Sand blasting to remove rust?
loply
PostPosted: 19:34 - 25 Dec 2004    Post subject: Sand blasting to remove rust? Reply with quote
Hi folks,
I bought my dad a compressor for some airbrushing for christmas, and am considering buything the following:
https://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=SV5IYMXQDDQV3CJO2C1SJ0Q?id=94223&ts=02898
In order to remove rust from my bike, and other items. Parts of my bike that are rusty include side stand, fairing mounts, horn, etc. Nothing like the frame or forks, just perhiperals.
Anyway what I want to know is:
Whats the difference between Aluminium Oxide beads, and Glass beads? Whats best for my needs?
Annd... will a 1.5hp/6.3cfm/170ltrm/115psi compressor be enough?
Also, can you recollect and reuse the shot if you do it into a clean cabinet of some kind?
Yamaha SZR660 Caution to the wind, the throttle pinned!
loply
PostPosted: 19:39 - 25 Dec 2004    Post subject: Reply with quote
Oh, and MERRY CHRISTMAS Very Happy Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 19:42 - 25 Dec 2004    Post subject: Re: Sand blasting to remove rust? Reply with quote
YEAH RIGHT
Alternative motive!
loply
PostPosted: 19:59 - 25 Dec 2004    Post subject: Reply with quote
haha, no honestly, and he gave me some money so now im deciding how to spend it... =P
Big Pete
PostPosted: 21:33 - 25 Dec 2004    Post subject: Reply with quote
aluminium oxide is coarser, harder abrasive, ok for steel, not good on ally. The glass beads are softer and are excellent on ally.
Yes you can colect the abrasive and reuse it, but you really need to do it inside a cabinet with a clear window and a pair of built in gloves.
The specs for the gun should give a cfm requirement which you can compare against your compressor, however, if you have a big air receiver (storage tank) you can use the gun in short bursts even if your compressor is marginal.
Trust me, I`m an engineer
GarageOfPower.co.uk
loply
PostPosted: 21:49 - 25 Dec 2004    Post subject: Reply with quote
Compressor isnt quite up to the spec (1.5hp intead of 2hp, and 25ltr instead of 50ltr)... but i figure itll still work for small parts or small bursts like you say?
How essential is a cabinet? Will I be fine just holding the part with some long pliers and wasting the spray?
PostPosted: 00:43 - 26 Dec 2004    Post subject: Reply with quote
I have a 7cfm compressor which runs up to 115psi (kicks in again at 80 I think).
It does work for cleaning up some smaller components. Gets defeated by soft paint though.
You can just waste the material but it will get expensive. What I did was use an old table in the garage and use thick polythene sheet around the bottom to build an enclosure to catch the grit so I could reuse it (just left a flat at the front to reach in through). Works OK (especially as I would have the table anyway).
One thing I would advise is to use some dust masks (as well as goggles) to stop you breathing all the rubbish in. Otherwise you will be coughing the stuff up for days afterwards.
One other thing that can be useful is a spot blaster. These are designed for cleaning very small areas but they do recirculate the grit themselves. Useful for cleaning up small components.
WildGoose
White Van Man
PostPosted: 01:49 - 26 Dec 2004    Post subject: Reply with quote
did an anti corrosion and husbandry course at work, used a blaster type thing to remove corrosion from various components and bits of metal, works a treat
just a thought that you will probly need to treat the metal afterwards otherwise there is nothing to stop it corroding again straight away, i cant remember the details off the top of my head (too much alcohol) but i believe most of it can be bought in your average B&Q homebase type deal, and comes in the form of a jelly or solvent, obviously depending on the metal/material you are treating
..just extends the ability of the material to resist corrosion for longer
ZRX61
Victor Meldrew
PostPosted: 04:43 - 26 Dec 2004    Post subject: Reply with quote
Coughing up stuff will be the least of his problems when silicosis wipes out his lungs in a few years if he doesn't use a mask, get one with N99 on it (or at least a N95), not those dumbass ones that are the same shape/size but about as much use as a kleenex for filtering the shit out.
Use glass beads, not aluminum oxide unless you plan on knocking 50 years of barnacles off the bottom of HMS Belfast.
You can buy bench top cabinets fairly cheaply, put a layer of clear tape on the inside of the glass & change it when it gets opaque.. 2in wide sellotape works well, saves having to replace the glass every month or so.
Most of the larger blasting cabinets use a minimum 10hp 120gal compressor & flow about 30cfm.... The one you got yer dad will be worn out in a week...
nick.h
PostPosted: 10:42 - 26 Dec 2004    Post subject: Reply with quote
If your using the sand blaster thingy only on a few items, does it matter if you waste the glass beads?
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
loply
PostPosted: 12:20 - 26 Dec 2004    Post subject: Reply with quote
haha
Okay, how quickly do you use sand on these things? will 1.5kg do to remove rust from about 10 bolts, a sidestand, a handful of brackets and mounts, and some footpegs?
How exactly does a spot blaster manage to reuse the sand automatically?
loply
PostPosted: 12:23 - 26 Dec 2004    Post subject: Reply with quote
P.S Thanks for all the replies and help.
loply
PostPosted: 14:20 - 26 Dec 2004    Post subject: Reply with quote
If anybody is interested ive just been in the garage and made a complete list of corroded parts:
  • Nosecone fairing mounting bolts
  • Front brake caliper banjo bolt
  • Front brake caliper bleed bolt
  • Front brake resevoir mounting bolts
  • Horn and horn mounting bracket and bolt
  • Front fender mounting bolts
  • Mirror holding bolts
  • Fuel tank front mounting nut and washer
  • Head bearing nut and cover
  • Yoke tensioners/mounting bolts
  • Lever mounting bolts for clutch lever and brake lever
  • Side fairing mounting brackets (internal)
  • Rearset mounting bolts and foot lever mounting bolts (both sides)
  • Rear brake lever banjo bolt
  • Rear brake brake-light switch connector
  • Sidestand, sidestand spring and bolts
  • Pillion footpegs mounting brackets + bolts
  • Exhaust hanger bolt
  • Rear subframe mounting bolts
  • Rear axle nut and rear axle bolt-head
  • Rear brake caliper banjo bolt
  • Chain tensioner bolts and nuts
Quite hefty, im not even sure how to get some of them off. Doh. Im sure ill get it all done though.
gammamanuk
PostPosted: 14:34 - 26 Dec 2004    Post subject: Reply with quote
Woudlnt some coarse wet and dry be easy and better Laughing
loply
PostPosted: 14:37 - 26 Dec 2004    Post subject: Reply with quote
With a list that long? I know its winter but cmon!
ZRX61
Victor Meldrew
PostPosted: 16:24 - 26 Dec 2004    Post subject: Reply with quote
ok, your basically wasting your time blasting all those little parts. What are you going to do to stop the part rusting once they have been cleaned? you have 2 choices:
#1: Cad plate.... there are 2 common types:
Cad #1 (silver)
Cad #2 (yellow/gold)
There's also a olive green version that Kawasaki use.
Choice #2: Paint em.
Blasting all those little bits will be a PITA & the easiest way to do it is put a handful in a sieve that ya steal from yer mums kitchen otherwise ya gojng be blasting parts all over the place.
What would be a LOT easier is to use acid & just dip the parts. The stuff ya use is Muracic Acid which is the stuff they use in swimming pools & can be found at any B&Q type place etc. Y ause about 20% acid to 80% water mix & just dip the parts in it (using the sieve again) It only takes afew seconds to remove the rust (& the original Cad plate) Then ya rinse the parts in clean water & spray the lot with WD40. Shouldn't cost more than about 30 quid to get all the parts Cad plated.
Banjo bolts: kinda critically sized, just replace em.
DO NOT pour the acid on the lawn after yer done with it..... makes a good drain cleaner tho...
loply
PostPosted: 16:48 - 26 Dec 2004    Post subject: Reply with quote
is cad plating entirely neccessary? will just regular coats of WD40 or other metal protector do the trick as good?
or paint
ZRX61
Victor Meldrew
PostPosted: 18:13 - 26 Dec 2004    Post subject: Reply with quote
Yes, unless you want to go thru the entire process again everytime it rains or the bike gets a bit damp. The reason it's rusting now is because the original paint/plating failed...
Nope, WD40 will protect the parts for maybe a day, the idea behind putting WD40 on the parts after they have been blasted/acid dipped is to stop them rusting on the way to the plating shop
loply wrote:
or paint
It will chip as soon as you use a spanner or screwdriver on the fastener & then the entire rusting process starts again....
The only other cure is Stainless fasteners.... or Parkerize (black coating done by acid dipping) the original steel fasteners
loply
PostPosted: 18:31 - 26 Dec 2004    Post subject: Reply with quote
Can you parkerize or cad plate in a DIY fashion?
I guess Ill just clean the parts up and have them cad plated if not. Bit of a bastard though since theres so many things I would really like to remove the rust on.
PostPosted: 23:45 - 26 Dec 2004    Post subject: Reply with quote
The Frost catalogue does list kits for DIY plating. No idea how good the results are.
dandit
PostPosted: 02:22 - 27 Dec 2004    Post subject: Reply with quote
Cad #1 (silver)
or dont be such a tight arse and buy some new bolts and just sand the bigger bits Laughing
WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo
Big Pete
PostPosted: 18:34 - 27 Dec 2004    Post subject: Reply with quote
dont bother doing bolts, buy new (stainless)ones. Home plating of bolts is a bad plan for anything important as there is a serious risk of hydrogen induced cracking. Also, blasting them will damage the thread form. Even if you get the bolts professionally replated you will struggle to get Cadmium plating in the UK, the enviromental problems mean very few platers still use it. Bright zinc, or yellow passivated zinc are easier to get and look very similar. Stainless is the only way to fly, but alloy or titanium are ok for fairings and non safety critical parts. Never use alloy bolts for things like calipers, bar mounts etc, and only use titanium if you are racing and replace the bolts every season.
GarageOfPower.co.uk
ZRX61
Victor Meldrew
PostPosted: 04:06 - 28 Dec 2004    Post subject: Reply with quote
One other option:
Dump the rusty bits in a bucket of Molasses for a few days... strips the rust right off. (yes really)
The last post was made 21 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 121.6 Kb
