cagiva mito stuck at 7000rpm
badboy2050uk
PostPosted: 21:20 - 27 Dec 2004    Post subject: cagiva mito stuck at 7000rpm Reply with quote
Hey all got a cagiva mito 1991 J reg dont know alot bout bikes but wanna learn it gets stuck at 7000 and pulls back its not restricted but my m8 told me its the power valve and i dont know where this is so anyone willing to help me pls thx.
gsxrboy
PostPosted: 23:53 - 27 Dec 2004    Post subject: Reply with quote
Is this in every gear? uphill and downhill?
Always try to give as much information as you can to aid an easy fix!! Very Happy I dont have too much knowledge of new 125's but I may have something to suggest with the right info.
Frost
PostPosted: 08:31 - 28 Dec 2004    Post subject: Reply with quote
Sounds like a flat spot from the powervavle being jammed open.
Take it to a mechanic and tell them to sort the powervavle out. should take them about 10 seconds to figure out whats wrong with it.
Worst case scenario would be a new powervavle + labour costs and would come to about £100, not alot given the improvement it will make.
badboy2050uk
PostPosted: 13:36 - 28 Dec 2004    Post subject: Reply with quote
ok will try that yer it is in every gear up and down hill.
PostPosted: 12:41 - 30 Dec 2004    Post subject: Reply with quote
Tends to suggest the power valve is stuck closed.
On the right side of the engine just above the exhaust there is a little cover (rubber I think) with a couple of cables going to it. Peel the cover back and turn the ignition on. It should open and close the power valve when the ignition is switched on (self cleaning and to check it is in the correct position) so you should see it move.
The control units for the power valve do fail on the Mito. These are ~£100 new, and to have a warrenty 3X will only sell you the control unit with a new power valve motor (another ~£100).
badboy2050uk
PostPosted: 16:36 - 30 Dec 2004    Post subject: Reply with quote
ok right had a look yer it opens then close but still stuck at 7000rpm so wat will i need to do?
Biker_Dene
PostPosted: 02:10 - 01 Jan 2005    Post subject: Reply with quote
hi m8
iv got a cagiva mito evo 2
wen i got it the power valve wasnt working my cdi (the little black box) waz broken but wether it waz open or clossed i could still rev it to 11k just wen it waz closed got better acceleration etc etc i can only think that maybe its still restricted ??
Dene
"RIDE LIKE A KNOB AND YOU'LL DIE"
K9 Suzuki Hayabusa
badboy2050uk
PostPosted: 14:05 - 01 Jan 2005    Post subject: Reply with quote
well i have tried 3 cans and 2 exausts? still the same?
Dom_
Points Mean Prizes
PostPosted: 18:30 - 01 Jan 2005    Post subject: Reply with quote
That is because it is the powervalve, NOT THE EXHAUST.
The last post was made 21 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 58.42 Kb
