Increasingly difficult to wheel around. - Now fixed.
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
hmmmnz
PostPosted: 08:03 - 10 Dec 2013    Post subject: Reply with quote
tyre pressures, wheel bearings, heavy oil dragging, front pads?
the humans are dead
I kick arse for the lord
Clutchy
PostPosted: 08:10 - 10 Dec 2013    Post subject: Reply with quote
OP lack of muscle?
dydey90
PostPosted: 08:14 - 10 Dec 2013    Post subject: Reply with quote
It's probably because you welded the front sprocket on.
Formerly known as
P.
PostPosted: 08:23 - 10 Dec 2013    Post subject: Reply with quote
Start of September, maybe they've just got dirt around the pistons and you haven't cleaned them. I know you haven't. Laughing
Formerly known as
P.
PostPosted: 09:03 - 10 Dec 2013    Post subject: Reply with quote
Not be a retard.
Remove caliper, remove pads, push pistons out a tiny bit more using the brake lever, clean the pistons, push back in clean the shit off the caliper, refit pads, refit caliper, done.
Given that you ride a lot and probably all weathers, the calipers might start to gum up a fair bit, cleaning is the best bet.
CaNsA
PostPosted: 09:05 - 10 Dec 2013    Post subject: Reply with quote
Can you not use the power of the R6 to drag it around?
Skudd
PostPosted: 09:07 - 10 Dec 2013    Post subject: Reply with quote
A bit of WD40 on the brake discs will help free them.
Skudd
PostPosted: 09:20 - 10 Dec 2013    Post subject: Reply with quote
MilfHunter wrote:
The problem isn't the dis[c] is it though.
You could of at least said the calliper and I may have believed it. Sleeping
Just take the calliper off front and back.
Formerly known as
P.
PostPosted: 09:36 - 10 Dec 2013    Post subject: Reply with quote
_Iain_ wrote:
Two bolts, I'm fairly confident even you cant fuck this one up Laughing
Hand
Last time, "he didn't touch it" and it was still fucked beyond redemption. I'd rather give Stevie Wonder some throwing knives and stand 2 feet in front of him than let him touch the brakes.
gbrand42
PostPosted: 09:42 - 10 Dec 2013    Post subject: Reply with quote
I think the wheel has to come off to get the rear caliper off a Varadero. Plenty of scope for fuck-upperage.
Off for some popcorn
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
Skudd
PostPosted: 09:48 - 10 Dec 2013    Post subject: Reply with quote
You need to take the pistons out to clean them otherwise you are just pushing the muck back in. Take the callipers off, leave the brake pads in the calliper and pump until they are closed together, the take the pads out and pump again till the pistons come out, you can use mole grips to help them come out the rest of the way. Just make sure that the pistons are fitted properly in the first place. There should be a solid flat surface facing outward. Some pillocks put them in the wrong way and have the open bit facing out, the hollow bit is where the brake fluid goes.
dydey90
PostPosted: 09:57 - 10 Dec 2013    Post subject: Reply with quote
MilfHunter wrote:
a toothbrush what has remnants of aqua fresh on does it matter?
This made me chuckle Laughing
davebike
PostPosted: 10:02 - 10 Dec 2013    Post subject: Reply with quote
Yes rear wheel has to come out to get the calliper off
Far from a easy brake to sort I done a few Very Happy
Unless you the OP are more capable than you sound take it to a Pro
Brakes are not a good place to muck up
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Skudd
PostPosted: 10:18 - 10 Dec 2013    Post subject: Reply with quote
MilfHunter wrote:
I've decided to take it to the garage and part with £10 for it done properly.
£10 Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Islander
PostPosted: 10:21 - 10 Dec 2013    Post subject: Reply with quote
I think that's a typo - he meant 5 ponds. AND He's got the R6 to run around on while it's in there. Mr. Green
PostPosted: 10:35 - 10 Dec 2013    Post subject: Reply with quote
Skudd, you realise that if you succeed in actually deading him, we won't get to enjoy any more of these classic threads? Tut Tut
Skudd
PostPosted: 10:54 - 10 Dec 2013    Post subject: Reply with quote
I could always help him do the repairs. Wink
The last post was made 12 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 132.83 Kb
