Making a temporary exhaust gasket
JackDaniels
PostPosted: 11:17 - 02 Jan 2014    Post subject: Making a temporary exhaust gasket Reply with quote
I have purchased a new exhaust for my hornet, what would be suitable for making a temporary exhaust gasket, i have been to my main dealer and ordered a gasket for it. but was wondering if it would be safe to make a gasket out of something to get the pipe fixed up.
https://i42.tinypic.com/2z4meir.jpg
https://i44.tinypic.com/116rg5t.jpg
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
RhynoCZ
PostPosted: 11:28 - 02 Jan 2014    Post subject: Reply with quote
If you have some chimney sealant (putty), you could use it. Definitely DO NOT use silicone. Thumbs Up
JackDaniels
PostPosted: 11:43 - 02 Jan 2014    Post subject: Reply with quote
in terms of putty the only thing i have in the garage is holts gun gum, i suppose i could wait a day or 2 for the honda gasket.
STONEY!
PostPosted: 11:53 - 02 Jan 2014    Post subject: Reply with quote
Tin foil and gun gum will work for a while. Also used old pie tins rolled up for header gaskets which lasted 2 years with no trouble.
Self adhesive foil tape for extractor ducting also works well
RhynoCZ
PostPosted: 12:00 - 02 Jan 2014    Post subject: Reply with quote
The tin foil is gonna burn out in couple of minutes while the engine idles. Thumbs Up
JackDaniels
PostPosted: 12:02 - 02 Jan 2014    Post subject: Reply with quote
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_196275_langId_-1_categoryId_255217#tab3
Would this stuff work ?
PostPosted: 12:19 - 02 Jan 2014    Post subject: Reply with quote
Ever used it? I know of someone who has done considerable mileage with an exhaust bandaged together with tin foil.
RhynoCZ
PostPosted: 12:25 - 02 Jan 2014    Post subject: Reply with quote
If you mean this, then yes.
https://media.thereadystore.com/mktg/blog/tin-foil.jpg
PostPosted: 12:46 - 02 Jan 2014    Post subject: Reply with quote
If you have to ride TBH I probably just wouldn't use anything. Fit it without a gasket and and ride.
JackDaniels
PostPosted: 12:57 - 02 Jan 2014    Post subject: Reply with quote
i have fitted it so i could ride to work today, but it is blowing a fair amount at the join at the bottom. looks better than previous system though.
https://i40.tinypic.com/15wf6kl.jpg
PostPosted: 13:00 - 02 Jan 2014    Post subject: Reply with quote
Why not?
Use silicone. Ordinary, general purpose plumbers silicone. Clag on loads of it.
I use silicone in that application on my own bike. You will need to allow time for it to dry before starting the engine.
Has the added advantage that it's really easy to remove when you want to fit the correct gasket.
PostPosted: 13:42 - 02 Jan 2014    Post subject: Reply with quote
RhynoCZ wrote:
Don't silicone [...] don't use tin foil
I can confirm that both of those have worked for me in the past as temporary bodges may have sold the GPz305 with silicone still in it.
I'm not talking about wrapping tin foil around the joint, I mean folding it into a narrow concertina and then using it inside the joint instead of a proper crush gasket.
Can you expand on your personal experience of them not working?
RhynoCZ
PostPosted: 14:11 - 02 Jan 2014    Post subject: Reply with quote
I just hate silicone. Thumbs Up
So far, I found this (did not work at all):
https://i970.photobucket.com/albums/ae184/RhynoCZ/ZX7R/DSC_0084_zpse495276b.jpg
And this, which was funny, because it started to leak the day I was just about to sell the bike (NC27), it even clogged the jet:https://i970.photobucket.com/albums/ae184/RhynoCZ/Image0746_zps5ccc6660.jpg
AND, the clutch cover on the ZX7R also seems to be sealed with silicone. Mad
EDIT: Also, the funny thing is, that proper seals are cheap, I just don't get it, why would anyone use silicone instead of proper seal. The ZXR didn't even have the seal that goes under the oil cap, oil was just dripping down the clutch cover. It's a simple cheap rubber ring ffs. Rolling Eyes
Benson_JV
PostPosted: 14:43 - 02 Jan 2014    Post subject: Reply with quote
My exhaust never gets all that hot (CBR600FW) so when I want to swap exhaust for the day for MOT and what not I use a cereal box. Cut into strips and wrap. Doesn't seem to burn or anything for me, all it does is create a nice seal. Mr. Green
Islander
PostPosted: 15:14 - 02 Jan 2014    Post subject: Reply with quote
You can also get high temperature silicone specifically designed to seal stove flues. Thumbs Up
PostPosted: 17:54 - 02 Jan 2014    Post subject: Reply with quote
Wrong silicone, it's not the stuff I'm on about.
That's horribly badly applied RTV compound (which is silicone based). I've seen worse. I'll see your carb gasket and raise you one rocker box (yes, oilways).
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image028.jpg
I'm talking about the clear stuff you use in a mastic gun to seal round the edges of your bath. A big fat slug of it all the way round then wipe off the excess.
gavcarter
PostPosted: 17:58 - 02 Jan 2014    Post subject: Reply with quote
Cheap no-brand bathroom sealant from poundland, dries rock hard, scrapes off easily enough when you need it to but makes for a good gasket Wink
Walloper
PostPosted: 18:24 - 02 Jan 2014    Post subject: Reply with quote
It's not tin in tin foil. Razz
RhynoCZ
PostPosted: 18:49 - 02 Jan 2014    Post subject: Reply with quote
Some people just shouldn't be allowed to work on engines. Imagine you'd buy an aircraft with engine like that. Neutral
The last post was made 12 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 120.51 Kb
