Suzuki ts 125 watercooled wiring
Ashboy18
PostPosted: 16:15 - 13 Dec 2013    Post subject: Suzuki ts 125 watercooled wiring Reply with quote
Hi i have bought a suzuki ts 125 for some off roading but needs rewiring does anyone know what wire goes where if looked for manual and forms cant find nothing apart from one on here which is confusing
WD Forte
PostPosted: 16:36 - 13 Dec 2013    Post subject: Reply with quote
This one?
It says TS/TC125 and is pretty straightforward
https://i675.photobucket.com/albums/vv118/hmmmnz2/suzuki/tstc125.jpg
bikers smell of wee
Ashboy18
PostPosted: 16:52 - 13 Dec 2013    Post subject: Reply with quote
Have you got a colour coded one cheers and is it anyway off making some of switch to start it up and cut out
poleposition
PostPosted: 18:14 - 13 Dec 2013    Post subject: Reply with quote
come again?
Theres a question in there somewhere..i'm sure of it.
Ride it like you stole it!
Ashboy18
PostPosted: 18:45 - 13 Dec 2013    Post subject: Reply with quote
Yes but it's very confusing they saying its one thing then another
Robby
Dirty Old Man
PostPosted: 18:58 - 13 Dec 2013    Post subject: Reply with quote
If you're planning on making a complete wiring loom from scratch, don't. You'll spend more on parts than you would buying a brand new one from Honda.
If it's just for offroading, work out which bits of the loom you need and draw your own wiring diagram with just those bits in. Then open up your existing loom, remove the unnecessary bits, and fix any broken bits.
This is not a quick, easy or clean job. Once your existing loom is untaped and spread out, it will cover your living room floor.
Ashboy18
PostPosted: 19:06 - 13 Dec 2013    Post subject: Reply with quote
I have got no wiring loom all I got is Cdi, stator , coil that's all I wanna know is what wire goes where and how can I make an on and off switch the last owner made one out a low and high beem switch but it's un a muddle and pretty hard to explain I shall upload a few pics first thing in the morning so you know where I am coming from cheers
Robby
Dirty Old Man
PostPosted: 19:13 - 13 Dec 2013    Post subject: Reply with quote
No need to upload pics. Get a wiring loom, a cheap one will come up on ebay.
Making a wiring loom from scratch using an old one as a template is a thankless task in itself. Making one from scratch with no reference points is going to end up with a lot of confusion and wasted wire.
WD Forte
PostPosted: 19:31 - 13 Dec 2013    Post subject: Reply with quote
the above diagram already has the colour codes on it
A bare bones/ignition only system for off road use is easy
all you need is follow the hacked diagram below
what could be simpler?
https://i115.photobucket.com/albums/n302/reggiecx/ts125ign_zps42dd63a6.jpg
bikers smell of wee
hmmmnz
PostPosted: 23:16 - 13 Dec 2013    Post subject: Reply with quote
didnt he say he had a cdi?? and water cooled,
so it will be a 12volt diagram not 6, and have a cdi and fan and all tht shit,
ill have a search through my diagram and see what i can find
the humans are dead
I kick arse for the lord
WD Forte
PostPosted: 23:51 - 13 Dec 2013    Post subject: Reply with quote
Yeah that 6v battery makes it kinda old dont it?
how about this one?
https://i1341.photobucket.com/albums/o743/pitbiker1987/TS2501_zps16162a96.jpg
from this thread
https://www.bikechatforums.com/viewtopic.php?p=3518796
If thats the right one its a bit more involved as you'll need DC power for the power valve, this means using the regulator and battery.
I'd keep the temp gauge and oil level switch too
but easy enough if you can follow a wiring diagram
bikers smell of wee
hmmmnz
PostPosted: 01:57 - 14 Dec 2013    Post subject: Reply with quote
if i remember rightly they were essentially just rm125's
so should be able to slim it don quite a bit, the rm's didnt have any batterys
the humans are dead
Ashboy18
PostPosted: 13:43 - 15 Dec 2013    Post subject: Reply with quote
Mine aint got a battery and it was started before so why do i need a new wiring loom? I got pic of the wires now from the stator to cdi
Ashboy18
PostPosted: 19:36 - 16 Dec 2013    Post subject: Reply with quote
[img][/img]
The last post was made 12 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 78.24 Kb
