cutting holes in air box
EXC-Rider
PostPosted: 11:47 - 22 Aug 2013    Post subject: cutting holes in air box Reply with quote
I was thinking about cutting some holes into the side of my air box on the exc and put a wire mesh behind it mainly for visual affect more than anything but I would know if I had to re jet the carb as more air is flowing ?
owned bikes: DR50, Thumpsta 110 , Honda CR85, Speedfight 100, Yamaha XT125X, Honda CRF450, Honda Hornet '07
current bikes: KTM EXC525 AKA the wheelie machine
A friend in need is a friend indeed but a friend with weed is better!
P.
PostPosted: 11:48 - 22 Aug 2013    Post subject: Reply with quote
Don't do it. Rain gets in. TTR had the same Laughing
Irn-Bru
PostPosted: 11:49 - 22 Aug 2013    Post subject: Reply with quote
Most likely will need rejetted. I read on the KTM forum when I had my EXC that the jetting from standard isn't too good regardless. Usually they are set up lean to get around EU testing.
Doovy
PostPosted: 12:02 - 22 Aug 2013    Post subject: Reply with quote
Reminds me of this guy: https://www.motorcyclenews.com/MCN/News/newsresults/General-news/2010/May/may2710-shervin-an-internet-motorcycle-celebrity-is-born/
https://www.motorcyclenews.com/upload/267830/Untitled-1.jpg
Don't do it.
Cutting a hole in your airbox will probably make it flow less air, not more and will screw up the laminart airflow meaning it wont carburate correctly.
You are looking at making grief for yourself for no good reason. Don't mess with airboxes unless you understand what you are doing and why (or are acting on the advice of someone who understands).
Irn-Bru
PostPosted: 12:07 - 22 Aug 2013    Post subject: Reply with quote
Doovy wrote:
Not really, it's not quite that silly. Off road and supermoto people often modify the air box of bikes to help improve performance, but you're meant to up the jetting to account for the extra air.
PostPosted: 12:15 - 22 Aug 2013    Post subject: Reply with quote
Not heard of an EXC needing it - it's usually on bikes designed to be slower and more road biased.
For the OP: why not just stick the mesh on the outside?
People that don't know about it won't know the difference and people that do would have thought you were silly if you had done it probably.
And yes, if you do, you will need to rejet.
robs321
PostPosted: 19:46 - 22 Aug 2013    Post subject: Reply with quote
Dont!
Matt-
PostPosted: 20:12 - 22 Aug 2013    Post subject: Reply with quote
I wouldn't do it unless you've seen some good solid evidence of it working and making a improvement on your bike.
A lot of people do it for 2 strokes, i personally did 2 small holes with some piping coming out of drilled holes facing down and it gave me slight improvement on my 0 - 60 time,However it did give me issues when it rained hard.
Plus if it doesn't work, your left with a bodged airbox.
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Drake
PostPosted: 20:14 - 22 Aug 2013    Post subject: Reply with quote
do it faggot
nathan k
PostPosted: 20:45 - 22 Aug 2013    Post subject: Reply with quote
As mentioned, you'll probably make the air flow worse not better. If you do it, you'll probbly need to upjet.
rac3r
PostPosted: 21:18 - 22 Aug 2013    Post subject: Reply with quote
Just remove the airbox and put mesh where it used to be...
Chequered Flag
stevo as b4
PostPosted: 21:36 - 22 Aug 2013    Post subject: Reply with quote
Can you just take the lid off the airbox or remove the intake silencer rubber/snorkle and do a back to back dyno test?
If more airflow is needed then such a test with A/F ratio monitoring would show it up both with differences to power and to the fueling.
Some bikes have a restrictive airbox and some don't. If such a test doesn't show any gains or show up big changes in fueling, then it's not needed and not worthwhile. You can also do a dyno run with the airbox intact and the filter element removed, and this would tell you if a freer flowing filter element would be worth fitting or not.
PostPosted: 21:58 - 22 Aug 2013    Post subject: Reply with quote
None of my 2 stroke EXCs have had a snorkel like that I don't think - and nor did my husaberg that I remember; I'm presuming the 4 strokes don't either.
The more trail/road orientated bikes do/have done.
stevo as b4
PostPosted: 22:14 - 22 Aug 2013    Post subject: Reply with quote
Yeah I'd say that makes more sense, as your not really worrying about intake noise levels on a competition machine.
The snorkel is often as about reducing noise and turbulence in the inlet hole to the airbox as it is about effecting performance.
I know on some bikes like the KMX125 for example that the airbox entry/snorkel is smaller than the size of the opening to the filter element. Modifying the airbox lid correctly and re-jetting seems to add 1-2bhp over std too.
Fizzer Thou
PostPosted: 23:44 - 22 Aug 2013    Post subject: Reply with quote
If you want to let more air in,fit a K&N air filter purpose made for the bike
https://pdq1.com/part.php?PartID=465&MakeID=17&ModelID=777&YearID=3260&Year=
You can buy performance modifying needles from Allens Performance
Always have a 'Plan B'
deadwolf
PostPosted: 23:58 - 22 Aug 2013    Post subject: Reply with quote
Doovy wrote:
Just had a look at his bikepics.com profile hoping for some lulz. Turns out that all of his photos have been deleted because he'd uploaded roughly 1500 of them, most of which showed the same thing.
Legend.
Motorsapien Art
EXC-Rider
PostPosted: 18:41 - 23 Aug 2013    Post subject: Reply with quote
seems like no is the answer
thanks Thumbs Up
cimbian
PostPosted: 09:31 - 24 Aug 2013    Post subject: Reply with quote
Did this on my TA and cured its asthma but created a ram-air issue at speed even though it was behind the main fairing.
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
pepperami
PostPosted: 09:44 - 24 Aug 2013    Post subject: Reply with quote
Cut up the air-box Thumbs Up set fire to bike Thumbs Up = no more problems Thumbs Up
The only time modifying an air-box has worked for me was when I re-jetted my RD 250 lc many moons ago.
And! then I only drilled some holes in it so it could suck better/more.
And! that was only after having a bad experience with those stupid after-market cone filters???
woodyeee
PostPosted: 10:32 - 24 Aug 2013    Post subject: Reply with quote
Reminds me of years ago when I added a pee-shooter powerpipe exhaust on my Suzuki ap50 it sounded much faster........ but it was actually 5mph slower Embarassed
Matt-
PostPosted: 10:51 - 24 Aug 2013    Post subject: Reply with quote
Don't even start with cone filter's pep!
cimbian
PostPosted: 10:54 - 24 Aug 2013    Post subject: Reply with quote
I drilled six 15mm holes in the front of mine but this was BEFORE the filter so the flame-arrest function of the filter remained. Smile
22PlusY
1cyl
PostPosted: 11:36 - 24 Aug 2013    Post subject: Reply with quote
Mesh? Pah!
If you want to mess with airflow for asthetic enhancements, this is how it's done:
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
The last post was made 12 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 129.41 Kb
