1997 TL1000S fiddlin'
PostPosted: 17:25 - 14 Sep 2013    Post subject: 1997 TL1000S fiddlin' Reply with quote
I traded the R1 a while back for a TL1000S, thought it was a 98, turns out its a 97.
No worries, it was clean, had a nice SS exhaust system and sounded great.
Rode like shit however for 3 reasons.
1, The injectors were filled with some form of yellow shit, also they had been removed before and the seals were not replaced. Explains my 60 miles to a tank, it pisses itself from the front injector when its switched on and pumping. Fixed that, new seals and bam, no leaks!
2, Due to some previous owner (maybe a few owners back but still) bodge work inside the tank. Suzuki intended for there to be a filter inside the tank with a little pipe work just after the pump.
Not here, oh no! Someone had inherited my genes and just wanged a real loose bit of fuel pipe that had perished and was leaking. They also shoved a filter the size of a can of baked beans between the rear cylinder and the tank, so I cannot re-use the pipe that should have gone pump > injector rail.
Thanks to Pete, the tank internals were fixed, he also synced the throttle bodies and sorted the vertical side stand! Top guy.
3, Suzuki fitted this horrendously stiff steering damper. It is totally stupid and ruins the handling. Pulled that off and left it off the first time I removed the tank.
Also, it was still restricted Rolling Eyes Someone has cut the speed limit wire and done it properly with selotape you know, so sorted that with heatshrink.
They had however left the standard restricted intakes in there. See top left in this photo.
https://i1291.photobucket.com/albums/b545/paddynewman/tl1000_manifold_restriction2_zpse951bddb.jpg
I set away with a drill and a file to remove the solid crescent of shit rather than pay Mr Suzuki £90. Worked perfectly Laughing
This is how it looked a few weeks ago after it was running bang on.
https://i1291.photobucket.com/albums/b545/paddynewman/P1010543_zpsf490d022.jpg
https://i1291.photobucket.com/albums/b545/paddynewman/P1010547_zps7801014c.jpg
Loaned it to Doovy so he could have a bike after he sold his and unfortunately someone damaged it. Didn't bother me too much, although I had to comfort Doovy who was gutted! The guy paid out for the damages in cash though so I can't really say anything bad about the situation Thumbs Up
This is the damage caused.
https://i1291.photobucket.com/albums/b545/paddynewman/tldamage_zps7def0b63.jpg
With the money the guy paid me after I priced up all the parts and bits I could either buy the panel required or pop a little more cash in and get the full respray. I chose the latter. Means I get the repair done, it becomes mint again and everyone is happy!
This is the current status
https://i1291.photobucket.com/albums/b545/paddynewman/tlwhi_zps0563e499.jpeg
I've also got a Power Commander sitting here ready to go on and a 15k resistor to basically have a TRE. Also dropping 2 teeth on the front for that hooligan feel. I'll add more stuff when more stuff happens Wink
Irezumi aka Reuben
Carrot Top
PostPosted: 08:56 - 15 Sep 2013    Post subject: Reply with quote
If Pete. is reading this would you be interested in balancing the TB's on an Aprilia Falco if I throw some cash your way?
P.S. Nice Tiller, be interested to see how it compares to my Falco.
Pictorgraphicalfantastical
Supermoto_Fan
PostPosted: 09:03 - 15 Sep 2013    Post subject: Reply with quote
Watch those indicators, look the same as mine, if they are wobbly then they will soon just fall away from the bracket as they are held on with rubber stalks and these perish over time/weather.
Love the TL
Pie-Roe
PostPosted: 10:02 - 15 Sep 2013    Post subject: Reply with quote
I have a spare TRE.
PostPosted: 12:50 - 15 Sep 2013    Post subject: Reply with quote
Pyro. wrote:
I have a spare TRE.
It is unlikely to work with my bike, the 97 had a shit wiring loom and is far different to your TLR Sad
Even so, its only 1 wire and 1 resistor, I'm sure I'll manage Laughing
Irezumi aka Reuben, if you are close to Maidstone, feel free to come have a go.
PostPosted: 19:40 - 28 Sep 2013    Post subject: Reply with quote
Well...
Fitted the Power Commander 2 today... promptly unplugged it as something is silly wrong with the idle speed but when its connected you get a fair chunk more go go juice Shocked
Here it is, repaired, painted and looking far more sexual than it should Thumbs Up
https://i1291.photobucket.com/albums/b545/paddynewman/tlwhite_zps4e319fa1.jpeg
Fisty
PostPosted: 07:56 - 29 Sep 2013    Post subject: Reply with quote
In this case white is not right. Do not want paddy!
Power commander has been set up for a bike with intake restrictors still in by the sounds of things.
Fatter and faster than Fret
PostPosted: 08:21 - 29 Sep 2013    Post subject: Reply with quote
It was a map made for me after I detailed the mods to the guys who I bought the PC2 from. Set up for UK inlets, full exhaust, aftermarket air filter, basically their stage 1 map Thumbs Up
mrdelmonti
PostPosted: 08:31 - 29 Sep 2013    Post subject: Reply with quote
I really like it white, not normally keen on white bikes or cars but that looks smart, good choice Thumbs Up
Fisty
PostPosted: 17:18 - 29 Sep 2013    Post subject: Reply with quote
Then he has done a shit job!
PostPosted: 17:54 - 29 Sep 2013    Post subject: Reply with quote
How so buddy?
PostPosted: 07:57 - 30 Sep 2013    Post subject: Reply with quote
_Iain_ wrote:
More likely set up for pod filters rather than a panel. It is very very rich low down.
Set up for the K&N pop in I currently have Thumbs Up Want to find a BMC so I can run that specific map.
UnspeedySam
PostPosted: 08:21 - 30 Sep 2013    Post subject: Reply with quote
Late to the party but very nice! Smile
PostPosted: 09:08 - 30 Sep 2013    Post subject: Reply with quote
_Iain_ wrote:
That guy up in sevenoaks with the dyno, get shit fixed & we'll take a run up? Name the day and i'll pop up with you.
T3 Racing Thumbs Up
garth
PostPosted: 09:52 - 30 Sep 2013    Post subject: Reply with quote
Needs black wheels.
PostPosted: 10:02 - 30 Sep 2013    Post subject: Reply with quote
garth wrote:
Needs black wheels.
Read my mind sir Thumbs Up
PostPosted: 12:54 - 30 Sep 2013    Post subject: Reply with quote
Erm, unsure if gonna plastidip yet as I'd need them back asap.
Drake
PostPosted: 13:45 - 30 Sep 2013    Post subject: Reply with quote
Powdercoating. Can be done for less than that paint price. Or for near ttiple that price
garth
PostPosted: 14:05 - 30 Sep 2013    Post subject: Reply with quote
Rob Fzs wrote:
do some proper wacky neon colour for teh wheels Thumbs Up
May i suggest turquoise
PostPosted: 14:08 - 30 Sep 2013    Post subject: Reply with quote
I'll go for some funky colours, might even be gay with white rim tape Neutral
Vote on some colours Laughing
garth
PostPosted: 14:11 - 30 Sep 2013    Post subject: Reply with quote
https://carmeetsroad.com/frs/files/2013/04/subaru-brz-on-issforged-spyder-gt-wheels-in-brushed-turquoise-spot-on-ft86-frs-forged-stance-stancenation-instacar-instagood-jdm-boxter.jpg
See, the colours work.
The last post was made 13 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 130.36 Kb
