| Global_Mongrel |
 Global_Mongrel L Plate Warrior
| map |
 map Mr Calendar
 Posted: 10:33 - 22 Nov 2013 Post subject: |
Is it in gear?
Is it in gear with sidestand down?
Have you tried WD40 in the kill switch?
There will have been a tilt sensor that'd killed the electronics. You need to do a google and check this is ok/reset.
Have you tried jumping it from another 12v battery/power pack.
You might have damaged the battery in the fall. Plus this time of year with it being cold doesn't do a so-so battery any favours.
I'd check battery first.
Please post progress/fix as I'd be interested.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Matt B |
 Matt B World Chat Champion
| misscrabstick |
 misscrabstick Crazy Courier
| chris-red |
 - Super Spammer
 Posted: 17:21 - 22 Nov 2013 Post subject: |
Apparently there was a recall of ST1100's due to the tilt switch failing...
Found this which suggests a way to bypass it to see if that's the problem...
"> I have had a similar problem. The bank angle sensor on my '93 failed. The
> bank angle sensor connector is mounted to the back of the instrument
> cluster. Only windshield, black cover above headlight and gray panel under
> windshield only needs to be removed to gain access to back of instrument
> cluster. It was a long time ago, but if I remember correctly, I jumped the
> red and green wires together(at the connector), this will bypass the
sensor
> and supply power to the circuit. I rode with the sensor bypassed for 2
weeks
> until the new one came in. Good luck......
https://www.mail-archive.com/st1100-digest@yucca.anv.net/msg00044.html |
| Global_Mongrel |
| Marmalade |
 Marmalade World Chat Champion
 Posted: 11:10 - 24 Nov 2013 Post subject: |
Just in case, for the future. If you drop the bike with ignition on, once back upright you need to turn off the ignition and turn it back on to reset the tilt switch or it will just turn over and not start.
They can go faulty and are a pain in the arse to change, behind the fairing on the offside, screwed to the fairing subframe just above where the mirror is. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| evoboy |
 evoboy World Chat Champion
 Posted: 22:05 - 24 Nov 2013 Post subject: |
I had an ST1100 in recently that was suffering from charging problems while riding the bike.
Swapped the reg/rec for a working used item, still the same. After digging deeper, it turned out the alternator had a crack in the casing!
Was only putting out enough power to run the engine and lights, but once the heated grips were on, it would discharge the battery.
Looks like a common problem, been as there are a few used parts on ebay with cracks in the cases!
Posting for future reference  ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Marmalade |
 Posted: 22:43 - 24 Nov 2013 Post subject: |
| evoboy wrote: | I had an ST1100 in recently that was suffering from charging problems while riding the bike.
Posting for future reference  |
They are about £500 from honda. you can get them recon but not if the cases are cracked.
ACF50 sprayed on when it's cold should help it to not rust and crack. It is mostly caused by bikes left for periods unused, the magnets rust, expand and cause the cracking. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| misscrabstick |
| tatfan |
 tatfan Nitrous Nuisance
| Marmalade |
 Posted: 16:58 - 11 Dec 2013 Post subject: |
Mine doesn't get a chance to seize, apart from the acf50 i cover it in, I do 60k a year on them.
I find that if you remove the swing arm, tank and all associated bits it is a piece of cake to change.
Done a couple on other peoples bikes. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| misscrabstick |
 Posted: 19:26 - 11 Dec 2013 Post subject: |
That really sucks! what is the best way to spray mine with some ACF stuff? what needs to come off to get to it? paranoid now.  |
The last post was made 12 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
