found a way of getting a cg to go faster!!!!
ts50x0
PostPosted: 16:44 - 20 Dec 2004    Post subject: found a way of getting a cg to go faster!!!! Reply with quote
you need a carb from a very early 1970's model.
it is bigger and these old one apparently do 80mph, you also need the exhaust to go that fast but trust me the carb works!
mr.z
PostPosted: 16:58 - 20 Dec 2004    Post subject: Reply with quote
Yes the older japanese made ones are a bit quicker, i think the carbs were changed for emmissions laws or something when they moved to brazil.
PostPosted: 17:04 - 20 Dec 2004    Post subject: Reply with quote
Really doubt you will get 80 out of one. That is quicker than the CB125S, the sportier ohc engined Honda single from the 1970s.
sickpup
Old Timer
PostPosted: 22:05 - 20 Dec 2004    Post subject: Re: found a way of getting a cg to go faster!!!! Reply with quote
That would be the bigger carb off of the CG185. If you do the big bore and fit the carb 80ish is possible. As far as I know it uses the same exhaust, at least the big H don't list a different one.
ts50x0
PostPosted: 23:16 - 20 Dec 2004    Post subject: Reply with quote
all i know is that the 1970 cg125 has a bigger carb and it makes a brazilian cg go faster
juggla
skim the head , gas flow the head .. done
ts50x0
PostPosted: 23:18 - 20 Dec 2004    Post subject: Reply with quote
i think my way is a it eaier
gsxrboy
PostPosted: 18:05 - 22 Dec 2004    Post subject: Reply with quote
I have an even easier way, it involves a car and a piece of rope.... Confused
Guest
PostPosted: 18:45 - 22 Dec 2004    Post subject: Reply with quote
Or a very high cliff Wink
ts50x0
PostPosted: 22:01 - 22 Dec 2004    Post subject: Reply with quote
or put it in the back of a van.
yes ive heard them all before! Rolling Eyes
dodsi
Dirty Carny
PostPosted: 01:23 - 23 Dec 2004    Post subject: Reply with quote
I have an even better way...
pass test...buy bigger bike!
sorted
Jrod
Page 3 Girl
PostPosted: 02:32 - 23 Dec 2004    Post subject: Reply with quote
But that won't make a CG go faster will it now. Razz
ts50x0
PostPosted: 12:13 - 23 Dec 2004    Post subject: Reply with quote
thank you zxr, i have a cg for a yewar as i need to get a no claims bonus.
i am taking lessons but i still wont be able to afford insurance on a bigger bike!
this whole topic was how to get a CG to go faster not how do I go faster. Rolling Eyes
BlueNinja
PostPosted: 15:08 - 23 Dec 2004    Post subject: Reply with quote
Rag it to the max, that makes it fast.. I got 62 mph up a slight hill on an SR125 by giving it some. Rebuild the engine once a year, give it propper oil.. itll be fast enough for a learner..
Kye
PostPosted: 19:32 - 23 Dec 2004    Post subject: Reply with quote
Nothing, is ever fast enough for a learner Razz
kasandrich
PostPosted: 22:06 - 25 Dec 2004    Post subject: Reply with quote
Yes it is, its just that they are not experienced enough to realise it Wink Wink Wink
Richard
CBR1000FM
whymore?
PostPosted: 01:43 - 02 Jan 2005    Post subject: Reply with quote
sickpup said "the bigger carb off of the CG185. If you do the big bore and fit the carb"
how big is the big bore 'cos +1mm doesn't make any difference to a CG. where do you find a CG185 and how old are they?
what is skimming the head or gas flow(ing) the head by the way? is this possible for a CG?
Scooby
Scrappy Doo
PostPosted: 01:49 - 02 Jan 2005    Post subject: Reply with quote
You could buy a mph to kph convertor, then it will do 80 easily.
PostPosted: 12:16 - 02 Jan 2005    Post subject: Reply with quote
Don't think the CG185 was ever imported to the UK. There was the XL185 which used basically the same engine as the CB125S, but that would be 20+ years old. The CB is an OHC engine while the CG is a pushrod engine so I very much doubt the barrels can be interchanged.
Skimming the head is normally done to make it flat again, but otherewise to increase the compression ratio.
Gas flowing is cleaning up and reshaping the ports to flow better.
Both could be done to the CG.
At the end of the day the CG is not going to produce large amounts of power or a high top speed. The CB125S, its sportier brother, would barely do over 70.
Mister James
I want to believe!
PostPosted: 12:49 - 02 Jan 2005    Post subject: Reply with quote
Well played sir!
sickpup
Old Timer
PostPosted: 03:46 - 03 Jan 2005    Post subject: Reply with quote
Honda built a CG185. I think it used the same piston as the XL.
cliff
Doctor Sicknote
PostPosted: 12:43 - 03 Jan 2005    Post subject: Reply with quote
Just gimme a couple of bongs and you'll get one!
Sweet reggae music.
PostPosted: 13:13 - 03 Jan 2005    Post subject: Reply with quote
I have had a quick Google and can find no mention of it anywhere. There is also nothing in the David Silver Spares catalogue.
There is the CD185 but that was a twin.
whymore?
PostPosted: 20:38 - 03 Jan 2005    Post subject: Reply with quote
I think we're flogging a dead horse here
the XL185 has an OHC, the cg is a pushrod
sodding about with a cg basic spec will mean upgrading the brakes and carbs too
and it'll make it less competitive to insure
for only 60cc more? I'd rather go buy a Benley 200 (are they still made new in the far east, perhaps a bit damply now?) or a 250cc if I was feeling rich
still if there's a working example of an improved cg out there, I'd like to know about it
you can type TYPEWRITER and PROPERTY using the top line of a typewriter only,but what can you type only using the others?
Aikman666
PostPosted: 18:04 - 06 Jan 2005    Post subject: Reply with quote
I think i may know what you mean. The manifold where the carb meets up with the engine is probably the wrong size. This is often a technique used by companies to restrict bikes. You can tell if there are completely clean bits on either of the connecting pieces of metal. If there is simply draw the line of it on the carb and file it down. This might be why the other carb makes the bike faster, or not BUT for gods sake if you do file down the manifold remember to remove and clean ALL of the swarf and filings, if those get into your piston they will grind along the cylinder walls and cause a loss of compression Very Happy
Will work for petrol
My Design Blog
The last post was made 21 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 124.82 Kb
