| badboy2050uk |
 badboy2050uk L Plate Warrior
| gsxrboy |
 gsxrboy Scooby Slapper
 Posted: 23:53 - 27 Dec 2004 Post subject: |
Is this in every gear? uphill and downhill?
Always try to give as much information as you can to aid an easy fix!! I dont have too much knowledge of new 125's but I may have something to suggest with the right info. |
| Frost |
 Frost World Chat Champion
| badboy2050uk |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:41 - 30 Dec 2004 Post subject: |
Tends to suggest the power valve is stuck closed.
On the right side of the engine just above the exhaust there is a little cover (rubber I think) with a couple of cables going to it. Peel the cover back and turn the ignition on. It should open and close the power valve when the ignition is switched on (self cleaning and to check it is in the correct position) so you should see it move.
The control units for the power valve do fail on the Mito. These are ~£100 new, and to have a warrenty 3X will only sell you the control unit with a new power valve motor (another ~£100).
| badboy2050uk |
| Biker_Dene |
 Biker_Dene Crazy Courier
| badboy2050uk |
| Dom_ |
 Dom_ Points Mean Prizes
The last post was made 21 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
