sv650 tyre pressure
stranger12
PostPosted: 14:35 - 10 Oct 2013    Post subject: sv650 tyre pressure Reply with quote
Hi All,
My tyre pressure in my sv is 36 psi rear and 33 front and I am around 115kg . The bike feels really stiff but that could be suspension which I need to check out and make sure it is adjusted correctly. so that temporary rules out air pressure causing the bike stiffness.
However whenever I ride it , I can see a single line left across front and rear of my bike which signifies that my tyre is over inflated as the center piece is mostly in contact with the road.
here is a pic for your referencehttps://i42.tinypic.com/2e4ln6d.jpg
what do you guys think , Am i correct in thinking that way and need to reduce tyre pressure?
Many thanks
SV650 Red
R6 Red
PostPosted: 14:36 - 10 Oct 2013    Post subject: Reply with quote
https://weknowmemes.com/wp-content/uploads/2012/03/what-the-fuck-am-i-reading.jpg
serlant
PostPosted: 15:57 - 10 Oct 2013    Post subject: Reply with quote
try going around some corners, i'd have said 36 rear 33 front is already low enough for the road. I never run my pressures that low (I just aim for a tad under 40psi front/rear.) Here are my front and rear tyre profiles, front is halfway gone rear is nearly at legal limit, neither have squared off both running 39 or so PSI on my VTR1000.
https://i191.photobucket.com/albums/z170/serlant/IMG_20131010_155239_zpsbe2fa932.jpg
https://i191.photobucket.com/albums/z170/serlant/IMG_20131010_155252_zps9238cd01.jpg
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
CaNsA
PostPosted: 16:14 - 10 Oct 2013    Post subject: Reply with quote
Seriously, what exactly are you asking?
CaNsA
PostPosted: 16:16 - 10 Oct 2013    Post subject: Reply with quote
What pressures do suzuki suggest for the sv650?
Carvel
PostPosted: 16:20 - 10 Oct 2013    Post subject: Reply with quote
You're a flatout bellend.
There should be a law against this shit.
stranger12
PostPosted: 16:25 - 10 Oct 2013    Post subject: Reply with quote
law against what ?
according to haynes mine is 36 33 rear front but that leaves a line in the middle as per the picture suggesting the wheel is over inflated also the bike is a bit wobbly in corners
SV650 Red
R6 Red
Marmalade
PostPosted: 16:34 - 10 Oct 2013    Post subject: Reply with quote
The only cure is to sell it and buy a car.
Or, maybe if you let the tyres down to 12.5psi and avoid any corners you'll be fine.
stranger12
PostPosted: 16:36 - 10 Oct 2013    Post subject: Reply with quote
well what I was asking is whether the line in the middle suggest over inflated tyre or not , full stop .
just needed opinion really Smile
SV650 Red
R6 Red
CaNsA
PostPosted: 16:41 - 10 Oct 2013    Post subject: Reply with quote
Do you think all of the tyre should be on teh road all the time?
Ask yourself, why are they curved.....
CaNsA
PostPosted: 16:43 - 10 Oct 2013    Post subject: Reply with quote
We could tell you the answer, or we could help you to think for yourself.
DrDonnyBrago
PostPosted: 16:47 - 10 Oct 2013    Post subject: Reply with quote
You are thinking of car tyres, where over-inflation means the middle wears out.
On a bike, straight lines make the middle wear out.
Acemastr
PostPosted: 16:50 - 10 Oct 2013    Post subject: Reply with quote
This 'line' you're on about is just your tyre in contact with the road, I run 36/42 on my CBR. The line is a contact patch, it's not going to squash the entire tyre into the road is it?
Follow what your manual says, you're a heavy fucker so i'd probably say to raise the rear a bit, I'm only 60kg and have higher than you already(my manual states 36/42)
2016 Toyota Tacoma Limited
CaNsA
PostPosted: 16:57 - 10 Oct 2013    Post subject: Reply with quote
You two may think you are helping this chap but unfortunately you have only enabled him to be even more retarded.
Well done. Thumbs Up
DrDonnyBrago
PostPosted: 17:14 - 10 Oct 2013    Post subject: Reply with quote
I thought you might appreciate the company Thumbs Up .
stranger12
PostPosted: 17:15 - 10 Oct 2013    Post subject: Reply with quote
surely I am not retart not sure whether you are as you seem to be sarcastic rather than trying to help.
I don't expect the full patch on the road at all times but rather saw that middle has a line or whatever you want to call it so thought that suggests over inflation and almost my bike weight is mostly in the middle of the tyre and not spread a bit outward hence why I asked ( it seems the middle bit I am referring to is too thin rather than the expected slightly more spread out)
may raise the rear a bit due to weight
SV650 Red
R6 Red
CaNsA
PostPosted: 17:28 - 10 Oct 2013    Post subject: Reply with quote
really?
fucking really?
The 5th word sums it up....
stranger12
PostPosted: 17:30 - 10 Oct 2013    Post subject: Reply with quote
not t d , spelling mistake Very Happy
SV650 Red
R6 Red
Clutchy
PostPosted: 17:34 - 10 Oct 2013    Post subject: Reply with quote
LOL must be trolling, surly NO-ONE is this stupid Laughing
You've bought the 'linear car tyre' for your SV so yes it does need to be deflated so the whole tyre is in contact with the road, next time ask for a sports/touring tyre.
HTH.
stranger12
PostPosted: 17:48 - 10 Oct 2013    Post subject: Reply with quote
I haven't it was on the bike .
it is Avon , anyway to conclude it seems normal and shall leave it
SV650 Red
R6 Red
The last post was made 12 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 105.65 Kb
