2000 Blackbird not firing...
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: 09:04 - 07 Mar 2014    Post subject: 2000 Blackbird not firing... Reply with quote
FI Blackbird. Started on the button Monday, went to pick up yesterday after it had been dropped and nothing when you hit the starter, just click.
Put battery from other bike on there and its spinning over nice and fast, lights are bright but its not firing.
Sorry, I can't really give in depth analysis as I had no multimeter but other battery I used is on my daily runner, no FI codes come up on dash. I pushed it over a mile and have now fucked my back. Great start to new bike Laughing
Aff
PostPosted: 09:27 - 07 Mar 2014    Post subject: Reply with quote
Stuck tilt sensor?
Electric Bike Project
wots
PostPosted: 09:37 - 07 Mar 2014    Post subject: Reply with quote
Aff wrote:
Stuck tilt sensor?
My thoughts too.
What happens when you attempt to start with Kill Switch on? Usually it's all part of the same circuit, however FI bikes don't generally crank at all with the kill switch on.
PostPosted: 10:03 - 07 Mar 2014    Post subject: Reply with quote
Erm... well this is what it does.
Initially, dead battery, bump start, ran home for 3 miles fine, power started dropping off.
Pushed home.
Put ER5 battery on there, spinning over like a boss.
Pump primes, lights are bright.
Killswitch is in the run position, clutch is pulled in, turns over when left out also.
Interested in tilt sensor, but as it bumps, would this not rule that out.
Ta Thumbs Up
wots
PostPosted: 10:08 - 07 Mar 2014    Post subject: Reply with quote
This makes me think Reg/Rec
PostPosted: 10:12 - 07 Mar 2014    Post subject: Reply with quote
New one fitted Saturday, only ran on Tuesday.
I am yet to take readings from reg rec as I cannot bump start it... gravel and 1/4 ton Laughing
MaybeGuy
PostPosted: 10:36 - 07 Mar 2014    Post subject: Reply with quote
ER5 batt not man enough.
PostPosted: 11:07 - 07 Mar 2014    Post subject: Reply with quote
Reg rec output is largely irrelevant if it's cranking but not firing. Any bike that spins over at normal speed should have enough battery to start.
I'd check the fuel lines.
mudcow007
PostPosted: 11:14 - 07 Mar 2014    Post subject: Re: 2000 Blackbird not firing... Reply with quote
i feel your pain buddy i pushed my bandit just over a mile last night with a binding rear brake i dont think i have ever sweated more in my life before
MaybeGuy
PostPosted: 11:27 - 07 Mar 2014    Post subject: Reply with quote
_Iain_ wrote:
ER-5 battery is bigger than a Blackbird battery & offers higher cranking amps.
Prove it? I call bullshit
Edit: google quickly tells me ER5= 180CCA, blackbird = 250CCA
Rigga
PostPosted: 11:37 - 07 Mar 2014    Post subject: Reply with quote
Aff wrote:
Stuck tilt sensor?
+1
Try turning ignition on and tilting bike a few times (without dropping it!)
Current bike: Honda CBR 1100xx
PostPosted: 11:46 - 07 Mar 2014    Post subject: Reply with quote
ER5 had a 12v 12Ah, BB had 12V 10Ah. Size wise, ER5 is also far larger.
PostPosted: 12:01 - 07 Mar 2014    Post subject: Re: 2000 Blackbird not firing... Reply with quote
Have you checked the spark plugs definitely aren't sparking?
If that's the case, get ya' multimeter out and get tracing back along the engine run/kill wiring and see where it's going wrong.
PostPosted: 12:02 - 07 Mar 2014    Post subject: Re: 2000 Blackbird not firing... Reply with quote
Nope, that is a job for day time. Honestly was so sick and tired of the pushing I gave up last night and went to bed. Will pull a HT lead and pop a plug in to test spark.
I know better than to doubt you, but can I ask why? Just wondering as I can bump it and it runs really well once bumped. Thumbs Up
Bezzer
PostPosted: 14:24 - 07 Mar 2014    Post subject: Reply with quote
I'd still be looking at the battery first, being able to bump start it and run points to the electrical side including the fragile reg/rec being OK. You use some battery power getting an FI BB started, might have enough to light it up but not enough to get it to fire but bumping gives it that bit extra to get it going. Confirm it by using leads from a decent car battery, starts and it's both your batteries are not up to it, not starting then you can start checking all the other possibilities. The tilt switch allows it to spin over but not start BUT it also kills the fuel pump and you're hearing that click and prime so the tilt should be OK, give it a tap with a screwdriver anyway just to make sure, you can also bridge the red and green wires on it to bypass.
PostPosted: 14:47 - 07 Mar 2014    Post subject: Reply with quote
The battery I am using is bigger than the current and is a hefty bugger in an ER5, would expect it to fire up instantly but I do have a car battery to use later.
If it does start, I'll let you all know but I have a feeling it will not Thumbs Up
_mjs_
PostPosted: 20:15 - 07 Mar 2014    Post subject: Reply with quote
My CB500 had the exact same symptoms at one point and it turned out to be worn out brushes on the starter motor.
Also, pictures of this beast Thumbs Up
PostPosted: 10:05 - 08 Mar 2014    Post subject: Reply with quote
Will not fire with a car battery.
Checked the main earth, cleaned frame and connectors, bolted back down.
Pump primes.
With key on + and - of battery have continuity... should that be so?
I am a right spaz with electrics so this is way over my head. Still not been able to get a spark plug out as they are buried underneath a plethora of plastic and wiring. I would hope it is just spark plugs, as the bike bumps (or at least did prior to me taking the rear plastic off) but then the battery was failing to charge.
Oh the joys...
Oh and pic... sorry, grabbed quick one before work.
https://i1291.photobucket.com/albums/b545/paddynewman/image_zpsea6049da.jpeg
Bezzer
PostPosted: 14:43 - 08 Mar 2014    Post subject: Reply with quote
Plugs are a pain the first time but you soon get the knack, when you do them go in from the top NOT from the front like the manual says it's a lot easier. No need to take tank fully off either or disconnect any of the lines they are long enough to let you lift and rest the tank between the frame rails with some suitable padding, it's secure enough just make sure it's not too full.
See you've posted on BIRD about it which is the best place given all their odd foibles, make sure the loom fix has been done on it when you've sorted this problem.
https://i561.photobucket.com/albums/ss60/mickcbr1100/misc/tankremoval_zps43c78a86.jpg
0l0dom0l0
PostPosted: 15:01 - 08 Mar 2014    Post subject: Reply with quote
Have you tried turning the kill switch off and on again?
This sometimes resets the tilt sensor if it's gone off.
PostPosted: 15:52 - 08 Mar 2014    Post subject: Reply with quote
Tried everything.
Resorted to the strip down...
https://i1291.photobucket.com/albums/b545/paddynewman/bb/image_zps3836be2b.jpeg
https://i1291.photobucket.com/albums/b545/paddynewman/bb/image_zps969afc2f.jpeg
https://i1291.photobucket.com/albums/b545/paddynewman/bb/image_1_zps9a89a24c.jpeg
https://i1291.photobucket.com/albums/b545/paddynewman/bb2/image_zps697def15.jpeg
https://i1291.photobucket.com/albums/b545/paddynewman/bb2/image_1_zpse980b6a8.jpeg
Oh stator, you so crispy. Wub
doggone
PostPosted: 15:56 - 08 Mar 2014    Post subject: Reply with quote
So was that caused by being gently dropped?
PostPosted: 16:01 - 08 Mar 2014    Post subject: Reply with quote
Looks like it's been rubbing on the rotor. Are the windings actually knackered? They don't look it. Try a phase-to-phase ohm test.
The last post was made 12 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 8
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 134.88 Kb
