Swarf after oil change
wots
PostPosted: 11:22 - 18 Aug 2013    Post subject: Swarf after oil change Reply with quote
Changed the oil in the ER6 yesterday, it's had two oil changes in my ownership, immediately after I got it then a few weeks later as i changed the filter after effectively a 'flush' with fresh oil. Hence they were quite close together. I should've changed it before now really, I've done about 3K and put in a magnetic sump plug at the last change. On the sump plug when it came out were about 3 or 4 strands of what I can only describe as fine wire brush like pieces of metal. 1/2 inch'ish long.
I'm going to change it again in about a month or so and see then. Should I be worried, other than that it's all ok. No issues at all.
lihp
PostPosted: 11:46 - 18 Aug 2013    Post subject: Reply with quote
How many miles?
Have you had it from new?
wots
PostPosted: 11:47 - 18 Aug 2013    Post subject: Reply with quote
PhilDawson8270 wrote:
How many miles?
About 22, I've had it for 5 months and put about 5K on it.
lihp
PostPosted: 11:48 - 18 Aug 2013    Post subject: Reply with quote
If there was no swarf in the oil that came out. I'd be tempted to do a couple of changes at short intervals just to check that nothing else is floating around.
If nothing else shows up I'd chill about it
wots
PostPosted: 11:50 - 18 Aug 2013    Post subject: Reply with quote
I only fitted the Magnetic plug at last oil change, about 3K, so wouldn't know.
PostPosted: 12:29 - 18 Aug 2013    Post subject: Reply with quote
I would not worry about it one bit. Manufacturing debris in the engine is common.
bikenut
PostPosted: 13:29 - 20 Aug 2013    Post subject: Reply with quote
:D manufacturing swarf as it came from the factory....thats a good one.....so they spend all that hi tech when making the engine and then throw in some grinding paste just before it leaves the factory......?
examine the old oil for bits, metal flakes etc etc.............mag sump plugs are a really good idea.........but wont catch alloy swarf etc.......
perhaps a good flush from the top down and clutch basket strip and clean, they can act as a centrifugal crap trap..........pics would be good.
wots
PostPosted: 13:44 - 20 Aug 2013    Post subject: Reply with quote
I took a pic, but the phone focused on the edge of the plug so not clear, not the actual swarf, I'll upload anyway.
Aff
PostPosted: 13:48 - 20 Aug 2013    Post subject: Reply with quote
bikenut wrote:
Very Happy manufacturing swarf as it came from the factory....thats a good one.....so they spend all that hi tech when making the engine and then throw in some grinding paste just before it leaves the factory......?
Look at the inside of an engine casting, they are usually pretty shoddy with plenty of areas with bad casting flash that you can break off with a fingernail.
Electric Bike Project
bikenut
PostPosted: 13:53 - 20 Aug 2013    Post subject: Reply with quote
really, how do you get your finger in there.......
PostPosted: 15:21 - 20 Aug 2013    Post subject: Reply with quote
Slip some roofies in the oil, take it to a dark alley.
wots
PostPosted: 15:22 - 20 Aug 2013    Post subject: Reply with quote
As ever, the voice of experience ....
-Matt-
PostPosted: 15:41 - 20 Aug 2013    Post subject: Reply with quote
Was looking at these magnetic sump plugs recently but thought they were maybe more novelty than purpose. Think i'll get one now after reading this. Did you find any fitting issues with the one you ordered or was it a 'perfect copy' Question
PostPosted: 16:08 - 20 Aug 2013    Post subject: Reply with quote
You really don't belong in this section.
wots
PostPosted: 16:11 - 20 Aug 2013    Post subject: Reply with quote
It actually came with a K&N oil filter, it's ready for wiring, not of interest to me. Nor the K&N brand, but the two came out cheap and my assumption was brand name rather than el cheapo. Just happened to be magnetic.
No leaks, no issues and didn't need to overtighten to seal. Wrist tight as some of the youtube videos say! Laughing
Quote Me Happy
PostPosted: 16:12 - 20 Aug 2013    Post subject: Reply with quote
I've put them on all my bikes, bought from Wemoto, perfect fit.
Never picked up any big bits of metal, but quite often a sort of charcoal grey colour very fine dust/sludge.
wots
PostPosted: 16:19 - 20 Aug 2013    Post subject: Reply with quote
In addition to the bits I mentioned, I had some of that sludge. Here is the pic, as you can see camera focused on the top of the oil!
https://i1312.photobucket.com/albums/t525/wotsthestory/da76d16b-7c18-4fa7-807e-d6f2debe28ee_zps4ce3d44d.jpg~original
PostPosted: 16:48 - 20 Aug 2013    Post subject: Reply with quote
A good investment those magnetic sump plugs. One of my bikes only has a gauze for the filter which is fine for bits of swarf, but not the ground down sludge.
PostPosted: 17:43 - 20 Aug 2013    Post subject: Reply with quote
Who said anything about grinding paste? If you can't put forward a decent argument at least stop making stuff up.
wots
PostPosted: 18:17 - 20 Aug 2013    Post subject: Reply with quote
If you keep a few bits of this from rattling round your engine, it's worth the cost
LongJohn22
PostPosted: 21:24 - 20 Aug 2013    Post subject: Reply with quote
This is what magnetic drain plugs are for, it's the microscopic shavings from quite normal wear that tend to form strands due to the magnetic lines of force. The time to worry is when the bits on the magnet are big enough to see as metal flakes.
Ed Case
PostPosted: 22:00 - 20 Aug 2013    Post subject: Reply with quote
If your ER gearbox is as 'clunky' as mine this debris probably emanates from there, I wouldn't worry about it. I had a magnetic sump plug in a 750 SOHC Laverda which was as thick as a knitting needle going in and as big as a bumblebee a thousand miles later.. Incidentally for what they cost I always use a genuine Kawasaki oil filter, pattern ones aren't that much cheaper.
bikenut
PostPosted: 10:54 - 21 Aug 2013    Post subject: Reply with quote
Very Happy and at least it aint going thro the oil pump anymore...... Very Happy
lihp
PostPosted: 11:01 - 21 Aug 2013    Post subject: Reply with quote
Who makes the filter for Kawasaki?
bikenut
PostPosted: 11:06 - 21 Aug 2013    Post subject: Reply with quote
:D i loved the pic of the mag sump plug.........brings back bmc mini etc days.....you know, when they made a loss on each one sold of some 8% ish.....good old brtitish engineering and industrial management. :D
The last post was made 13 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 131.93 Kb
