what's the best way to take off glue[from carbon fibre wrap]
skikman
PostPosted: 17:23 - 04 Jan 2014    Post subject: what's the best way to take off glue[from carbon fibre wrap] Reply with quote
hi all.ive bought a yamaha fj1200 that has been sprayed matt black and carbon fibre wrap stuck on[badly].im going to pull off wrap and respray.before i start pulling.will there be glue left behind?what's the best way to get it off before sanding?will i need to prime if im going to gloss black it?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:57 - 04 Jan 2014    Post subject: Reply with quote
Nail-varnish stripper.
Triumph Sprint ST 1050
MartQ
PostPosted: 23:54 - 04 Jan 2014    Post subject: Reply with quote
Lighter fluid, zippo type, not aerosol gas - shifts any type of sticky mess and won't melt paint where nail varnish remover probably will.
skikman
PostPosted: 00:09 - 05 Jan 2014    Post subject: Reply with quote
thanks.thats what i was thinking about the nail varnish remover.prob a bit to strong.
PostPosted: 00:55 - 05 Jan 2014    Post subject: Reply with quote
If it's proper vinyl wrap, nothing will be left behind.
Use a hairdrier to heat up the wrap as you peel it off. If you don't, you'll land up picking little pointy strips off one at a time. If you heat it up a little first so it's flexible, you'll be able to slowly peel huge sheets off.
Take this from someone who has personally wrapped his petrol tank with carbon effect wrap then 6 months later peeled it off and replaced it with orange.
TheCatSatOnTh...
PostPosted: 07:21 - 05 Jan 2014    Post subject: Reply with quote
Sick
PostPosted: 11:55 - 05 Jan 2014    Post subject: Reply with quote
TheCatSatOnTheMat wrote:
Sick
It amuses me. It costs about a tenner to change the colour of my petrol tank using cheap vinyl wrap so I try different things periodically. I try to make them as tasteless as possible in order to thumb my nose at the cleaning and polishing brigade.
Wahlberg
PostPosted: 17:46 - 08 Jan 2014    Post subject: Reply with quote
I do vinyling at work and use citrus cleaner - it's non solvent based and smells nicer on your hands than zippo fluid!
If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape! Smile
The last post was made 12 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 56.09 Kb
