Honda NSR 125 knocking
fanax
PostPosted: 21:54 - 24 Mar 2014    Post subject: Honda NSR 125 knocking Reply with quote
Hello,
First of all, sorry for my bad English, it is not my first language.
Ok, I'm have a problem. After top-end rebuild, I hear knocking sound at low rpm, until I reach 4000rpm's.
I hope it is not big end bearing?
I'm not changed small end bearing, but before rebuild there were no such sounds.
Here is video of my NSR sound, and little end:
https://www.youtube.com/watch?v=Fc5a7iR9RF4&list=UUsORh6AhgOI05_cN4DTxyQA
https://www.youtube.com/watch?v=EzYJWnjgr60&list=UUsORh6AhgOI05_cN4DTxyQA
Thanks Wink
fanax
PostPosted: 11:12 - 25 Mar 2014    Post subject: Reply with quote
mpd72 wrote:
What did you change? Was it re-bored? if so did you modify the head gasket's inner circumference? Has the head been modified, if so was the plug raised with washers before and not now?
Did you rebuild after any piston/ring damage? Maybe there's still a bit of piston/ring, which could have been lurking in the crank but is now bouncing around in the combustion chamber
It does sound top end, rather than main bearings.
I changed piston, rings. I did honing. I looked, head gasked is ok, piston isn't touching it. Plug was raised, and i kept it raised.
I rebuild it, because the compression was low. Everything else was in good condition.
I don't know what check. I looked at power valve, but it is ok.
What you can say about small end from video? Connecting rod is straight, just video is distorted. But I worry because bearing is moving sideways, and I don't know is this right?
I'm newbie at motorcycles Very Happy This is my first.
fanax
PostPosted: 17:30 - 25 Mar 2014    Post subject: Reply with quote
I rebuild it a few days ago. Piston is from "Meteor" 53.95cm (A). The old one has not been marked, so I think it was original. Engine does 14000km.
Have any ideas?
alains
PostPosted: 20:22 - 25 Mar 2014    Post subject: Reply with quote
did you ckeck the side play of the conrod bid end ? it should be 0.4 to 0.7 mm . the small end play is normal
the other thing to Watch is the balancer bearing
The last post was made 12 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 50.29 Kb
