Paddock Stands
TurbodTurtle
PostPosted: 13:53 - 21 Jan 2014    Post subject: Paddock Stands Reply with quote
Hi,
Can someone tell me how paddock stands work? How do I ensure they will work on my bike? I have a 2007 ZX6r.
Also, the bike is kept outside under a cover so ideally ones that are not overly expensive as they may rust/get scratched over time.
I have seen a few different types but unsure what I need.
Sorry if this is a silly question
Thanks
Ashley
MattJ
PostPosted: 13:56 - 21 Jan 2014    Post subject: Reply with quote
What do you want paddock stands for? Maintenance on the bike?
TurbodTurtle
PostPosted: 14:05 - 21 Jan 2014    Post subject: Reply with quote
Thats right, just to help me with the chain and get the tires off the floor while it stands in the cold.
CarlosCBR
PostPosted: 14:09 - 21 Jan 2014    Post subject: Reply with quote
The front is usually two prongs, one sits under the fork whilst the other goes behind it, it's just a case of making sure they are located properly and pushing down on the handle.
Rear stands come in cup or hook form, both are easy to use. If you have bobbins on your swingsrm you can use the hook version, fairly self explanatory just hook the bobbins then push the handle down or if you have the cup type stand, locate them properly under the swingsrm and push down the handle.
When you first give it a go it might be worth getting a mate to hold the bike level for you but once you've done it a few times you should be fine to do it on your own.
J.M.
PostPosted: 14:12 - 21 Jan 2014    Post subject: Reply with quote
You're planning on leaving the bike on its paddock stands at all times?
2004 R1 & 2018 XSR900
MattJ
This is a rear one that you would be able to use without modifying the bike in any way. It just sits under the swingarm and lifts it up that way.
https://www.sticky-stuff.co.uk/images/new%20rear%20paddock%20stand.jpg
And this is one for the front where you just rest the bottom of the forks and lift it up that way
https://www.sportsbikeshop.co.uk/product_images/bike_tek_red_front_paddock_stand.jpg
You can also fit bobbins to your bike so the paddock stands hook onto those and lift them up to avoid damaging your bike
Shinigami
PostPosted: 14:49 - 21 Jan 2014    Post subject: Reply with quote
I have a rear one like the red one above for sale if you're anywhere near manchester
-Matt-
PostPosted: 15:03 - 21 Jan 2014    Post subject: Reply with quote
No need to leave it on paddocks, i'd be a bit worried doing so to be honest some of them can give way occasionly, its rare but if you're with the bike working on it at least theres a good chance to stop it smashing down. I've had it happen once with my set in a few years.
I prefer adapting the rear stand with paddock hooks
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/63007?r=GS&gclid=CLzk2ZK3j7wCFUnjwgodqmQAEw
Then you can lift it hooking them under bobbins
https://www.evotech-performance.com/2007-2035/long-kawasaki-paddock-stand-crash-protector-bobbins-m10-1-25-thread
Most generic ones will be fine for your bike. You can get sets off ebay for as little as 30 quid or so. I got mine new for about 55 IIRC. A rear ones particularly useful for chain maintenance. Unless you're going to be removing the wheels yourself a front one might not be nescessary.
Islander
PostPosted: 15:36 - 21 Jan 2014    Post subject: Reply with quote
If you want to keep the bike up on a stand for long periods then consider an Abba stand. They're easier to use single handed without worrying about dropping the bike and they're a lot more stable. Thumbs Up
Andy S
PostPosted: 15:45 - 21 Jan 2014    Post subject: Reply with quote
I bought one of these recently, good for the price:
https://www.ebay.co.uk/itm/BIKETEK-UNIVERSAL-SERIES-3-MOTORCYCLE-MOTORBIKE-LIGHTWEIGHT-REAR-PADDOCK-STAND-/400521891623
also on ebay deal at the moment:
https://www.ebay.co.uk/itm/Oxford-Heavy-Duty-Rear-Paddock-Stand-/190804375525
ws4936
PostPosted: 15:50 - 21 Jan 2014    Post subject: Reply with quote
I also keep my zx6r on paddock stands at all times, with the blaintently obvious exception of when I am riding it.
But I use paddock bobbins for the rear, and a headstock paddock stand for the front so the forks are not under load. Mind you I do have it in a warm garage - I doubt I'd paddock them overnight outdoors, that seems odd to me. Idk why - just seems like a lot of work for not much gain. My ninja isn't in use everyday so is hooked up to an optimiser also.
Idk OP- whatever floats your boat I guess.
If everything seems under control, you're just not going fast enough.
Rogue_Shadow
PostPosted: 16:17 - 21 Jan 2014    Post subject: Reply with quote
I've got a paddock stand that sits underneath my rear bobbins Thumbs Up
Didn't like the "swingarm" lift style paddock stands. I wouldn't fancy leaving it unattended for long periods of time though.
In future I'll get myself an Abba stand, I find getting my bike onto a paddock stand by myself a little awkward Confused
BenchWench
PostPosted: 16:20 - 21 Jan 2014    Post subject: Reply with quote
https://www.abbastands.co.uk/product_details.asp?id=44
AHHH I want one of these....
Yamaha YBR - 2009
125KG of bike is not comfortable as knee ware.
t121anf
PostPosted: 16:51 - 21 Jan 2014    Post subject: Reply with quote
i'm not sure I'd trust the band used to hold it in the positions.
wots
PostPosted: 17:18 - 21 Jan 2014    Post subject: Reply with quote
I've got the ABBA stand kit, not the sky lift, but the one that allows you to raise the front wheel with the tie down. ER6 had no front end on it for about 3 weeks over christmas whilst I did the forks. Never moved an inch.
I've said it before, I'm a fool, I managed it. Laughing
My first paddock stand which is red and similar to those knocking about looks like it will twist and buckle, I don't really trust it. Wouldn't leave it on it.
This would be much better https://www.ebay.co.uk/itm/BIKETEK-HEAVY-DUTY-REAR-ALUMINIUM-BOX-MOTORCYCLE-MOTORBIKE-PADDOCK-STAND-/281040478582?pt=UK_Motorcycle_Parts&hash=item416f516176
Rogue_Shadow
PostPosted: 17:20 - 21 Jan 2014    Post subject: Reply with quote
Me neither Shocked
I'm more interested in the less complicated version
(Edit: Tried & Tested by Wots Laughing )
https://imageshack.us/a/img13/7873/bikeonstand.jpg
Couple of sandbags on the rear tyre & I could raise the front tyre off the ground aswell Thumbs Up
wots
PostPosted: 17:23 - 21 Jan 2014    Post subject: Reply with quote
This kit, just an add-on to a standard abba, but I bought it as a whole kit.
https://www.abbastands.co.uk/product_details.asp?id=42
Solid as a rock. Most difficult part for me was the strap as I didn't know how the ratchet straps work. Embarassed
t121anf
PostPosted: 17:39 - 21 Jan 2014    Post subject: Reply with quote
It's on my purchase list, I hate my ABBA super bike front lift thingy, bike feels so unstable on it.
gmc38609
PostPosted: 20:49 - 21 Jan 2014    Post subject: Reply with quote
My bike fell over on a paddock stand smashing the tank and rear fairing. I was gutted the bike was 9 years old and spotless, when I bought it, I had owned it 4 days when this happened.
Lesson learnt though always make sure the surface is flat and if it has adjustable bits make sure there done up tight before using
dodgydog
PostPosted: 21:31 - 21 Jan 2014    Post subject: Reply with quote
I'd glue some old inner tube rubber into the cups that hold the swingarm, holds it a little firmer and stops it scratching the swingarm, either that or use the bobbin type. Also I've never thought that type of front stand is very stable, I prefer the type with a pin that slots in the headstock tube.
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
TurbodTurtle
PostPosted: 22:12 - 21 Jan 2014    Post subject: Reply with quote
Wow those abba stands look cool. I'm trying to find a used one, some on eBay but most seem to be collection only. I don't want to pay £100 for one but £50-£60 isn't too bad Smile
Thanks for all the replies. I might get some bobbins anyway as they look quite good Cool
Islander
PostPosted: 22:34 - 21 Jan 2014    Post subject: Reply with quote
They're solidly constructed and hence, heavy. Mr. Green
If you do buy one secondhand, you'll need to order the correct fitting kit for your bike (unless you really luck out that is).
TurbodTurtle
PostPosted: 23:07 - 21 Jan 2014    Post subject: Reply with quote
There is one on eBay that he used to have a 'ninja' on, but doesn't say which. He lives a long way and won't post but have asked if he'll accept if i book a courier Mr. Green Mr. Green
wots
PostPosted: 23:11 - 21 Jan 2014    Post subject: Reply with quote
If you get one secondhand and don't have the right fitting kit for your bike, go to the Abba site and find the right kit number for your bike. Then do an ebay search for that kit number and you might find one cheaper, as someone might've switched bikes and will be selling off their old kit.
bikertomm
PostPosted: 23:25 - 21 Jan 2014    Post subject: Reply with quote
This is what you want mate, I have the exact same for my 07' hornet,
https://www.ebay.co.uk/itm/NEW-REAR-UNIVERSAL-PADDOCK-STAND-KAWASAKI-ZX6R-ZX-6R-NINJA-PDSTAND-/130769571930?pt=UK_Motorcycle_Parts&hash=item1e7279505a
Never had an issue, use it to do my chain all the time, lovely bit of kit for the price.
You will need someone to hold the bike up straight so you can slot it in though incase you didn't realise.
The last post was made 12 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 133.3 Kb
