YBR - Shifting issues 1st to 2nd
SofaBear
PostPosted: 13:11 - 16 Nov 2013    Post subject: YBR - Shifting issues 1st to 2nd Reply with quote
Hi all,
I was out on the bike last weekend and noticed that i would try shifting from 1st to 2nd (2nd to 1st) and no matter what i did or how hard i changed the bike would stick it in neutral making me rev the tits off it when i released the clutch, looking like a douchebag. i end up having to double tap the lever to get it to engage.
Am i doing something wrong here or is it a sign of something not right?
Its a 2013 Yamaha YBR 125. barely 400 miles on the clock.
arry
PostPosted: 13:17 - 16 Nov 2013    Post subject: Reply with quote
How's the clutch cable free play looking for adjustment?
Might just have bedded in enough it needs a bit of a fiddle now.
SQL
PostPosted: 13:26 - 16 Nov 2013    Post subject: Reply with quote
Possible its you, try adjusting the gear lever position.
SofaBear
I have no idea, new to this game so wouldn't know what i am looking at.
Its due its first service shortly so i am assuming this would get looked at?
arry
PostPosted: 14:20 - 16 Nov 2013    Post subject: Reply with quote
It should get picked up on its service but it's a really easy 2 minute job mate
Stick a ruler transverse from the handlebar end out towards the ball on the end of the clutch lever. Measure the amount you can move the ball out away from the bar and back into its resting position. It should be about 15-20mm
If you need to adjust it, under the rubber boot on the lever pivot point you'll find a lock ring adjuster. Slacken the lock ring off, and turn the inner part until you get the right amount of free play. Tighten the lock ring up again and you're done.
YBR Ric
PostPosted: 17:53 - 16 Nov 2013    Post subject: Reply with quote
400 miles! The gearchange mechanism hasn't even had time to bed in yet. Start to force things and its be crap gearchanges forevermore.
Ensure you run some lube down the clutch cable once the rubber boot has been pulled back. I used 3-1 initially then a few drops of clean engine oil. It'll make a world of difference.
Just a small tip...
Clutch lever play between a cold engine and hot engine differs, as with engine tickover speed, it's best adjusted when the engine is hot Smile
Boris the spider
PostPosted: 20:22 - 16 Nov 2013    Post subject: Reply with quote
_Iain_ wrote:
Slack chain
YBR's are a real sod for it, when the chain goes slack the gears dont quite engage propperly and it'll usually ping out and go straight into neutral.
That's when I know my ones needs lubed and adjusted.
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
Pigeon
PostPosted: 21:48 - 16 Nov 2013    Post subject: Reply with quote
Boris the spider wrote:
_Iain_ wrote:
Slack chain
Smile Same method I use
SofaBear
PostPosted: 12:51 - 17 Nov 2013    Post subject: Reply with quote
So you recon adjusting the chain, lubing it and if not adjusting the play?
I thought i broke it the first time lol
How often should the chain be tensioned?
arry
PostPosted: 12:57 - 17 Nov 2013    Post subject: Reply with quote
Check the chain tension once every few weeks but it shouldn't need too much adjusting if it's been cared for, cleaned and lubricated properly
Would still check the free play too
SofaBear
PostPosted: 13:05 - 17 Nov 2013    Post subject: Reply with quote
I am riding for a weekend every month or so. In uni away from home and the bike so not near it. should i be checking adjusting every time i ride it?
SofaBear
PostPosted: 13:06 - 17 Nov 2013    Post subject: Reply with quote
arry
PostPosted: 13:09 - 17 Nov 2013    Post subject: Reply with quote
Where's it stored when not in use? Do you clean it down if it's been out in bad weather etc?
There's no exact science to chain maintenance but the basics are if you've covered the chain in road film and grit, without it being lubricated properly, and don't clean it down, then it'll rot, run dry on the rollers and stretch MUCH faster than a chain that's been cared for. In that scenario, you'll be adjusting it loads - and replacing it very quickly too.
To give you an idea, the last time my chain needed adjustment was circa 2000 miles ago. I do check it for lubrication and condition every ride though
SofaBear
PostPosted: 13:21 - 17 Nov 2013    Post subject: Reply with quote
Its stored in a garage, not heated.
I haven't cleaned it yet, not really needed to however it was rather wet the last time i was out in it. I have lubed the chain twice, once few weeks before i went out on it and second after i brought it back from a ride out.
Dimonn
PostPosted: 12:15 - 19 Nov 2013    Post subject: Reply with quote
I agree with Iain, i had an 06 Ybr and had the same problem occur until the chain was tightened and lubricated, also with the cain tightened, gear change is much smoother
dansidi
PostPosted: 15:28 - 20 Nov 2013    Post subject: Reply with quote
I found that my YBR was popping out of 2nd for no reason at all and leaving me in neutral. I found that difficult to select neutral and also changing down to first, whether moving or not, was getting difficult and frustrating.
Adjusting the clutch cable fixed all those issues and it just takes 30 seconds.
Slide the rubber guard down from the clutch lever to expose the adjuster nuts. Undo the lock nut on the clutch cable - the big disk shaped nut next to the clutch lever, then turn the adjuster, which sits inside the lock nut. Just try turning it one whole revolution. Tighten the lock nut again and then give the bike a go, see it if has helped. If it did not help try turning the adjuster nut the other way.
It's easy enough to do this while out on a ride, but not while you're moving, OBVIOUSLY.
current bike to first bike: SV650s K3, YBR125, Vespa GT125, Vespa ET4-125, Suzuki CS-50 (!!)
Mod 1 passed 02-11-2012
Mod 2 passed 05-12-2-12
The last post was made 12 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 99.73 Kb
