Why do i get flashed
illuminateTHE... This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
johnsmith222
PostPosted: 03:35 - 19 Jul 2013    Post subject: Reply with quote
because the beam pattern is shit and is dazzling people.
Surely if colour had anything to do with it then riding around on high beam with stock lighting should be no problem.
Fisty
PostPosted: 03:52 - 19 Jul 2013    Post subject: Reply with quote
If you can't work out why, you really must be stupid.
Fatter and faster than Fret
illuminateTHE...
PostPosted: 04:01 - 19 Jul 2013    Post subject: Reply with quote
Fisty wrote:
If you cant work out why you really must be stupid.
It does not dazzle anyone thats the problem. They must have dodgy lights which malfunction creating the flash.
Theory: PASSED Module 1: PASSED Module 2: PASSED 12/2012!!!
yzf r125 [SOLD] sv650 [CURRENT]
Fisty
PostPosted: 04:07 - 19 Jul 2013    Post subject: Reply with quote
I rest my case.
https://i302.photobucket.com/albums/nn82/mr_fisty/1373476141679_zps350be60f.png
trevor saxe-coburg-gotha
PostPosted: 04:12 - 19 Jul 2013    Post subject: Reply with quote
What planet are you smoking meth on??
Last edited by trevor saxe-coburg-gotha on 04:53 - 20 Jul 2013; edited 1 time in total
PostPosted: 04:35 - 19 Jul 2013    Post subject: Reply with quote
lets spell it out in simple terms.....................
HID lights in a housing with a halogen reflector = fail.
Triumph Trophy Launch Edition
uberkron
PostPosted: 05:29 - 19 Jul 2013    Post subject: Reply with quote
It seems odd that after you fitted a dodgy hid conversion kit, peoples headlight switches started malfunctioning.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
Knightsy
PostPosted: 05:31 - 19 Jul 2013    Post subject: Reply with quote
I'll just leave it here.
https://www.youtube.com/watch?v=-p9gQvzOLog
09' Versys 650 | 07' FJR1300A
janner_10
PostPosted: 05:57 - 19 Jul 2013    Post subject: Reply with quote
https://1.bp.blogspot.com/-ymNre4gQbT4/ULvjgL4AfOI/AAAAAAAADKo/9GJeCViq5Ww/s1600/Facepalm_9a08b9_59080.jpg
-Matt-
PostPosted: 06:35 - 19 Jul 2013    Post subject: Reply with quote
Youre blinding people. 60% is a hell of a lot. Get them fitted suitably or take them out mate itll cause an accident sooner or later most likely someone hitting you whilst being dazzled. Get xenon bulbs if you want a brighter/white look.
anthony_r6
PostPosted: 06:38 - 19 Jul 2013    Post subject: Reply with quote
I recognise this as the Trolling comment it is, but please, for your own good, stop being a cock.
Wonko The Sane
PostPosted: 06:43 - 19 Jul 2013    Post subject: Reply with quote
HID lights were an option on my car when I bought it,
I asked if it was possible to fit them later, the answer was no.
The reason is, the chassis needs altering for a different suspension set up (not entirely convinced here) because the light housing needs to self level in response to the car pitching under acceleration or just general being bumped around by the crap roads we have.
Without this, you're just making it look like you're riding round on full beam.
Personally, HID's should be banned, fed up of being blinded by badly fitted ones and when being tailgated by HID fitted cars (both on the bike and in the car) I can't see a thing due to the shadow they cast.
wots
PostPosted: 06:45 - 19 Jul 2013    Post subject: Reply with quote
I had an Astra estate, P Reg, it had appalling lights. So I thought I'd try HID's. They are reflector headlights, they lasted 2 hours before I removed them. When I realised how much they dazzled everyone. The light is no longer focused, it was dangerous.
My Signum, has Projector headlights, they work perfectly, but I took them out for my MOT test, replaced with Night Breaker road legal bulbs. These are much better, legal and safer for other road users. Put a nightbreaker bulb in (or two depending on bike).
EDIT: These (obviously get correct fitment)
https://www.amazon.co.uk/Osram-64193NBP-Night-Breaker-Headlight/dp/B003Y7FKTC/ref=sr_1_2?ie=UTF8&qid=1374216439&sr=8-2&keywords=nightbreaker
fox
PostPosted: 07:46 - 19 Jul 2013    Post subject: Reply with quote
I don't think HIDs are dangerous at all if used correctly.
I have noticed an immediate difference in cars noticing me, going from my previous bike which had them fitted to my current bike which doesn't. Both have projectors as standard.
If set up correctly, I believe they can be a life saver. Anything that makes you more visible to other road users has got to be a good thing.
That said, it would be foolhardy to continue using them in a standard reflector unit. As others have mentioned, the beam pattern ends up really messed up, which blinds other road users.
Try some Philips X-tremes if you want brighter bulbs Thumbs Up
Sold: 2003 satin black Yamaha R6
Current rides: 2006 blue Triumph Sprint ST 1050, 2003 Yamaha WR450F
Timmeh
PostPosted: 08:39 - 19 Jul 2013    Post subject: Reply with quote
The H4 lamp in my TZR was absolute shit, especially as it spends most of its life riding down an unlight single stretch of tarmac that barely resembles a road, which is my daily commute. At night it can be lethal as there's a lot of wildlife to avoid. It also never lasted more than a month or two thanks to vibration.
Whilst it still has the standard reflector, I bought a HID kit that has the proper shroud round the front to stop the light going upwards, and I also got a 5000K normal-white rather than a gay blue one. Dip and Hi-beam work perfectly and there is a considerable difference between the two.
The beam pattern isn't too dissimilar than a halogen and passed the MOT with no problems.
So it can be done, you just have to use a bit of savvy, and not use the cheap shit kits.
Doovy
PostPosted: 09:04 - 19 Jul 2013    Post subject: Reply with quote
Either remove them or angle them downwards further so they are not in people's eyes.
I've had 6K HID system on my Hornet for about 2 years now and haven't been flashed once for it... passes my MOTs with it too.
goto10
PostPosted: 10:37 - 19 Jul 2013    Post subject: Re: Why do i get flashed Reply with quote
I've noticed ever since I've been ridding with HID lights i get flashed by say around about 60% of vehicles i pass.
My HID lights are not so bright that they turn light blue. I personally think my lights can't dazzle incoming motorist. So why flash?
Because they think you're awesome.
Entertwainer
PostPosted: 10:51 - 19 Jul 2013    Post subject: Reply with quote
oohhhhhh a meme response thread!
i'll add some GIF action....
https://i.imgur.com/f6due.gif
angryjonny
PostPosted: 11:00 - 19 Jul 2013    Post subject: Re: Why do i get flashed Reply with quote
It's because you're literally illuminating their minds.
Only kidding. It's because your rucksack is unzipped.
reed
PostPosted: 11:15 - 19 Jul 2013    Post subject: Reply with quote
As I have said in other threads started by you, your opinion and stories are completely irrelevant due to you riding a YZF 125.
Gay Boy with gay bike and gay light = Illuminatemydick.
(I had a HID kit but mine was strictly heterosexual) Twisted Evil
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
mysterious_rider
PostPosted: 11:30 - 19 Jul 2013    Post subject: Reply with quote
Lower your headlight aim mate. I fitted a HID without a high beam, blinded everyone, then I bought one with a dipped beam option, everyones happy.
KAWASAKIIIII
Doovy
PostPosted: 11:31 - 19 Jul 2013    Post subject: Reply with quote
That's a point. Mine has dipped and high beam settings too.
Lord Percy
PostPosted: 11:34 - 19 Jul 2013    Post subject: Reply with quote
OP, I must admit this is a crazy-dumb post. I don't even know what you're trying to achieve by discussing it with us.
"I have bright lights, why are drivers flashing me to tell me my lights are too bright. I have bright lights. My lights aren't that bright! Wait Wha-? Thinking"
The last post was made 12 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 131.34 Kb
