| a bikers life |
 a bikers life Derestricted Danger
| _Iain_ |
 _Iain_ Banned
 Posted: 23:37 - 28 Feb 2014 Post subject: |
If the float is stuck then sort it.
No point trying diagnosis on an engine with a known major carburation fault as it'll likely run poorly even after you find another issue!
When the floats jammed on my GS500 it filled the crankcases with fuel. Definately worth testing the oil to see if it stinks of fuel and feels very thin as petrol isn't a great replacement for oil. ____________________ Please be aware that the above post may be full of complete nonsense.
| RockandGrohl |
 RockandGrohl Nova Slayer
| a bikers life |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 09:11 - 01 Mar 2014 Post subject: |
Float got stuck on my cbr causing your symptoms too, I cleaned the whole carb and it ran great after that. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| P.addy |
 P.addy Red Rocket
| _Iain_ |
 _Iain_ Banned
| a bikers life |
| a bikers life |
| P.addy |
 P.addy Red Rocket
| a bikers life |
| dydey90 |
 dydey90 World Chat Champion
| _Iain_ |
 _Iain_ Banned
 Posted: 00:01 - 02 Mar 2014 Post subject: |
What gets me is that you have fuel pissing out the overflow tube and yet you're trying to change air filters and spark plugs.
Did you confirm the air filter was clogged prior to replacement?
Did you confirm there was a poor spark prior to replacement?
Randomly replacing components till you get the desired response isn't a cost effective method of fault finding!
You KNOW you have a carburettor fault, start by fixing the obvious before mucking about changing other things. If you know for a fact part of the engine isn't operating correctly, why on earth spend time and money changing parts of the engine that only might be faulty? ____________________ Please be aware that the above post may be full of complete nonsense.
| a bikers life |
| a bikers life |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| P.addy |
 P.addy Red Rocket
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 13:10 - 03 Mar 2014 Post subject: |
O dear so much fail with this one. ____________________ My Flickr |
| Northern Monkey |
 Northern Monkey World Chat Champion
| a bikers life |
| P.addy |
 P.addy Red Rocket
| a bikers life |
| _Iain_ |
 _Iain_ Banned
 Posted: 16:10 - 03 Mar 2014 Post subject: |
| a bikers life wrote: | Just had the guy look at it and he is saying my gearbox is full with petrol, he has said ethier i have a big problem or someone has put it in there, and has said it will cost upto £500 to fix it if the head casket is gone |
I'd not let him near my bike again
When a float jams, fuel pisses into the engine. If the inlet valve is open it makes it into the cylinder. There's gaps round the side of the piston, very small but big enough for fuel to drip down...when it's left overnight for 12hrs then there's lots of time for the petrol to drip into the oil.
I'd not always be bothered about doing the filter, but just drop the contaminated crap & refil with the correct amount of 10w40.
Carburettor obviously has an issue.
If it's not grit, then suspect worn float needle or a float that doesn't float.
Pop the float bowl off, remove the float and inspect it - if there's liquid in it then you need a new one. If not, put it in the sink and fill sink with water - see if it floats evenly. If not, you need a new one.
If the float is good, inspect these bits - the needle valve, and the seat.
https://i42.photobucket.com/albums/e341/mascioj/2005%20Yamaha%20TW200/removing%20%20Carb%20Foat/floatvalveneedleandseat.jpg
What you're looking for on the needle tip is any kind of wear.
It's this needle valve getting stuck open that's causing all your issues. If you need an explanation of what's happening, open the top of your toilet and flush. Then watch what happens when it fills up. Then flush it again, but this time hold the float down under the water - noting that the thing then fills up past where it's supposed to & that water is pouring out of an overflow vent in the top?
This may help you, obviously you won't need to do all of it - just concentrate on the float, the needle and the needle seat. Skip to 8:00
https://www.youtube.com/watch?v=HeMjppADyTM
HTH
Edit;
| a bikers life wrote: | Il try to if anyone on here if from or near hemel hempstead then be my guess |
I think you mean:
| a bikers life wrote: | If there's anyone on here that's anywhere near Hemel Hepstead, I'd be really grateful for a helping hand! |
| a bikers life |
| _Iain_ |
 _Iain_ Banned
 Posted: 18:07 - 03 Mar 2014 Post subject: |
Keep an eye on it the next few days. Open the oil cap and sniff for petrol - if it stinks of it it's a sure fire sign it's happening again. ____________________ Please be aware that the above post may be full of complete nonsense.
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
