454ltd / en450 lack of power - timing chain repalcement?
rebeltaz
PostPosted: 19:33 - 22 Mar 2014    Post subject: 454ltd / en450 lack of power - timing chain repalcement? Reply with quote
Guys, I have an 86 Kawasaki EN450/454LTD that has lost power on the upper end. It still has get up and go, but I can only get 65-70 mph at full throttle in top gear on a flat straight away. I have rebuilt the carbs twice and replaced the spark plugs.
I do know that I had to replace the cam chain tensioner last year and when I did, I thought the cam chain felt a little loose. I am going to check the valves, the cam chain and timing this week, but I wanted to see - first, if anyone had any other ideas - and second, the entire crankcase has to be split to replace a timing chain on this bike, doesn't it? That is a very bad design, if you ask me, from a mechanics point of view.
Thanks.
Derek Tombrello
www.ShelbyCycle.com (for profit)
www.RobotsAndComputers.com (just for fun)
yen_powell
PostPosted: 19:44 - 22 Mar 2014    Post subject: Re: 454ltd / en450 lack of power - timing chain repalcement? Reply with quote
Thanks.
You can fit a split cam chain, using the old one to pull the new one through, then rivet it up.
XT1200Z and a DR350 in bits
rebeltaz
PostPosted: 20:01 - 22 Mar 2014    Post subject: Reply with quote
Where would I find a split chain? All I can find is the factory original single piece. Thanks.
Derek Tombrello
yen_powell
PostPosted: 20:28 - 22 Mar 2014    Post subject: Reply with quote
https://www.galeacamchainservices.co.uk/
Go see Tony.
temeluchus
PostPosted: 21:40 - 22 Mar 2014    Post subject: Reply with quote
before you take the drastic step of replacing the camchain,
check the diaphragms on the carbs, if they are split, the bike will run ok, but effectively it does not allow the throttle to open fully.
rebeltaz
PostPosted: 21:43 - 22 Mar 2014    Post subject: Reply with quote
Go see Tony.
lol... Europe is a bit of a road trip for me. I'm in the Southern United States.
Derek Tombrello
rebeltaz
PostPosted: 21:50 - 22 Mar 2014    Post subject: Reply with quote
I called myself checking them when I took them apart the last two times, but I am going to given them one more look before shooting it... I mean going deeper Smile
Derek Tombrello
PostPosted: 21:52 - 22 Mar 2014    Post subject: Reply with quote
Official way to replace the cam chain is to split the crankcases (primary chain is also a pain to replace). But a rivet link cam chain should be available.
temeluchus
PostPosted: 01:12 - 23 Mar 2014    Post subject: Reply with quote
Another possibility-
Could also possibly be the ignition not advancing? Do you have a spare ignitor?
rebeltaz
PostPosted: 01:16 - 23 Mar 2014    Post subject: Reply with quote
I don't, no... I could try to get one, I suppose.
Derek Tombrello
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3.14 - MySQL Queries: 13 - Page Size: 70.35 Kb
