Cagiva mito 125 starts then revs high and won't drop
merky69
PostPosted: 22:56 - 04 Mar 2014    Post subject: Cagiva mito 125 starts then revs high and won't drop Reply with quote
Just recently bought a cagiva mito 125 7 speed on a 2000 plate , bike was bought not running but I took the barrel off and luckily enough it was just rings stuck in there seats so fitted a be piston.
I came to fire the bike up and it started without effort, but it was revving really high like 6 - 7 k without touching the throttle , if I did touch the throttle it would raise easily but then would drop back down to about 6k again but very slowly . I have took the carb off and cleaned all jet passages and tightened all jubilee clips from air box to reeds .
I did notice carb was leaking a tiny bit even after I cleaned it .
Any help or advice would be greatly appreciated
Thanks for reading my post
PostPosted: 00:05 - 05 Mar 2014    Post subject: Reply with quote
Is the carb rubber mounting (between the carb and the reed valves) cracked? If these crack there is an air leak after the carb and you land up with a load of extra air getting in raising the idle speed. Also possible that the main bearing seals are worn which gives a similar problem.
MattWadz
PostPosted: 07:58 - 05 Mar 2014    Post subject: Reply with quote
air leak or youve put the throttle slide in the wrong way maybe?
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
PostPosted: 13:58 - 05 Mar 2014    Post subject: Reply with quote
Bad routing of cable.
Idle screw adjust badly, so far in as PO sold as non running, god knows what he might have done.
Crack in inlet.
Stuck choke.
I'd check those first.
The last post was made 12 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 44.78 Kb
