| skikman |
 skikman Renault 5 Driver
| Nobby the Bastard |
| MartQ |
 MartQ Two Stroke Sniffer
| skikman |
| stinkwheel |
 Posted: 00:55 - 05 Jan 2014 Post subject: |
If it's proper vinyl wrap, nothing will be left behind.
Use a hairdrier to heat up the wrap as you peel it off. If you don't, you'll land up picking little pointy strips off one at a time. If you heat it up a little first so it's flexible, you'll be able to slowly peel huge sheets off.
Take this from someone who has personally wrapped his petrol tank with carbon effect wrap then 6 months later peeled it off and replaced it with orange. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| TheCatSatOnTh... |
 TheCatSatOnTh... Scooby Slapper
| stinkwheel |
 Posted: 11:55 - 05 Jan 2014 Post subject: |
It amuses me. It costs about a tenner to change the colour of my petrol tank using cheap vinyl wrap so I try different things periodically. I try to make them as tasteless as possible in order to thumb my nose at the cleaning and polishing brigade. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wahlberg |
 Wahlberg Two Stroke Sniffer
 Posted: 17:46 - 08 Jan 2014 Post subject: |
I do vinyling at work and use citrus cleaner - it's non solvent based and smells nicer on your hands than zippo fluid! ____________________ If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape!  |
The last post was made 12 years, 314 days ago. Instead of replying here, would creating a new thread be more useful? |
