XR125 Exhaust Bodge Advice
DiscoBiscuit This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:29 - 20 Mar 2014    Post subject: Reply with quote
The quickest and cheapest bodge for this is buying a new bike...
Triumph Sprint ST 1050
SQL
PostPosted: 18:32 - 20 Mar 2014    Post subject: Reply with quote
use aluminium tape with lashings of firegum..
SQL
PostPosted: 18:38 - 20 Mar 2014    Post subject: Reply with quote
DiscoBiscuit wrote:
Aluminium tape, didn't think of that!
bang the loose rust off with a hammer or end of a screwdriver first then use a big jubilee clip to hold the 2 sides together then firegum the lot don't miss any holes then use aluminium tape to seal it all up
lihp
PostPosted: 18:40 - 20 Mar 2014    Post subject: Reply with quote
Sprocket looks worn
SQL
PostPosted: 18:46 - 20 Mar 2014    Post subject: Reply with quote
PhilDawson8270 wrote:
Sprocket looks worn
Exactly what I was thinking.
PostPosted: 19:08 - 20 Mar 2014    Post subject: Reply with quote
Whatever you do is going to vibrate loose in short order, as I doubt there's enough meat on the silencer to clamp it firmly.
If I absolutely had to, I'd find a piece of thin metal (in the past I've cut up one of Mrs Borg's old baking trays Shhh!), roll it around the pipe, then squeeze it a bit more and shove it inside to make an internal sleeve.
Then go in with the jubilee clip / tape / bandage / silicone / putty / bits of string and chewing gum.
c_dug
PostPosted: 19:32 - 20 Mar 2014    Post subject: Reply with quote
I'd (not) suggest something along these lines: https://www.bikechatforums.com/viewtopic.php?t=237320&highlight=exhaust
PostPosted: 20:36 - 20 Mar 2014    Post subject: Reply with quote
Thumbs Up to tin can, I was probably over-thinking it.
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 86.88 Kb
