Cagiva Mito 125 1991 no spark!!!!
Gareth
PostPosted: 20:46 - 11 Aug 2013    Post subject: Cagiva Mito 125 1991 no spark!!!! Reply with quote
Hi guys well where to start..... I had a water pump go, the cog snapped. Replaced the cog and gasket. As i was doing this id did not know how to get to the plastic cog so i was trying to take the alternator nut off the but was on real tight could not get it off. I then put a screw driver inside the through to lock alternator off as i did this some metal or something came loose not sure what. Could this be causing no spark. any suggestions guy would really appreciate this. The bike has been sat a few months as well the bike did start before.
Regards
Gareth
bikenut
PostPosted: 11:38 - 12 Aug 2013    Post subject: Reply with quote
hi gareth,
pic pics and more pics.................
Clutchy
PostPosted: 11:58 - 12 Aug 2013    Post subject: Reply with quote
Flat battery?
nathan k
PostPosted: 12:04 - 12 Aug 2013    Post subject: Reply with quote
You've probably broken the stator, take the wheel you locked in place off (might need a flywheel puller) and check for damage.
Gareth
PostPosted: 22:56 - 14 Aug 2013    Post subject: Cagiva no spark Reply with quote
Thanks very much for the reply. I have had the battery charged and is brand new. I have tried to get then nut off the alternator but is sized on and wont budge. I tried to stop the engine from turning over with a screw driver through a hole in the alternator but snapped the screw driver. Now there is a noise as though metal or something has snapped off not sure. What is the best way to lock engine off and get this nut off as have tried almost everything i can think of.
Regards
Gareth
bikenut
PostPosted: 14:44 - 15 Aug 2013    Post subject: Reply with quote
hi gareth,
could it be a left hand thread ( yes they do exist ) perhaps.....pic pic and pic please.............
good fitting socket and long ish bar and a wooden mallet.............
dedicated tool made to hold the flywheel perhaps..............
if not an auto, then back brake and gears..............
pic pic and some pics at least........will help.
Captain Liberious
PostPosted: 14:58 - 15 Aug 2013    Post subject: Reply with quote
you can lock the engine by sticking a good bit of nylon rope down into the cylinder
A squid eating dough in a polyethelene bag is fast and bulbous, got me?
The last post was made 13 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 50.93 Kb
