Hayabusa Not Charging battery?
Ammoman
PostPosted: 11:59 - 26 Mar 2014    Post subject: Hayabusa Not Charging battery? Reply with quote
My 2nd Gen Hayabusa is not charging the battery? Voltage of around 12.5 when running when it should be around 14v. I have replaced the Stator but still the same Sick Any ideas people? Thanks..
2013 ZZR1400 & Honda CG125 1986..
sabian92
PostPosted: 12:15 - 26 Mar 2014    Post subject: Reply with quote
Checked it isn't your battery that's shagged?
Mine wasn't charging and was showing a low voltage, replaced the battery and bang, worked fine.
PostPosted: 12:26 - 26 Mar 2014    Post subject: Reply with quote
Have you done the stator and checked output voltage of it in AC?
Have you also replaced the regulator?
Ammoman
PostPosted: 13:43 - 26 Mar 2014    Post subject: Reply with quote
Changed Stator and checked voltage in DCv and no change when engine running.
New Battery fitted.
Do I now change the Regulator Question
PostPosted: 13:53 - 26 Mar 2014    Post subject: Reply with quote
Get AC voltage from each of the stator wires at the connector.
Red probe on 1 wire, black on frame. AC volts rather than DC. You should have roughly the same across all 3. Check it increases with rpm, so 5000rpm.
If they are outputting a decent chunk and are within a few V of each other, I'd hazard a guess the regulator may be toasted.
I'd replace both as a matter of course regardless.
PostPosted: 20:12 - 26 Mar 2014    Post subject: Reply with quote
The 'busa generator should put out more than 65V AC on all three phases at 5000rpm to be declared healthy. Un-plug the genny and test with a meter across the yellow wires - all three combinations of pairs.
The battery voltage should read between 13.6V and 15.1V at 5000rpm with a fully charged battery.
If the AC test proves the genny is good, which it likely is since you swapped it with no change, then first of all follow the reg/rec wires to the loom plug these have a habit of going rotten and melting. I know of several Gen1 'busas which have the reg/rec plug chopped off and a chocolate block put in it's place.
If the plug seems ok then check out the black lead from the battery. It splits into a thicker and a thinner lead. The thinner one has a heavy spade connector on it and this can corrode causing all manner of problems including not charging.
stuartt
PostPosted: 22:25 - 06 Apr 2014    Post subject: Reply with quote
thats my busa not charging now Sad
PostPosted: 22:43 - 06 Apr 2014    Post subject: Reply with quote
Check the plug on the reg/rec first of all. They are known to melt - my mate has had his connected by chocolate block for the last few years. Then check the loom earth spade connector which is a few inches from the battery -ve terminal. This bad boy in the attached image is what stopped mine charging.
stuartt
PostPosted: 23:12 - 06 Apr 2014    Post subject: Reply with quote
thanks pete .
the f1 light came on 2 weeks ago , i switched the bike off to see if restarting it would clear the light but the bike wouldn't start .
i bought a new battery & i thought the bike was ok .
i took it out tonight & after 5 miles the f1 light came on again !
i phoned my boy & he came & met me with the battery out of his cg125 , it did the job to get me home Very Happy
i'll check the connections tomorrow , thanks again .
PostPosted: 23:24 - 06 Apr 2014    Post subject: Reply with quote
Yes, a very flat battery will put the FI light on, but it won't come on to tell you the bike isn't charging.
You have to remove the tailpiece to get to the reg/rec, it's fixed to the seat subframe near the left grab handle.
stuartt
PostPosted: 23:31 - 06 Apr 2014    Post subject: Reply with quote
Mine is under the bike behind the stand just infront of the back wheel , my busa is a k9
Busa1340R
PostPosted: 23:38 - 06 Apr 2014    Post subject: Reply with quote
Not on a Gen2 it isn't (unless someone has moved it)........it's on a bracket below the front end of the swingarm.....above the rear fairing extension. 😉
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
stuartt
PostPosted: 17:44 - 09 Apr 2014    Post subject: Reply with quote
thats my bike fixed , it turned out to be the regulator .
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 77.07 Kb
