degree air temperature.
Northern Spain was cooler than Seville / Cordoba etc. in the south.
Fizzer Thou
PostPosted: 16:33 - 04 Jul 2013    Post subject: Reply with quote
I regularly noticed 105c when stuck in traffic in Monte Carlo a few years ago on the R1.The fan would then kick in and do its bit to drag air through the radiator.
Before I went on the ride to Tuscanny I flushed the coolant system and mixed it 70% distilled water and 30% quality anti-freeze.Water is a far better liquid at moving heat away from hotspots like cylinder heads,hence the higher ratio of distilled water.The anti-corrosion inhibitors in anti-freeze is what is needed with alloy engines.If this was not the case you could run 100% distilled water.
Running a 50/50 mix is hardly necessary as Spain is never likely to freeze down to -30c.Neither is this country for that matter.
I once heard of someone who knew no better and ran his bike engine on 100% anti-freeze Rolling Eyes
Always have a 'Plan B'
PostPosted: 17:43 - 04 Jul 2013    Post subject: Reply with quote
I'll grab a bottle of it and do a 70/30 split Thumbs Up
Walloper
PostPosted: 22:13 - 04 Jul 2013    Post subject: Reply with quote
Most anti-freeze 'if' it has inhibitor added will only have about 4% which means you get the minimum recommended 2% inhibitor when you dilute to 50:50 (1/2 water 1/2 antifreeze)
Most manufacturers will recommend 50:50 mix (or use their approved coolant)
Ethylene Glycol has a different heat capacity than pure water so an engine can safely work at higher temperatures than the boiling point of pure water at sea-level (100°C) if ethylene glycol is used.
The engine won't melt or come to any harm at above 100°C the coolant only need NOT boil. If it boils then it makes pockets of gas. Gas will not cool the engine and you get 'Hot Spots' which can result in cracking.
I would not phaph with a mixing type. Buy an extended life coolant which has inhibitor and antifreeze Pre-mixed. No doubt and less waste.
Defo flush before new coolant.
brains_t
PostPosted: 22:16 - 04 Jul 2013    Post subject: Reply with quote
Do you have a radiator cover? If so may be an idea to remove it for the trip to Spain as they tend to make engine run hotter
The last post was made 13 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.38 - MySQL Queries: 13 - Page Size: 123.53 Kb
