| Mattyboi |
 Mattyboi L Plate Warrior
 Posted: 23:57 - 21 Nov 2013 Post subject: THINK YOU KNOW ABOUT BIKES? HERES ONE FOR YOU ALL!!!! |
I have a electrical fault with my speedo lights, i have replaced all bulbs as this bike is a project and needed some of them work (i think the other connectors need new ones) but basically all of the light stay on when the ignition is set to full or (engine on and lights on). So for example i put the ignition to the third position and all the speedo lights, light up including the oil, indicators, the full beam, the engine temp, the fuel light.
I know for a fact they shouldn't all light up when the ignition is all the way on. Now i will have a look tomorrow in the day light, but i don't fancy re-wiring the speedo light wires or having to strip them out and replace them, could this be a problem with some relay that shows the lights to be on when they need to, i.e the fuel when its low or the oil when its low.
When the ignition is at the second position though (engine on but not headlights) none of the lights show up even the indicators when i switch them on, there is nothing.
Now my oil is at its full, my fuel is full, my full beam is showing on even when full beam is on dipped and my engine would be cold but all the lights stay on.
Surely at least the indicator speedo light should flash when indicators are on but they just stay on, even when indicators are off. The only other thing i can think if is the brake switch is missing which im replacing next week after re-building the master cylinder i realised it had no brake switch, would this make the speedo lights short out or affect the connection?
Sorry for the vague crappy description of my problem but it all i could explain it as.
Thanks, Matt |
| soforene |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 soforene Nearly there...
| Mattyboi |
| Raffles |
 Raffles World Chat Champion
| soforene |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 00:13 - 22 Nov 2013 Post subject: |
Are you Polish? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| soforene |
| Mattyboi |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| sickpup |
 sickpup Old Timer
| DMCpro |
 DMCpro Traffic Copper
 Posted: 01:16 - 22 Nov 2013 Post subject: Re: THINK YOU KNOW ABOUT BIKES? HERES ONE FOR YOU ALL!!!! |
| Mattyboi wrote: | I have a electrical fault with my speedo lights, i have replaced all bulbs as this bike is a project and needed some of them work (i think the other connectors need new ones) but basically all of the light stay on when the ignition is set to full or (engine on and lights on). So for example i put the ignition to the third position and all the speedo lights, light up including the oil, indicators, the full beam, the engine temp, the fuel light.
Thanks, Matt |
Trace all your wires back using a wiring diagram if it checks out ok dirty connections (inside clocks) or dirty earth somewhere. Sounds a simple problem but it was the way you asked it. That's why no one answered unless taking the piss. If you can take on a project bike but can't problem solve basic problems maybe you should reconsider taking projects on. ____________________ Honda CB-1, TS125X
VW Golf Estate |
 Posted: 01:21 - 22 Nov 2013 Post subject: |
Other than the over-compensating for a small penis, shouty topic title and total failure to say what bike he has. Is there another reason everyone is jumping on this guy and not telling him he has a bad earth? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| moonzoomer |
 moonzoomer World Chat Champion
| Clutchy |
 Posted: 02:20 - 22 Nov 2013 Post subject: |
Sounds like your subframe is twisted...
Probably because none of us know anything about bikes.
In fact why is it called BCF? I thought this forum was '' we don't know anything about bikes anonymous''
That's why you joined right? ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| misscrabstick |
 misscrabstick Crazy Courier
The last post was made 12 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
