96 cbr 600f3
weezy416
PostPosted: 16:23 - 13 Dec 2013    Post subject: 96 cbr 600f3 Reply with quote
i just bought my bike 2 weeks ago and last week i went to go ride, it takes about two trys it starts, it ran for about 40 seconds and bougs out and then i tryed to start it it dont start, so i replace the sparkplugs yesterday it takes 2 tryes and it runs. i let it run for about an hour or to go and try to start it and it backfires and then now dont even want to turn over ---please help----
1cyl
PostPosted: 21:56 - 13 Dec 2013    Post subject: Re: 96 cbr 600f3 Reply with quote
Fuel issue? Sounds like it would probably benefit from a good carb service. have you tried riding it, maybe a good spanking will help?
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Clutchy
PostPosted: 22:40 - 13 Dec 2013    Post subject: Reply with quote
You left it idling for an hour? Plugs are probably fouled!
weezy416
PostPosted: 15:33 - 14 Dec 2013    Post subject: Re: 96 cbr 600f3 Reply with quote
no i havent tryed to ride it, it was snowing and tooo cold lol
weezy416
PostPosted: 15:36 - 14 Dec 2013    Post subject: Reply with quote
(clutchy) yea i left it running for an hour and i had fuel stabilizer in the gas also, so i have to change the plugs again?
Clutchy
PostPosted: 18:28 - 14 Dec 2013    Post subject: Reply with quote
Well I'd try and clean them at least.
Paddy Blake
PostPosted: 20:03 - 14 Dec 2013    Post subject: Reply with quote
It is not good to leave a bike run for an hour while not moving.
It might have over heated.
skatefreak
PostPosted: 08:25 - 16 Dec 2013    Post subject: Reply with quote
It has a fan over the rad which will draw air through the rad if the bikes not moving to stop the engine from overheating however if that fan works is anyone's guess.
If the fan didn't work I would expect the bike to overheat and eventually blow off a coolant pipe or something...
As he says the bike backfired and now wont even turn over is somewhat worrying.
Get the spark plugs out and give them a clean.
Whilst the plugs are out, put the bike in gear and push it along to make the the engine turns over okay.
Get a new battery and try turn it over with the starter motor.
This will rule out catastrophic engine failure (in case that backfire was a con rod letting go) and confirm if the starter is still working.
Get back to us.
If everything checks out to this point then maybe check out the carbs.
They may just need draining or a strip down and clean.
-Jvr
The last post was made 12 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 56.55 Kb
