| P.addy |
 P.addy Red Rocket
 Posted: 09:04 - 07 Mar 2014 Post subject: 2000 Blackbird not firing... |
FI Blackbird. Started on the button Monday, went to pick up yesterday after it had been dropped and nothing when you hit the starter, just click.
Put battery from other bike on there and its spinning over nice and fast, lights are bright but its not firing.
Sorry, I can't really give in depth analysis as I had no multimeter but other battery I used is on my daily runner, no FI codes come up on dash. I pushed it over a mile and have now fucked my back. Great start to new bike  |
| Aff |
 Aff World Chat Champion
| wots |
 wots World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 10:03 - 07 Mar 2014 Post subject: |
Erm... well this is what it does.
Initially, dead battery, bump start, ran home for 3 miles fine, power started dropping off.
Pushed home.
Put ER5 battery on there, spinning over like a boss.
Pump primes, lights are bright.
Killswitch is in the run position, clutch is pulled in, turns over when left out also.
Interested in tilt sensor, but as it bumps, would this not rule that out.
Ta  |
| wots |
| P.addy |
 P.addy Red Rocket
 Posted: 10:12 - 07 Mar 2014 Post subject: |
New one fitted Saturday, only ran on Tuesday.
I am yet to take readings from reg rec as I cannot bump start it... gravel and 1/4 ton  |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 10:36 - 07 Mar 2014 Post subject: |
ER5 batt not man enough. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| _Iain_ |
 _Iain_ Banned
| Pete. |
 Pete. Super Spammer
 Posted: 11:07 - 07 Mar 2014 Post subject: |
Reg rec output is largely irrelevant if it's cranking but not firing. Any bike that spins over at normal speed should have enough battery to start.
I'd check the fuel lines. ____________________ a.k.a 'Geri'
| mudcow007 |
 mudcow007 World Chat Champion
| MaybeGuy |
| Rigga |
 Rigga World Chat Champion
| P.addy |
 P.addy Red Rocket
| _Iain_ |
 _Iain_ Banned
| G |
 G The Voice of Reason
| P.addy |
 P.addy Red Rocket
| Bezzer |
 Bezzer World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 14:47 - 07 Mar 2014 Post subject: |
The battery I am using is bigger than the current and is a hefty bugger in an ER5, would expect it to fire up instantly but I do have a car battery to use later.
If it does start, I'll let you all know but I have a feeling it will not  |
| _mjs_ |
 _mjs_ Could Be A Chat Bot
 Posted: 20:15 - 07 Mar 2014 Post subject: |
My CB500 had the exact same symptoms at one point and it turned out to be worn out brushes on the starter motor.
Also, pictures of this beast  ____________________ Previous Bikes: 2006 Honda XR125L > 2003 Yamaha DT125R > 1996 Honda CB500
Current bikes: 1997 Kawasaki ZZR 600 E5 > 2006 Honda Varadero XL125V |
| P.addy |
 P.addy Red Rocket
 Posted: 10:05 - 08 Mar 2014 Post subject: |
Will not fire with a car battery.
Checked the main earth, cleaned frame and connectors, bolted back down.
Pump primes.
With key on + and - of battery have continuity... should that be so?
I am a right spaz with electrics so this is way over my head. Still not been able to get a spark plug out as they are buried underneath a plethora of plastic and wiring. I would hope it is just spark plugs, as the bike bumps (or at least did prior to me taking the rear plastic off) but then the battery was failing to charge.
Oh the joys...
Oh and pic... sorry, grabbed quick one before work.
https://i1291.photobucket.com/albums/b545/paddynewman/image_zpsea6049da.jpeg |
| Bezzer |
 Posted: 14:43 - 08 Mar 2014 Post subject: |
Plugs are a pain the first time but you soon get the knack, when you do them go in from the top NOT from the front like the manual says it's a lot easier. No need to take tank fully off either or disconnect any of the lines they are long enough to let you lift and rest the tank between the frame rails with some suitable padding, it's secure enough just make sure it's not too full.
See you've posted on BIRD about it which is the best place given all their odd foibles, make sure the loom fix has been done on it when you've sorted this problem.
https://i561.photobucket.com/albums/ss60/mickcbr1100/misc/tankremoval_zps43c78a86.jpg ____________________ I used to be indecisive but now I'm not quite so sure. |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 15:52 - 08 Mar 2014 Post subject: |
| doggone |
 doggone World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 16:01 - 08 Mar 2014 Post subject: |
Looks like it's been rubbing on the rotor. Are the windings actually knackered? They don't look it. Try a phase-to-phase ohm test. ____________________ a.k.a 'Geri'
The last post was made 12 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
