Custom washers
Ichy
PostPosted: 21:40 - 05 Jan 2014    Post subject: Custom washers Reply with quote
I'm after a couple of 25.4mm id x 32mm od x 0.5mm washers preferably in aluminium, brass or copper. I've searched the 'net and ebay and cannot find anything near. Is anyone aware of where I might get a couple made? Sizes are not precise and can be a bit bigger.
stu_m
PostPosted: 21:43 - 05 Jan 2014    Post subject: Reply with quote
30x25? https://www.ebay.co.uk/itm/SAW-BLADE-BUSHING-WASHERS-REDUCING-RINGS-SPACER-BUSHES-/360772453458?pt=UK_Home_Garden_PowerTools_SM&var=&hash=item53ffb6c452
Ichy
PostPosted: 21:45 - 05 Jan 2014    Post subject: Reply with quote
Cheers but they are going to be way to thick.
stu_m
PostPosted: 21:46 - 05 Jan 2014    Post subject: Reply with quote
I think your going to really struggle Confused
these any good?
https://www.ebay.co.uk/itm/5-X-24MM-COPPER-SEALING-WASHER-WASHERS-O-D-32mm-KW164-/270974594222?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item3f17582cae
Pete.
PostPosted: 21:49 - 05 Jan 2014    Post subject: Re: Custom washers Reply with quote
I can make those for you, what are your tolerances?
a.k.a 'Geri'
Ichy
PostPosted: 22:09 - 05 Jan 2014    Post subject: Re: Custom washers Reply with quote
Cheers Pete. Tolerance are not critical. the ID needs to be over 25.4 plus 1/2mm is fine. OD is even less important, anywhere between 31 and 33 is good. Laughing Thickness 0.5mm within 0.1?
Pete.
PostPosted: 22:41 - 05 Jan 2014    Post subject: Reply with quote
No worries I'll knock them up tomorrow night.
a.k.a 'Geri'
Ichy
PostPosted: 22:44 - 05 Jan 2014    Post subject: Reply with quote
That's really good of you. Thanks.
Walloper
PostPosted: 23:47 - 05 Jan 2014    Post subject: Reply with quote
No probs mate, they'll cost you 10K Karmas.
PostPosted: 23:59 - 05 Jan 2014    Post subject: Reply with quote
Is other than the thickness these seem to match:-
https://www.amazon.co.uk/Copper-Washer-Sealing-Washers-25-4mm/dp/B00AJ6EOKM/ref=sr_1_13?s=automotive&ie=UTF8&qid=1388962631&sr=1-13&keywords=26Mm+Copper+Sealing+Washer
Grind them down to 0.5mm?
Pete.
PostPosted: 23:00 - 06 Jan 2014    Post subject: Reply with quote
Set of phosphor bronze shims ID 25.4mm OD 31.75mm thickness 0.3mm to 1.1mm in 0.1mm increments tolerance 0.03mm plus a couple intermediates.
a.k.a 'Geri'
Pete.
PostPosted: 23:29 - 06 Jan 2014    Post subject: Reply with quote
Generic lathe-whoring pic 'just because' Smile
Glad for the reason to use it TBH, don't get much opportunity what with work and stuff.
a.k.a 'Geri'
Chalky.
PostPosted: 23:37 - 06 Jan 2014    Post subject: Reply with quote
Nice one Pete. Thumbs Up Karma
Walloper
PostPosted: 23:46 - 06 Jan 2014    Post subject: Reply with quote
I'd ride that little bitch. Thumbs Up
Pete.
PostPosted: 08:00 - 07 Jan 2014    Post subject: Reply with quote
I'd let you on the bike before I let you on my lathe Clobber, and I'd be more upset if someone crashed the lathe too Smile
a.k.a 'Geri'
Walloper
PostPosted: 13:40 - 07 Jan 2014    Post subject: Reply with quote
^^^ Sounds legit. Very Happy
WD Forte
PostPosted: 14:39 - 07 Jan 2014    Post subject: Reply with quote
lathe whoring!
https://l-userpic.livejournal.com/43353041/2497543
Is that a Monarch 10?
Old, circa 1940's but built to very high standard they were
bikers smell of wee
PostPosted: 16:24 - 07 Jan 2014    Post subject: Reply with quote
Well, I'm free whenever buddy Laughing
Pete.
PostPosted: 19:41 - 07 Jan 2014    Post subject: Reply with quote
WD Forte wrote:
lathe whoring!
Yes it's an early 10ee. I was so lucky even finding one in the UK let alone being the only person to bid on it. Best £500 I ever spent.
"...today the Monarch 10EE Precision Toolroom lathe has a well-established reputation as one of the finest small lathes it is possible to buy. "
https://www.lathes.co.uk/monarch/page2.html
a.k.a 'Geri'
Ichy
PostPosted: 10:56 - 11 Jan 2014    Post subject: Reply with quote
Thanks for the help Pete. Absolutely perfect and saved about 20 hours of rework.
The last post was made 12 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 109.53 Kb
