Scotoiler, worth fitting?
Wonko The Sane
PostPosted: 23:21 - 15 Aug 2013    Post subject: Scotoiler, worth fitting? Reply with quote
Considering fitting a mini scottoiler to the ZZR so I don't have to worry about keeping on top of lubing the chain.
The millage I do I'd need to top it up once a month, if that.
Is it worth it?
is it worth the hassle of fitting it?
clancy
PostPosted: 23:38 - 15 Aug 2013    Post subject: Reply with quote
No, definitely not if you only have to do it once a month
Squirt some oil on every now Abd then, time And money saved Thumbs Up
KLX 300r
Radis
PostPosted: 04:43 - 16 Aug 2013    Post subject: Reply with quote
I have found they make a big fucking mess. I won't be fitting one to any other bikes and will just stick to white dry lube in the future.
-Matt-
PostPosted: 05:31 - 16 Aug 2013    Post subject: Reply with quote
Personally im a bit dubious about these. I know a few couriers that swear by them but for normal riding id rather just clean and oil it myself every so often.
Some cheaper similar alternative to scottoilers
https://www.loobman.co.uk/
https://www.pdoiler.co.uk/
trevor saxe-coburg-gotha
PostPosted: 05:41 - 16 Aug 2013    Post subject: Re: Scotoiler, worth fitting? Reply with quote
Is it worth it?
Keeping on top of lubing the chain? Dude that's no chore. Okay wait - have you got a centre stand? I can see how faffing with a paddock might get old. But really - hoiking it onto the centre then hand spinning the back wheel whilst giving 1 or 2 passes of the chain a quick squirt with some nice, thick hear oil. Pretty effortless. Fuck, I clean my chain after every ride - little bit of diesel on a small piece of sponge, spin back wheel, press sponge on chain. Viola, innit. Then on with the thick stuff. Bike loves it. Bollocks to Scott oilers unless you're planning on travelling back in time to the '80s and getting a job couriering in london. Laughing
PostPosted: 08:09 - 16 Aug 2013    Post subject: Reply with quote
I've tried loobman and tutoro and they're both wank. It's almost impossible to keep them aligned on the sprocket, although if your goal is to oil your rear tyre I can't recommend them enough.
mudcow007
PostPosted: 08:34 - 16 Aug 2013    Post subject: Reply with quote
aha....but what about bikes with only a side stand?
i think i needs to buy me some paddock stands
PostPosted: 08:36 - 16 Aug 2013    Post subject: Reply with quote
Apply oil, roll bike forward, apply more.
or block of wood under right hand foot peg, balance it on that and spin the wheel.
j.silvs
PostPosted: 08:54 - 16 Aug 2013    Post subject: Reply with quote
Bought a stand used it once, over it
Just roll it back and forward now lol
jimspeed
PostPosted: 09:15 - 16 Aug 2013    Post subject: Reply with quote
Bit of hassle to set up but once it is right I found it good and not had to adjust the chain since (3500 miles) no faffing with lube every weekend and my wheel stays a lot cleaner than it did when I just oiled the chain manually.
I can get some pics of mine fitted on the zzr if you want mate
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
mudcow007
PostPosted: 09:26 - 16 Aug 2013    Post subject: Reply with quote
i think i would need a steel I beam or something
u felt the weight of a Bandit!?
DrDonnyBrago
PostPosted: 09:37 - 16 Aug 2013    Post subject: Reply with quote
I use one (one of the old vacuum actuated ones), haven't needed to adjust my chain in 10,000 miles. I still clean and oil my chain but do it much less regularly than I would need to without a chain oiler.
Mine is fitted under the seat, inside the tail cowl so it is a bit of an arse to fill it up, otherwise I am glad I have it. Wet, fast roads do an excellent job of washing any oil off of your chain, which in winter, then rusts immediately. With the oiler there is still a little bit of oil left on the chain after a rainy ride.
Tutoro/loobman are shite.
Andyk
PostPosted: 09:42 - 16 Aug 2013    Post subject: Reply with quote
i have the tutoro auto and have to say im quite impressed wasn't impressed with the manual version, there is a bit of spray onto the rim etc but not tons and it was mainly caused by me not adjusting it when it got hotter Embarassed
Suntan Sid
PostPosted: 09:48 - 16 Aug 2013    Post subject: Reply with quote
There is a Scott Oiler on my bike, (came with the bike), crud build up, on my back wheel, doesn't seem any more or less than it would be without it. Unless space is severly limited, I can't see any disadvantages.
I say go for it! Thumbs Up
goto10
I use https://www.pdoiler.co.uk/ but with a Scottoiler nib on the rear sprocket, it's an electronic system (at a fraction of the Scottoiler cost, albeit without the fancy screen) - it's been absolutely spot-on and took zero effort to install and set-up. The pump uses metered doses too, so there's no need to adjust for temperature - it will always apply the same sized drop.
PostPosted: 09:56 - 16 Aug 2013    Post subject: Reply with quote
And wank. Wanking into a pile of shite, you've all seen the video.
I reckon I'll ditch the sprocket tyre oiling head on my loobman and just shove a piece of cable tie up the Japseye of the tube and lie it directly on the chain. It'll still dribble incontinently but at least it'll be voiding itself directly above the rollers rather than spurting inboard of the sprocket.
Quote Me Happy
PostPosted: 10:27 - 16 Aug 2013    Post subject: Reply with quote
I like my Scottoiler but then I'm lazy.
Yes, sometimes there's a bit of oil on my rear wheel but then that doesn't bother me, it might do if I had a shiny bike.
garth
PostPosted: 10:33 - 16 Aug 2013    Post subject: Reply with quote
They're good when they work, mine tend to break all the time, no idea why. Just stop dripping.
Eddie Hitler
PostPosted: 11:01 - 16 Aug 2013    Post subject: Reply with quote
I have one sitting in the shed, haven't bothered fitting it yet. Just seems more of a fit and forget, when I'd rather inspect my chain every few days.
There's also something really satisfying painting my chain with oil. Paint brush oiler. Old school.
MinhDinh
PostPosted: 11:02 - 16 Aug 2013    Post subject: Reply with quote
My boss had it on his Hornet. The chain lasted a long time and never really got loose. Based on that, I would say it is worth it. I use to make a mess doing it myself, so if it messy, it would be no different for me.
Hit the G spot. Wink
goto10
PostPosted: 11:16 - 16 Aug 2013    Post subject: Reply with quote
Eddie Hitler wrote:
...Just seems more of a fit and forget, when I'd rather inspect my chain every few days.
You can still do this with the oiler fitted.
It just means that between your loving oily moments, it gets yet more automatic TLC. Win.
</suck eggs>
C1REX
Depends what you want.
I have a Tutoro Auto because I use my bike everyday and do more miles than average rider.
11000 miles and I adjusted the chain once. It may need another adjustment soon.
I'm pretty sure the chain will last at least 40 000. I hope for 60 000.
Some couriers manage to do 80 000 on a chain with an oiler.
You can't get such a mileage even if you lube your chain after every ride.
I use the cheapest oil from Halfords. 5 quid for 5 Litres should last a lifetime.
Top Tip - DO NOT use a Twin feed nozzle. Single one work MUCH better. You chain will be lubed better.
MCForum meetup - One of the biggest motorcycle clubs in UK
TwoWheelsDail...
PostPosted: 11:46 - 16 Aug 2013    Post subject: Reply with quote
I have a tutoro auto, i think its fantastic, i have no issue with the nozzle moving. Works a treat!
Suzuki GSR 750 - 33BHP (Restriction Ends 17/12/2014)
KTM Duke 125 - SOLD
www.facebook.com/TwoWheelsDaily | www.twitter.com/TwoWheelsDaily | www.instagram.com/TwoWheelsDaily
Boxing
PostPosted: 11:53 - 16 Aug 2013    Post subject: Reply with quote
.... Thinking Am I the only one that uses GT-85 on their chain? Neutral
I found my loobman ok.
It did get knocked about a bit, but high stoppies on a dirt bike and off roading through English green lanes is rather asking for trouble - with normal riding it was always fine.
The last post was made 13 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 129.33 Kb
