Oil change.. how much!? Also mechanic query, abs brake pads?
bikertomm
PostPosted: 22:27 - 04 Mar 2014    Post subject: Oil change.. how much!? Also mechanic query, abs brake pads? Reply with quote
Looking at doing my first oil change on a bike (my hornet) soon.
Have just bought an oil filter and crush ring for the sump, £15.
4 Litres of castrol's finest is coming in at £40, found it for £30 online.
So near enough 50 spunking pound!
Still, looking forward to doing it, only worry is the oil filter is going to be a bitch to get off- but hopefully not. Any tips?
Also, on another note:
Is it generally acceptable to say buy my own brake pads and ring up and ask mechanics if they would be interested in fitting them?
Or will I be laughed at down the phone? I'm guessing they make a certain profit through parts?
It's looking like I can get brake pads for front and rear for £40 (Goldfren?)
I don't just want any old shitty pads put in - any advice on this?
This means I can do my own oil change and have new pads for under £100. Then say labour of £60+ I think I'll be happy with.. I don't know how to do my own brake pads and there's abs on the bike which I've heard can make it harder.
Cheers! Thumbs Up
Doovy
PostPosted: 22:31 - 04 Mar 2014    Post subject: Reply with quote
Servicing a Hornet is piss easy. Do the brakes yourself.
Some mechanics say they won't fit externally supplied parts as if its the wrong fitment, they usually discover this when the bike is up on the ramp and it means wasted time.
To get the filter off easily, drain all the oil out the sump, then hammer a screwdriver in through the filter. Use that as a turning handle, it will come off easily. Just make sure you drain it all first!!
I used some ebay bought brake pads on my Hornet, I think EBC they were.
I'm in North East London, you like look you're on the west of the M25.. if you ever needed a hand I'm sometimes about here. Not had experience with the ABS brakes though.
bikertomm
PostPosted: 22:37 - 04 Mar 2014    Post subject: Reply with quote
Sweet, thanks for that.
I've heard of that screwdriver method!
I've got a paddock stand too (for the rear) so yeah oil change should be easy, wonder what I can get to go wrong.. Laughing
Cheers for the offer, I'm near High Wycombe.
Hopefully someone may be able to shed some light on the abs issue!
Thumbs Up Karma
Islander
The hardest part of servicing a Hornet is changing the plugs. Seriously. Laughing
It took me as long to change the plugs as it did to change the oil and filter last service. Fiddly buggers. Brakes are a doddle, filter - remove as above or buy a strap wrench. Don't overtighten the new one - screw it in with your fingertips then nip it up with a full hand grip.
Clutchy
PostPosted: 22:52 - 04 Mar 2014    Post subject: Reply with quote
Make sure you turn the sump bolt the correct way, working on bikes upside down means you can forget sometimes lol
Islander
PostPosted: 22:55 - 04 Mar 2014    Post subject: Reply with quote
Voice of experience? Laughing
Clutchy
PostPosted: 22:59 - 04 Mar 2014    Post subject: Reply with quote
Shhh!
Rounded it off, glad I didn't crack the sump, however it did mean I had the pleasure of extending my list of tools and buying a larger version of this:
https://s7g3.scene7.com/is/image/ae235?$p$&layer=0&size=281,281&layer=1&size=281,281&src=ae235/96028_P
-Matt-
PostPosted: 01:39 - 05 Mar 2014    Post subject: Reply with quote
I've taken plenty of my own supplied parts for fitment at various garages in the past, never had any comments or problems. That being said definately do it all yourself - oil and pads are dead easy - were the first couple of things i did when i started doing my own work on the bike a year or two back.
Few youtube videos and you'll know exactly what you're doing Thumbs Up
I've used this for years without problems. [email protected] (can get cheaper on offer sometimes)
janner_10
PostPosted: 05:38 - 05 Mar 2014    Post subject: Reply with quote
As all asaid - do it yourself. definitely 2 of the more easier jobs to do, get in the habit of doing the oil regularly - I do mine every 2k miles and the filter every other change.
You tube is your friend and get a tube of copper grease for the back of the pads.
bikertomm
PostPosted: 12:45 - 05 Mar 2014    Post subject: Reply with quote
Sweet, cheers for the tips boys. Most parts on order so this weekend will hopefully get something done Very Happy
Doovy
PostPosted: 13:50 - 05 Mar 2014    Post subject: Reply with quote
That's a point. A bit of copper grease on the back of the pads stops it binding to the disc Thumbs Up
IIRC the inner two plugs were blocked by the frame, it took a fair bit of maneuvering the plug tool to get them out!
Minty
PostPosted: 14:11 - 05 Mar 2014    Post subject: Reply with quote
lolwut?
How does grease to the back stop the front sticking to a disc?
It helps stop brake squeel. Saying that, I've never used it and yet to have any brakes get noisy.
My fingers smell of your mum.
ficedula
PostPosted: 14:43 - 05 Mar 2014    Post subject: Reply with quote
Having just failed to change my oil ("that'll not take long, I''ll do it at lunchtime!") then if you've got a non-standard set of exhaust downpipes on, double check if the sockets/extensions/whatever-you're-using to get the sump bolt out will actually get to it around the pipes.
Felt like a right muppet when I realised the new exhaust I fitted last month blocks access to the sump bolt Doh!
Probably not going to be an issue, but if you really are wondering what could go wrong... Wink
Bike history: YBR125 -> XJ600
-Matt-
PostPosted: 14:46 - 05 Mar 2014    Post subject: Reply with quote
I have used it and have had the brakes continue squeeling like a pig Laughing seems a bit hit n' miss
Minty
PostPosted: 14:51 - 05 Mar 2014    Post subject: Reply with quote
Put some on the front of the pads. That'll stop it. Wink
Doovy
PostPosted: 15:33 - 05 Mar 2014    Post subject: Reply with quote
Minty wrote:
lolwut?
Well I've never had a pad bind to the disc so far Laughing
Minty
PostPosted: 15:49 - 05 Mar 2014    Post subject: Reply with quote
Touché.
Clutchy
PostPosted: 16:45 - 05 Mar 2014    Post subject: Reply with quote
Can you not just get a spanner on it from one side rather than a socket???
Islander
PostPosted: 17:40 - 05 Mar 2014    Post subject: Reply with quote
My OHs Zephyr has a 4 into 1 that routes the downpipes under the sump and across the filter cover. It's a drop the pipes job to change the oil. Upside is that the header studs will never seize through corrosion. Laughing
ficedula
PostPosted: 18:09 - 05 Mar 2014    Post subject: Reply with quote
Maaaaaybe, I did see if I could get a spanner on it, but the sump bolt has a kind of 'lip' around it that means while a socket goes on fine, getting a flat spanner on from the side isn't easy.
I have some spanners with an offset handle which would get around that problem, except the offset means the pipes stop you getting it on again! Wink
In fairness it might be doable with a spanner, just not in the time I had at lunch. Be a bit tedious, though, given the limited room.
Not entirely coincidentally, I went from the OEM 4-2 to a 3rd party 4 into 1 when I fitted the new exhaust last month... Wink
bikertomm
PostPosted: 19:23 - 05 Mar 2014    Post subject: Reply with quote
I've just seen a cheeky tip: put a bit of tinfoil on the downpipes before you take the oil filter off to prevent most of it making a stinky mess when you start up the bike.. Thumbs Up
bladerunner
PostPosted: 00:43 - 06 Mar 2014    Post subject: Reply with quote
Another tip...wipe a bit of new oil on the filter O ring....stops it bunching up when fitting
bikertomm
PostPosted: 12:13 - 06 Mar 2014    Post subject: Reply with quote
Will do!
Does anyone know if abs will affect anything when putting in new brake pads?
It seems fairly simple to do after watching some videos and I am up for it, I just want to make sure that because I have abs it's no problem..
Cheers Thumbs Up
Doovy
PostPosted: 14:16 - 06 Mar 2014    Post subject: Reply with quote
I think because of the ABS it may be harder to push the pistons back into the caliper.. so you may need to release the bleed nipple for the pressure. You may also need to bleed the brakes if air gets into the system Idea
bikertomm
PostPosted: 18:17 - 06 Mar 2014    Post subject: Reply with quote
After just having a look at my bike the brakes do seem a bit daunting Laughing
I've watched how-to videos and it looks so simple on a bike without abs, here's a picture of mine:
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_1545999_zps794d9b3e.jpg
You can see 1&2 are the standard 12mm bolts, but then the abs system is all attached and ballsed up, it also links across to the other side.. I just don't know what I'll be doing..
Rear looks a tad confusing too:
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_134320_zps995f7647.jpg
Oil filter:
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_144605_zps641c6672.jpg
Aaaaand my oil window... with no oil in Shocked The bike was tilted on the stand, but still, will soon be sorting this.
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_134022_zps5c3f0749.jpg
Is this the correct sump bolt? Again 12mm. I guess it is because there's fuck all else down there.. seems odd that it comes off horizontally though Laughing Hope it doesn't spray oil everywhere lol.
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_134110_zpsa8cae80f.jpg
aaand my bent indicator.. I bought it like this, passed MOT like it as it's still fully functional, but I would like to bodge this at some point - any ideas?
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_144544_zpsf93efcc3.jpg
Gave it a quick wash too!
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_144601_zpsb20cec6e.jpg
Any tips appreciated.....
Cheers!! Thumbs Up
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 140.41 Kb
