I killed a conti go in 3736 miles
sidewinder
PostPosted: 22:48 - 15 Mar 2014    Post subject: I killed a conti go in 3736 miles Reply with quote
So am I doing something wrong.pressure was at a constant 32 psi as per manual.or are they just shit.never mind got a bt45 on order . Sad
CaNsA
PostPosted: 22:54 - 15 Mar 2014    Post subject: Reply with quote
38psi could be considered high, but it depends what you had it on.
PostPosted: 23:00 - 15 Mar 2014    Post subject: Reply with quote
You killed it... how dead was it?
What bike and what do you use it for?
sidewinder
PostPosted: 00:21 - 16 Mar 2014    Post subject: Reply with quote
Tire is a conti go with now 1mm of tread and a little bit squared off..Bike is a 98 600 divvy .used for everything from commuting to weekend trips..
sidewinder
PostPosted: 00:22 - 16 Mar 2014    Post subject: Reply with quote
Got that wrong it has got 32psi in it
CaNsA
PostPosted: 00:27 - 16 Mar 2014    Post subject: Reply with quote
32 is fine for a divvy.
straightline hero....
PostPosted: 00:35 - 16 Mar 2014    Post subject: Reply with quote
A Divvy barely has the power to remove the bobbles off a tyre, how did you wear one out?
Sable
PostPosted: 00:39 - 16 Mar 2014    Post subject: Reply with quote
my conti go is it about 14k mile. its square. but still going.
sidewinder
PostPosted: 01:38 - 16 Mar 2014    Post subject: Reply with quote
Could be our lovely welsh road surface? The wear indicators are now gone but still have 2mm - 4mm down the tread.so I take it this tire is now illegal due the loss of the wear indicators.confused I am now.
barrkel
PostPosted: 01:56 - 16 Mar 2014    Post subject: Reply with quote
Misaligned wheel?
sidewinder
PostPosted: 03:18 - 16 Mar 2014    Post subject: Reply with quote
barrkel wrote:
Misaligned wheel?
it's just passed a mot.so should of been spoted if it was.
Vracktal
PostPosted: 10:30 - 16 Mar 2014    Post subject: Reply with quote
Do you have panniers or carry anything heavy in a topbox regularly?
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
panrider_uk
PostPosted: 10:37 - 16 Mar 2014    Post subject: Reply with quote
Once got through a Michelin in 3000 miles on a CD185T.
I was less than impressed
iooi
PostPosted: 10:50 - 16 Mar 2014    Post subject: Re: I killed a conti go in 3736 miles Reply with quote
Forget manual when changing brands.....
Conti Site
You should have been at 2.8 bar or 40 PSI.
Low pressure will kill a tyre.....
PostPosted: 10:53 - 16 Mar 2014    Post subject: Reply with quote
It is a cheap and fairly soft tyre. Wouldnt expect more than 5k on a ER5, so less on an XJ really.
I used to get about 6k on a CBR125.
sidewinder
PostPosted: 11:31 - 16 Mar 2014    Post subject: Reply with quote
So the wear is pretty normal then Smile
covent.gardens
World Clap Champion
PostPosted: 12:00 - 16 Mar 2014    Post subject: Re: I killed a conti go in 3736 miles Reply with quote
BT45 is 500cc max (recommended)
https://moto.bridgestone.co.uk/motorcycle-tyres/ranges/battlax/bt-45/#sizes
High-quality bias construction for small and medium displacement engines (up to 500cc).
I know that's ^ only a recommendation but BT45 isn't known as lasting all that long either if you ride spirited.
iooi
PostPosted: 13:00 - 16 Mar 2014    Post subject: Re: I killed a conti go in 3736 miles Reply with quote
BT 45 is the tyre of choice of Divvy riders for good life and great grip. Got 10k out a set I had on mine.
PostPosted: 13:12 - 16 Mar 2014    Post subject: Re: I killed a conti go in 3736 miles Reply with quote
The Divvy is only 9Kg heavier than a CB500, and I don't think the tyre cares how many cylinders you have.
CaNsA
PostPosted: 14:52 - 16 Mar 2014    Post subject: Re: I killed a conti go in 3736 miles Reply with quote
The Shaggy D.A. wrote:
[The Divvy is only 9Kg heavier than a CB500, and I don't think the tyre cares how many cylinders you have.
Who mentioned cylinders?
sidewinder
PostPosted: 18:06 - 16 Mar 2014    Post subject: Reply with quote
So the the bt45 comes in at £103 fitted .is that a ok price ? Don't think a divvy has much more power than a cb500 any how and was recommended by my yammie dealer so should be good.. Very Happy
chickenstrip
PostPosted: 18:14 - 16 Mar 2014    Post subject: Reply with quote
I'm surprised the BT45 is still the tyre of choice for many. Others have been upgraded several times since that came out - no upgrade/improved replacement for the BT?
Moo.
PostPosted: 20:33 - 16 Mar 2014    Post subject: Reply with quote
I prefer the Michelin Pilot Activ over the BT45 on my divvy, rubber is a more modern design and less prone to the usual bt45 squaring it gets pretty quickly..
A2 Passed 18/6/10
sidewinder
PostPosted: 20:50 - 16 Mar 2014    Post subject: Reply with quote
He did mention the pilot actives.might pop in tomorrow and order them instead think there a bit cheaper to.
evoboy
PostPosted: 20:24 - 17 Mar 2014    Post subject: Reply with quote
Had around 6k on the conti go i had on the back of a GPZ5. Pretty much got hammered everywhere with no strip and melted balls of rubber on the edges. Laughing
I would ignore the bike manual tyre pressure and find out what the tyre company recommends.
APT Motorcycles
The last post was made 12 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 123.09 Kb
