honda cg 125 clutch
stuartt
PostPosted: 11:46 - 14 Sep 2013    Post subject: honda cg 125 clutch Reply with quote
i bought a cg 125 for my boy yesterday .
the clutch won't disengage when you pull the clutch in .
i've stripped it down a few times & it looks ok as far as i can tell .
what i'm not sure about is the shaft that comes out of the engine has a outer & inner bit , should the inner shaft move in to the outer shaft to allow the the clutch to disengage ?
advice needed please .
Ariel Badger
PostPosted: 12:30 - 14 Sep 2013    Post subject: Reply with quote
Can you see the plates opening when you pull the lever in?
stuartt
PostPosted: 12:39 - 14 Sep 2013    Post subject: Reply with quote
when i put the cover back on i can't see a thing , the lever feels ok but nothing happens .
i should add the bike is a 2008 with 1900 mls & has lay in a garden since 2009 when the 1st yrs tax ran out !
lukamon
PostPosted: 12:45 - 14 Sep 2013    Post subject: Reply with quote
hmmm... maybe the clutch is stuck? Thinking
if you havnt been messing with the adjusters and have assembled it back right, then that might be it. push it in nutral, run along side as fast as you can, jump on, pull in clutch, bang into second
that's what id do anyway. it might take a few tries
killa wrote: Im an ass man myself
stuartt
PostPosted: 12:49 - 14 Sep 2013    Post subject: Reply with quote
what are the adjusters ?
when the clutch is off the inner & outer shaft turn separately , i think the inner shaft should go in to the outer shaft when the clutch lever is pulled to disengage the clutch , is that what should happen ?
lukamon
PostPosted: 12:50 - 14 Sep 2013    Post subject: Reply with quote
the screws / nuts that adjust the length of the clutch cable?
anyway, go give it a try. you never know
stuartt
PostPosted: 12:57 - 14 Sep 2013    Post subject: Reply with quote
i'll put it back together & try thanks
lukamon
PostPosted: 13:09 - 14 Sep 2013    Post subject: Reply with quote
oh wait... its apart now? why not post a pic of it Thumbs Up
stuartt
PostPosted: 14:17 - 14 Sep 2013    Post subject: Reply with quote
can't post pics , it stresses me to fk trying to post pics Confused
Alpha-9
PostPosted: 14:26 - 14 Sep 2013    Post subject: Reply with quote
It's easy, try harder.
www.postimage.org
Fzr-600 1999
stuartt
PostPosted: 15:32 - 14 Sep 2013    Post subject: Reply with quote
https://postimg.org/image/6sjs7gmsh/
stuartt
PostPosted: 15:35 - 14 Sep 2013    Post subject: Reply with quote
https://s23.postimg.org/w9cesdiwr/IMAG0069.jpg
stuartt
PostPosted: 17:48 - 14 Sep 2013    Post subject: Reply with quote
here's a link to a pic someone else posted .
in the middle of the clutch theres a pin going in to the shaft . my clutch seems to be missing the pin , i take it thats my problem ?
https://www.flickr.com/photos/grillyfish/8153404609/
mudcow007
PostPosted: 17:54 - 14 Sep 2013    Post subject: Reply with quote
Yap
that pin is what gets pushed, to push the plates together
cmsnl or ebay will be your friend here
or speak to Honda
stuartt
PostPosted: 17:56 - 14 Sep 2013    Post subject: Reply with quote
ok , thanks
mudcow007
PostPosted: 18:02 - 14 Sep 2013    Post subject: Reply with quote
stuartt wrote:
ok , thanks
Boom!
stuartt
PostPosted: 18:30 - 14 Sep 2013    Post subject: Reply with quote
thanks , all the bits for the wee bike seem to be cheap Very Happy
The last post was made 12 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 89.58 Kb
