cbr 125 problem
a bikers life
PostPosted: 22:47 - 28 Feb 2014    Post subject: cbr 125 problem Reply with quote
Hello guys i have a big problem with my cbr 125, my bike will not start easily. As you have to hold the ignition down and give it all of throttle and when/if it does get going it will die if you let the throttle go. I had rac out today and had to get a lift home the guy i was speakimg to had a look at it and could'nt find the problem, he said it could be anything like my carbs my float stuck (as i had fuel leaking form that
Bit) or compression as he could'nt check it or my engine. My bike is a 05 and has done only 7000 miles, what should i do and what could it be?
Thanks guys.
RockandGrohl
PostPosted: 03:09 - 01 Mar 2014    Post subject: Re: cbr 125 problem Reply with quote
Thanks guys.
Sounds super dumb, but you are using the choke, yeah? I've had to choke-start my bike for the past... I dunno... 4 months now? Even when it doesn't seem that cold, it'll just stall if I don't use choke.
a bikers life
PostPosted: 08:54 - 01 Mar 2014    Post subject: Reply with quote
Could a bad float cause all the problems iv been having tho? And how easy is the float to remove from a cbr 125?
Clutchy
PostPosted: 09:11 - 01 Mar 2014    Post subject: Reply with quote
Float got stuck on my cbr causing your symptoms too, I cleaned the whole carb and it ran great after that.
PostPosted: 09:24 - 01 Mar 2014    Post subject: Reply with quote
CBR125s of the carb era need full choke to start and need at least a mile or 2 easy for me to even consider turning the choke off. All 3 or 4 I've had were the same.
Might be worth doing the valve clearances.
a bikers life
PostPosted: 13:28 - 01 Mar 2014    Post subject: Reply with quote
A quick update, iv had a guy round today to look at it and he said the compression is fine and that im running rich. His told me to go buy a new spark plug and a new air fillter and see if it will fix it if not he said that he will need to take it apart and clean my carb and check my vacum for cracks and has said it can cost up to £80 to fix it, if the plug and filtter dont fix it.
a bikers life
PostPosted: 16:11 - 01 Mar 2014    Post subject: Reply with quote
Just changed the spark plug and put a new air filter in and its still bad. What should i check/do next?
PostPosted: 16:28 - 01 Mar 2014    Post subject: Reply with quote
Take the carb off. Give it to someone who can either clean and check it or DIY. Better yet, remove it and take a photo of inside the float bowl.
You'll be better off DIY and taking photos at each step.
a bikers life
PostPosted: 19:40 - 01 Mar 2014    Post subject: Reply with quote
okay i suppose il just have to wait for this guy to come fix it then as i don't have a clue where to start to clean a carb.
dydey90
PostPosted: 19:55 - 01 Mar 2014    Post subject: Re: cbr 125 problem Reply with quote
I thought this too!
The choke on them is weird, you pull it out and then it retracts itself. Mine always pulled back in too fast so I had to hold it out while it warmed up a bit.
See if holding the choke makes a difference?
a bikers life
PostPosted: 10:33 - 02 Mar 2014    Post subject: Reply with quote
Well the guy i had to look at it said to replace them. As my spark plug was some racing one that was in there before i bought it and also he said to change the air filter. And now the fuel is not leaking out the overflow. Could it have just been leaking when they where trying to start my bike by giveing to much throttle maybe? As i said i dont know much about bikes but i have a freind over later who is going to check my carb. And starting with the choke has no difference i tried, rac tried, a freind tried and the guy yesterday so its defenttly no that. Its just weird how it can't idle and sometimes it can for a few minutes.
a bikers life
PostPosted: 12:16 - 03 Mar 2014    Post subject: Reply with quote
Just had the guy look at it and he is saying my gearbox is full with petrol, he has said ethier i have a big problem or someone has put it in there, and has said it will cost upto £500 to fix it if the head casket is gone
DrSnoosnoo
PostPosted: 12:57 - 03 Mar 2014    Post subject: Reply with quote
You must enjoy writing updates and getting the same advice over and over. Drop your oil, take your carb off and clean it up. Put a new oil filter on with new oil ...
READ THE ADVICE.
PostPosted: 13:04 - 03 Mar 2014    Post subject: Reply with quote
So much derp. So little sense.
The carb has obviously been subject to a bowl of crap and the float has stuck. This has gone into the engine and this has now gone into the oil.
Drop the oil out.
DO NOT START THE ENGINE.
Remove the carb.
Clean the carb.
Re-fit the carb.
Put new, fresh oil in.
Start bike.
Do it, in that order and you'll be fine.
Miss a step, sell the bike for scrap.
If you are anywhere close to Maidstone, Kent, PM and I'll do it free of charge.
PostPosted: 13:10 - 03 Mar 2014    Post subject: Reply with quote
O dear so much fail with this one.
Northern Monkey
PostPosted: 13:52 - 03 Mar 2014    Post subject: Reply with quote
The fail is stong here.
Fix dodgy carb. Change oil. Profit?
a bikers life
PostPosted: 14:04 - 03 Mar 2014    Post subject: Reply with quote
The carb has been cleaned he said it was fine he has drained the oil with the petrol and replaced it and it is now runin but he thinks it might go again as he has no idea how that much petrol got in there he said it was maybe a pint of petrol and supprised the engine is still runing.
PostPosted: 14:14 - 03 Mar 2014    Post subject: Reply with quote
Then find a new mechanic/friend.
It will only go again if he hasn't properly cleaned the carb.
a bikers life
PostPosted: 14:15 - 03 Mar 2014    Post subject: Reply with quote
Il try to if anyone on here if from or near hemel hempstead then be my guess
a bikers life
PostPosted: 17:54 - 03 Mar 2014    Post subject: Reply with quote
Well its working at the moment i doubt il use him again as i cant trust him to have cleaned my carb. So if it goes again il take it to a shop so they can clean it as il end up breaking something if i do it.
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.13 Sec - Server Load: 0.91 - MySQL Queries: 15 - Page Size: 133.31 Kb
