Rust!
Doomsnite
PostPosted: 15:59 - 30 Dec 2013    Post subject: Rust! Reply with quote
Would rust like on the exhaust below put you off buying a bike or could it come off easily enough? Obviously would try and avoid it but if the price is right!? Cant really see it elsewhere so would have to view it.. anywhere to look out for?
https://i.ebayimg.com/00/s/NzY2WDEwMjQ=/z/um0AAMXQVERSwBhP/$_80.JPG
Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125
CaNsA
PostPosted: 16:08 - 30 Dec 2013    Post subject: Reply with quote
rusty zorst.....
not a problem.
-Matt-
PostPosted: 16:11 - 30 Dec 2013    Post subject: Reply with quote
Looks like its on the side-plate on the front fender too Question Probably just shitty plating. Wouldn't be too concerned if its just surface rust in those areas and not all over the bike, if its a reasonable price.
Acemastr
PostPosted: 16:12 - 30 Dec 2013    Post subject: Reply with quote
yea.. don't buy it if the front plastic fender is rusty, asking for trouble! Wink
2016 Toyota Tacoma Limited
wots
PostPosted: 16:13 - 30 Dec 2013    Post subject: Reply with quote
If it looks better than a brand new CBF 125, it'll be fine Razz
Doomsnite
Its up for a monkey so more than reasonable but makes me wonder of theres anything else wrong. Is surface rust easy to remove ?
wots
PostPosted: 16:17 - 30 Dec 2013    Post subject: Reply with quote
If you are really bothered about aesthetics, I don't think they are expensive to replace. Just clean it up. It'll be fine, especially at that money. MOT&TAX?
Doomsnite
PostPosted: 16:22 - 30 Dec 2013    Post subject: Reply with quote
Has both - tax july mot feb. Not bothered about the looks too much just wonder whats lurking underneath to cause problems.
wots
PostPosted: 16:24 - 30 Dec 2013    Post subject: Reply with quote
From the limited amount I can see, it looks better than the CBF125 I had at a year old.
RhynoCZ
PostPosted: 16:25 - 30 Dec 2013    Post subject: Reply with quote
It's alright, I'd offer the seller a bit less, like 50 pounds, and told him, that it would need some job to be done. Thumbs Up
PostPosted: 16:26 - 30 Dec 2013    Post subject: Reply with quote
Wouldn't bother me, 30 minutes with a wire brush on a drill and some autosol, or don't bother. If the exhaust is rotting, it'll be from the inside out, and you can't see that or determine it from the exterior condition.
Doomsnite
Cheers guys. Probably get snapped up by the time I get to see it now!
mentalboy
PostPosted: 16:27 - 30 Dec 2013    Post subject: Reply with quote
Plenty of elbow grease and autosol will remove surface rust but that exhaust looks like the rust has penetrated the plating. Whilst you may remove the rust you will be left with small breaches in the plating which will have a tendency to keep building up rust.
If aesthetics doesn't concern you too much then give it the best cleaning up you can and then rag it over with linseed oil. This will slow down the further degradation of the plating but once chrome starts peeling there is very little you can do to stop it.
Make mine a Corona.
PostPosted: 16:32 - 30 Dec 2013    Post subject: Reply with quote
At that sort of money, I'd just paint it.
1cyl
PostPosted: 16:43 - 30 Dec 2013    Post subject: Reply with quote
-Matt- wrote:
Looks like its on the side-plate on the front fender too Question .
I think its a reflection of a house.
OP. Thats a 2, on my 1-10 scale of rusty. Buff it up with some autosol like your having an uber wank. And don't worry until its a 7+.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Walloper
PostPosted: 16:46 - 30 Dec 2013    Post subject: Reply with quote
A tin of silver emulsion out of B&Q will do it. Wink
Seriously: It's shit thin chrome finish on steel plate. It will rust even if you clean it off.
It will need autosol or something all the time to keep the 'appearance' bright.
The Chroming process takes time and is labour intensive so to cut corners the OEM uses less chrome and one single dip.
Good chroming involves several dips in various metals and then the chrome layers built up by chroming-grinding-chroming. The just dipped finish is dull and has to be polished/ground to be shiny.
1cyl
PostPosted: 16:53 - 30 Dec 2013    Post subject: Reply with quote
Edit: double post.
Saltire
PostPosted: 17:16 - 30 Dec 2013    Post subject: Reply with quote
I used a thing called Ajax powder on rust on my bike and it worked wonders. Just get a cloth, get it wet and apply the tiniest bit of powder onto the cloth... wipe away the rust and boom.
j.silvs
PostPosted: 17:22 - 30 Dec 2013    Post subject: Reply with quote
Yep! it is defo a reflection of a house. You can see the windows.
-Matt-
PostPosted: 19:29 - 30 Dec 2013    Post subject: Reply with quote
I'm now afraid I need glasses, how on earth did you notice that Shocked
The last post was made 12 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 105.96 Kb
