ER6 - Front wheel alternatives
wots
PostPosted: 15:48 - 09 Feb 2014    Post subject: ER6 - Front wheel alternatives Reply with quote
So I've completely mullered my front wheel bearing when trying to remove it, one side ok, the other side is really bad.
Which other Kwak wheels will fit? Ideally with minimal effort.
Aff
PostPosted: 17:00 - 09 Feb 2014    Post subject: Re: ER6 - Front wheel alternatives Reply with quote
You killed the bearing or the housing?
And what year?
Electric Bike Project
wots
PostPosted: 17:04 - 09 Feb 2014    Post subject: Re: ER6 - Front wheel alternatives Reply with quote
And what year?
The seat in the wheel, trying to grind the remainder out.
Aff
PostPosted: 17:11 - 09 Feb 2014    Post subject: Re: ER6 - Front wheel alternatives Reply with quote
wotsthestory wrote:
And what year?
Ah OK, I seem to remember you having a first gen.
So I think you can have a wheel from:
Any er6 2006-2010
Any ZR750 2007-2010
Any KLE650 2008-2010
This is from memory so you will have to check.
A cheaper option would be to bore it out. 2005+ ZX6R's use the same wheel but with a larger OD bearing, so there is plenty of material to take away.
Another option is to use one of the 2005+ ZX6R wheels with a different bearing to match the ZX6 OD and the ER6 ID.
:edit: why did you need to grind it in the first place?
:edit 2: Just for a bit more info. The ER6 uses a 42x20x12 bearing on the front. the 05-08 ZX6R uses a 47x25x12 bearing on the front. So you could use a ZX6 wheel with a 47x20x12 bearing or bore out the damaged ER6 wheel to 47mm H7 and use the 47x20x12.
wots
PostPosted: 17:52 - 09 Feb 2014    Post subject: Reply with quote
_Iain_ wrote:
Photos required.
Photos embarrassing! Embarassed
wots
PostPosted: 18:06 - 09 Feb 2014    Post subject: Re: ER6 - Front wheel alternatives Reply with quote
Sounds great.
1) Where to get it bored out?
2) Where to get a 47x20x12 bearing?
Aff
PostPosted: 18:16 - 09 Feb 2014    Post subject: Re: ER6 - Front wheel alternatives Reply with quote
Ask around a few machine shops to see if they got a big enough lathe.
Looks like you cant get a 47x20x12
Closest is 47x20x14 I'm not sure if you can lose that much material though.
You could always use this as an excuse for a ZX6 fork upgrade, wouldn't cost much more that buying a new wheel. Laughing
wots
PostPosted: 18:19 - 09 Feb 2014    Post subject: Reply with quote
I considered the fork option, but if I'm looking at a £200 for f**king it up. I'll break it as component parts go for good money on these. It's worth as much running as it is in pieces.
Aff
PostPosted: 18:21 - 09 Feb 2014    Post subject: Reply with quote
Can you still get those Chinese copies for £150?
wots
PostPosted: 18:23 - 09 Feb 2014    Post subject: Reply with quote
£175 plus the cost of getting the tyre swapped. I was planning on selling it in the next couple of months anyway.
Carvel
PostPosted: 18:40 - 09 Feb 2014    Post subject: Reply with quote
Throw a pic up.
Front wheels for them are are bloody expensive!
wots
PostPosted: 19:33 - 09 Feb 2014    Post subject: Reply with quote
Carvel wrote:
Throw a pic up.
Haven't actually got a pic. The wheels are ridiculously expensive. It is almost the same cost to throw a full front end on from something else.
Ed Case
PostPosted: 20:05 - 09 Feb 2014    Post subject: Reply with quote
Have you tried sticking an ad. on the ER5/6 owners club site ?.
wots
PostPosted: 20:06 - 09 Feb 2014    Post subject: Reply with quote
Pretty much dead on there. Except for people asking what to do when their exhaust has snapped ... Thumbs Down
wots
PostPosted: 13:35 - 10 Feb 2014    Post subject: Reply with quote
I found somewhere local that could bore out to 47mm, no idea of price though. Went to remove discs, bolts just round out, managed 2 out of 5 one side and none the other. Potential costs have spiraled to the point I need to bin it. Very few options for a front wheel on this, I can't believe it.
Aff
PostPosted: 13:54 - 10 Feb 2014    Post subject: Reply with quote
You shouldn't need to take the disks off, just pull the tyre off.
Does there look to be enough material to take it out to 14mm deep?
wots
PostPosted: 13:55 - 10 Feb 2014    Post subject: Reply with quote
What am I looking at?
Aff
PostPosted: 14:37 - 10 Feb 2014    Post subject: Reply with quote
The lip on the inside that stops you pushing the bearing any further.
wots
PostPosted: 14:49 - 10 Feb 2014    Post subject: Reply with quote
Oh ok, I need to arrange a picture. In all honesty, the damage isn't THAT bad. Where the outer race seats, it POSSIBLY could be re-machined to 42MM, as I don't think I went through (or just nicked it). The outer race is still in there. 47MM would be easy but not sure about depth. Would have to look.
I'll go back and have a look later.
Ed Case
PostPosted: 21:27 - 10 Feb 2014    Post subject: Reply with quote
Try ringing DK Motorcycles in Newcastle-u-Lyme (01782-861100), Used Spares dept, massive breakers and fair too.
The last post was made 12 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 118.47 Kb
