Let us talk Nitrous Oxide
Ariel Badger
PostPosted: 20:56 - 23 Jul 2013    Post subject: Let us talk Nitrous Oxide Reply with quote
I am thinking of running NOX on a methanol fueled carbed bike. What do I need to know?
Clutchy
PostPosted: 22:59 - 23 Jul 2013    Post subject: Reply with quote
Thread has potential... Smile
Frost
PostPosted: 23:57 - 23 Jul 2013    Post subject: Reply with quote
Nitromethane not an option?
PostPosted: 02:35 - 24 Jul 2013    Post subject: Reply with quote
_Iain_ wrote:
Perhaps worth contacting wizards of nos themselves & seeing what they've got to say about it all?
If there's one thing that Trevor is good for - it's saying stuff about it all. Be sure to ask him about the yank stuff - that's gotta be good for an hour's ear-bending.
Clever guy but will deaden your brain trying make you understand just how clever.
SteveZZR
PostPosted: 09:23 - 24 Jul 2013    Post subject: Reply with quote
That stuff is fooking lethal but difficult to get going sometimes.
Had the bright idea a good few years back to fill a Zippo with it but the spark wasn't hot enough so has to add petrol to it. Nice big green/grey flames. Set the cotton underneath on fire in the end!
Can imagine a bike running it would be mental
UnknownStuntm...
PostPosted: 09:26 - 24 Jul 2013    Post subject: Reply with quote
What CC? if it's less than a 500 you might struggle to get small enough jets, but I reckon the best thing to do is contact Wizards of NOS or whomever they are...
I had a similar idea to convert a chainsaw engine a while back, but I couldn't find a small enough jet to do the work.
Oh, and KNOW where your fire extinguishers are, and KNOW what a fire 'without flames' looks like.
ssray
PostPosted: 09:34 - 24 Jul 2013    Post subject: Reply with quote
Here you go https://www.nitrous.info/
stevo as b4
PostPosted: 11:36 - 24 Jul 2013    Post subject: Reply with quote
Make sure you don't drive over your crankshaft though! Laughing
mudcow007
PostPosted: 12:05 - 24 Jul 2013    Post subject: Reply with quote
nitrous oxide....you having a laugh?
see what i did there
PostPosted: 12:14 - 24 Jul 2013    Post subject: Reply with quote
Will it work well through a wide open bellmouth or would it be better having some sort of airbox?
Or of course, forced induction.
SteveZZR
PostPosted: 19:52 - 24 Jul 2013    Post subject: Reply with quote
Miff on ZZR-International has a ZZR 600 E running Nitrous - ram air is basically a poor mans Turbo, that count as forced induction?
Worth noting he has a custom CNC lock-up clutch in the works as the stock one slips like mad under the force of the nitrous
Ariel Badger
PostPosted: 20:20 - 24 Jul 2013    Post subject: Reply with quote
Thanks people, it is an option I am looking to fit on my Jawa powered sprint bike. 500cc single with 15:1 CR.
Robby
Dirty Old Man
PostPosted: 20:35 - 24 Jul 2013    Post subject: Reply with quote
On that CR, I assume you're running close to hydraulic locking the engine as it is. Add in another shot of methanol to go with the gas and you're going to have a lot of fluid in the cylinder.
*Note for children. Methanol has a very high octane rating, but a very low energy density. This means that it is very good as resisting knock and can run at a high compression ratio, but you need to squirt in a lot more of it. This mean hydraulic lock is a worry, because you squirt a lot of fluid into a much smaller combustion chamber.
Ariel Badger
PostPosted: 20:42 - 24 Jul 2013    Post subject: Reply with quote
We over jet with methanol to keep the motor from cooking a piston, running dope rich does not have the same consequences as petrol so it will not get boggy. This bike has a 800 jet and I imagine it will do about 4 mpg.
PostPosted: 21:21 - 24 Jul 2013    Post subject: Reply with quote
Methanol stoichometric ratio is 6.4:1 compared to 14.7:1 for petrol. Burt munro reportedly melted a few engines one year because he didn't understand this.
15:1 is a helluva CR to be adding nitrous though. you got a bronze skull in that puppy?
Ariel Badger
PostPosted: 22:00 - 24 Jul 2013    Post subject: Reply with quote
You think it could blow the head off Pete? I will build provision into the frame and engine plates to clamp it on.
I am used to running on dope, it is NO2 that I am clueless with!
PostPosted: 23:21 - 24 Jul 2013    Post subject: Reply with quote
Main thing to remember is that upping the oxygen content increases the rate of burn a lot, effectively advancing the timing. So not only do you get a much bigger bang, it also comes in too early. Cylinder pressures skyrocket which is why you don't really want it activated until you're well up the rev range and with almost full throttle (because elevating the cylinder pressures at low revs increases the duration of that huge strain on the mechanical components) There's little point applying nitrous if the throttle is part-open - you might as well just use more throttle and save the gas for when there's no more throttle to add.
Can't help you at all with using it alongside dope Wali. What little I know is pretty-much contained above.
Skulls are fitted to stop the ally of the head melting around the valve seats, and since the seats are formed into the skull, there's no chance of a seat falling out.
Shaft
PostPosted: 07:45 - 25 Jul 2013    Post subject: Reply with quote
Is the engine up to it?
They blow up for a hobby in the state of tune speedway riders run them in, so you have to ask yourself if it can take much more.
Having said that, you aren't limited to non exotic materials like speedway is, so I guess you could chuck some titanium in there.
The last post was made 13 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.01 - MySQL Queries: 13 - Page Size: 104.17 Kb
