| loply |
 loply World Chat Champion
 Posted: 19:34 - 25 Dec 2004 Post subject: Sand blasting to remove rust? |
Hi folks,
I bought my dad a compressor for some airbrushing for christmas, and am considering buything the following:
https://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=SV5IYMXQDDQV3CJO2C1SJ0Q?id=94223&ts=02898
In order to remove rust from my bike, and other items. Parts of my bike that are rusty include side stand, fairing mounts, horn, etc. Nothing like the frame or forks, just perhiperals.
Anyway what I want to know is:
Whats the difference between Aluminium Oxide beads, and Glass beads? Whats best for my needs?
Annd... will a 1.5hp/6.3cfm/170ltrm/115psi compressor be enough?
Also, can you recollect and reuse the shot if you do it into a clean cabinet of some kind? ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| loply |
 Posted: 19:39 - 25 Dec 2004 Post subject: |
Oh, and MERRY CHRISTMAS  ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Sparks! |
 Sparks! Sir Tart-a-lot
| loply |
 Posted: 19:59 - 25 Dec 2004 Post subject: |
haha, no honestly, and he gave me some money so now im deciding how to spend it... =P ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Big Pete |
 Big Pete Spanner Monkey
| loply |
 Posted: 21:49 - 25 Dec 2004 Post subject: |
Compressor isnt quite up to the spec (1.5hp intead of 2hp, and 25ltr instead of 50ltr)... but i figure itll still work for small parts or small bursts like you say?
How essential is a cabinet? Will I be fine just holding the part with some long pliers and wasting the spray? ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
 Posted: 00:43 - 26 Dec 2004 Post subject: |
I have a 7cfm compressor which runs up to 115psi (kicks in again at 80 I think).
It does work for cleaning up some smaller components. Gets defeated by soft paint though.
You can just waste the material but it will get expensive. What I did was use an old table in the garage and use thick polythene sheet around the bottom to build an enclosure to catch the grit so I could reuse it (just left a flat at the front to reach in through). Works OK (especially as I would have the table anyway).
One thing I would advise is to use some dust masks (as well as goggles) to stop you breathing all the rubbish in. Otherwise you will be coughing the stuff up for days afterwards.
One other thing that can be useful is a spot blaster. These are designed for cleaning very small areas but they do recirculate the grit themselves. Useful for cleaning up small components.
| WildGoose |
 WildGoose White Van Man
| ZRX61 |
 ZRX61 Victor Meldrew
| nick.h |
 nick.h World Chat Champion
| loply |
| loply |
 Posted: 12:23 - 26 Dec 2004 Post subject: |
P.S Thanks for all the replies and help. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| loply |
 Posted: 14:20 - 26 Dec 2004 Post subject: |
If anybody is interested ive just been in the garage and made a complete list of corroded parts:
- Nosecone fairing mounting bolts
- Front brake caliper banjo bolt
- Front brake caliper bleed bolt
- Front brake resevoir mounting bolts
- Horn and horn mounting bracket and bolt
- Front fender mounting bolts
- Mirror holding bolts
- Fuel tank front mounting nut and washer
- Head bearing nut and cover
- Yoke tensioners/mounting bolts
- Lever mounting bolts for clutch lever and brake lever
- Side fairing mounting brackets (internal)
- Rearset mounting bolts and foot lever mounting bolts (both sides)
- Rear brake lever banjo bolt
- Rear brake brake-light switch connector
- Sidestand, sidestand spring and bolts
- Pillion footpegs mounting brackets + bolts
- Exhaust hanger bolt
- Rear subframe mounting bolts
- Rear axle nut and rear axle bolt-head
- Rear brake caliper banjo bolt
- Chain tensioner bolts and nuts
Quite hefty, im not even sure how to get some of them off. Doh. Im sure ill get it all done though. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| gammamanuk |
 gammamanuk Scooby Slapper
 Posted: 14:34 - 26 Dec 2004 Post subject: |
Woudlnt some coarse wet and dry be easy and better  |
| loply |
 Posted: 14:37 - 26 Dec 2004 Post subject: |
With a list that long? I know its winter but cmon! ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| ZRX61 |
| loply |
 Posted: 16:48 - 26 Dec 2004 Post subject: |
is cad plating entirely neccessary? will just regular coats of WD40 or other metal protector do the trick as good?
or paint ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| ZRX61 |
| loply |
 Posted: 18:31 - 26 Dec 2004 Post subject: |
Can you parkerize or cad plate in a DIY fashion?
I guess Ill just clean the parts up and have them cad plated if not. Bit of a bastard though since theres so many things I would really like to remove the rust on. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| dandit |
 dandit Nearly there...
| Big Pete |
| ZRX61 |
The last post was made 21 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
