Brothers motorhispania rx50 won't start?
reed
PostPosted: 15:16 - 22 Oct 2013    Post subject: Brothers motorhispania rx50 won't start? Reply with quote
Hey people of the internet, a little while ago my younger brother turned 16 and got a motorhispania rx50 on a 2004 plate, he did his cbt a couple days ago and it has been running fine, but yesterday it decided to be gay and not start, I took the tank off and realised that the spark was jumping from the ht lead (just at the back of the ht cap) onto something else, therefor meaning the spark was not getting to the plug.
I then moved the ht lead away from any metal and straight away it ran again, leading me to believe it was a sparking issue, now however it has decided not to start again, I have just tried replacing both the spark plug and the ht cap with no joy, I have also checked the ht lead etc. And a spark is getting through. Also the plug gave a visible spark against the frame when I tested it.
Now I am stumped, it doesn't even sound like it's trying to start, when I attempt to bump start it, it just turns over, then when the clutch is pulled in it kind of coughs then cuts out.
Any ideas? I would be cry grateful. Smile
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
P.
PostPosted: 15:18 - 22 Oct 2013    Post subject: Reply with quote
Clean the carb? Did you turn the fuel back on when you took the tank off Laughing
reed
PostPosted: 15:20 - 22 Oct 2013    Post subject: Reply with quote
I never turned the fuel off Embarassed just put a pipe with a knot in the end on instead Smile
Do you think the carb could be the problem? When it ran it didn't feel like there was anything wrong with the carb, seemed to be nice and smooth and have a decent amount of power and pull. (for a 50cc) Laughing
P.
PostPosted: 15:22 - 22 Oct 2013    Post subject: Reply with quote
Ghetto, I like it Laughing
Would probably whip the plug out, give it a quick clean. Pop the carb off and clean the bowl out.
reed
PostPosted: 15:23 - 22 Oct 2013    Post subject: Reply with quote
I put a new plug in about 5 mins ago Smile Ooo I have never attempted to take a carb apart in any way (other than on my gsxr 400 with the supervision of a friend Laughing )
P.
PostPosted: 16:51 - 22 Oct 2013    Post subject: Reply with quote
Not too hard really, remove it and just turn fuel off. Turn carb upside down and remove the screws holding the bowl on, clean bowl and unscrew jets, clean them and make sure they are clear.
Done Thumbs Up
reed
PostPosted: 17:16 - 22 Oct 2013    Post subject: Reply with quote
Okay so far I have:
Replaced ht cap
Replaced spark plug
Taken the coil pack off to clean the earth wire
Checked for a spark which there is
I am confused as the problem before was definitely related to the lack of spark, a temporary solution fixed it, but now the exact same problem is back.
It doesn't seem like a carb issue to me, it was running absolutely fine before, and it has the same issues that it had when there was a lack of spark.
I may try taking the carb off. However I am not good when it comes to remembering how stuff goes back on. Crying or Very sad
bypass2
PostPosted: 17:25 - 22 Oct 2013    Post subject: Reply with quote
does it have a side stand switch if so maybe faulty.
iooi
PostPosted: 17:29 - 22 Oct 2013    Post subject: Reply with quote
So Spark plug out. Connect into HT lead and rest on cylinder. Then crank bike over.
Should see it spark.
If not then you may need to trim HT lead back a bit so that HT cap is getting good contact with the wires inside lead.
Has lead come loose at coil end?
Only reason I would look at carb is for a air lock in the fuel line.
Oh and have you knocked kill switch?
reed
PostPosted: 19:20 - 22 Oct 2013    Post subject: Reply with quote
Already done all that mate, and there is no kill switch. Sad
bypass2
PostPosted: 19:56 - 22 Oct 2013    Post subject: Reply with quote
what about the battery does it have to be fully charged
Ariel Badger
PostPosted: 20:38 - 22 Oct 2013    Post subject: Reply with quote
Has it run out of fuel? Is the plug wet after trying to start it?
reed
PostPosted: 22:04 - 22 Oct 2013    Post subject: Reply with quote
Definitely not out of fuel, will check the new spark plug tomorrow. Cheers mate. Thumbs Up
reed
PostPosted: 12:17 - 23 Oct 2013    Post subject: Reply with quote
Just took the plug out. It does seem wet, but not at the tip, more on the thread itself, so it may have just got there from screwing it in?
mysterious_rider
PostPosted: 12:23 - 23 Oct 2013    Post subject: Reply with quote
maybe try spraying something flammable down the carb intake. Even deodorant if you have it. It does work... If it starts then you know its a carb related issue.
You've checked for a spark and it works, so the next thing to check is fueling. Wet plug you say? Well I'd still be taking the carb apart.
I had the rx50 (aprilia) And it managed to have a bent float needle which stopped it from running properly. Worth having a look inside. Clean the jets and the paths behind them with an airline. etc.
KAWASAKIIIII
reed
PostPosted: 12:43 - 23 Oct 2013    Post subject: Reply with quote
I tried putting a bit of petrol into the cylinder head and putting spark plug etc back (as I did with my old GSXR 400) and it did absolutely nothing, it's as if the kill switch has been put on, but there is no kill switch, no side stand switch, no switch any where else. Might have to give up soon and take it to the garage, however I may have a look at the carb first, which will most likely end in me breaking something if it isn't already broken. Smile
P.
PostPosted: 12:45 - 23 Oct 2013    Post subject: Reply with quote
Where abouts are you based? You don't look too far from me... I can probably take a look Laughing
reed
PostPosted: 12:50 - 23 Oct 2013    Post subject: Reply with quote
My headquarters are in Herne Bay. Laughing although you'll probably turn up and discover a mysterious hidden kill switch. Laughing
P.
PostPosted: 12:56 - 23 Oct 2013    Post subject: Reply with quote
Can possibly get over, don't suppose you can get it to Ashford Laughing
reed
PostPosted: 13:04 - 23 Oct 2013    Post subject: Reply with quote
Not unless I push it. Laughing don't worry too much mate, don't want to put you out of your way. Smile
If you really want to help, then I guess I could gratefully accept. Wink
reed
PostPosted: 15:07 - 23 Oct 2013    Post subject: Reply with quote
mpd72 wrote:
Sorry, newbie first post....
If the HT lead was arcing out to another metal object, there's clearly something wrong with the lead.
I've got an old Shogun which refused to start one evening. You could see the leads arcing out to the engine block. Swapped the leads and it's been fine ever since.
Chopping the end off the lead wont really help. If it's arcing out, the insulation isn't doing it's job. Was the lead soaking wet when it was arcing out?
You can buy HT lead for a couple of quid a metre on Evil bay...
https://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1311.R2.TR10.TRC0.A0.Xht+lead&_nkw=motorcycle+ht+lead&_sacat=0&_from=R40
When I changed it on my 2 stroke race bike, I had to pop the plastic snap connectors to open up the bit of the coil where the lead fits. I sealed the leads in with a bit of silicone sealant just to make sure it was waterproof.
This is what I believed the issues was, however with the new ht cap came a rubber seal that goes over the ht lead, I have attempted starting it in the dark since and it is no longer arcing on anything, I'll probably replace the lead anyway, but I can't see this being the issue really.
bypass2
PostPosted: 19:29 - 23 Oct 2013    Post subject: Reply with quote
does any of the electrics work. maybe a fuse /bad earth. is the plug sparking allright now.
reed
PostPosted: 22:34 - 23 Oct 2013    Post subject: Reply with quote
There is a spark and the neutral light, horn etc all work fine.
The last post was made 12 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 134.1 Kb
